    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    aerobic decoupling
    Scheduled Pinned Locked Moved SuuntoPlus™ Sports Apps
    37 Posts 14 Posters 10.5k Views 14 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Raimo JärviR Offline
      Raimo Järvi @Mads Hintz-Madsen
      @Mads-Hintz-Madsen Thank you for testing!
      Aerobic decoupling app doesn’t use normalized power, it currently uses 5 minute rolling average of power and HR values for calculating decoupling value (for cycling). This is also the value shown in Suunto app graph.
      Pragmatic Programmer
      Mads Hintz-MadsenM 1 Reply Last reply Reply Quote 2
      • Mads Hintz-MadsenM Offline
        Mads Hintz-Madsen Silver Members @Raimo Järvi
        @Raimo-Järvi Thanks for clarifying!
        How is the final decoupling value (listed in the summary) calculated? Is that calculation using the average power and average heartrate over the entire activity (excluding warmup/baseline periods)?
        In the Suunto App graph, there is an average decoupling value which is different from the final decoupling value. I assume that this average then is the average of the rolling 5-minute decoupling values.
        Raimo JärviR 1 Reply Last reply Reply Quote 0
          @Mads-Hintz-Madsen “Final decoupling” is value from last 5 minutes. I guess the name is not very descriptive, app description in SuuntoPlus store should also be updated.
          Suunto app graph calculates average of all values during the workout, in this case the values are decoupling values from rolling 5 min average. And since the graph includes 10 min warmup and 10 min baseline calculation, those zero values are included in the average. I guess first 20 minutes should not be included in data, or in calculating the average 🤔
            @Raimo-Järvi said in aerobic decoupling:
            I agree.
            • ? Offline
              A Former User
              I have been using S+ aerobic decoupling for my running and walking activities and everything works as expected…
              however, it seems that for the nordic walking and treadmill activities it does not work, i.e. if you activate it, start the activity, as soon as you select the aerobic decoupling page the watch displays a warning:
              power not available, pair power sensor for measurements.
              I know that power is used when it is available, but otherwise pace is used, so if I am not missing something it should work.
              or not?
                Raimo Järvi @Guest
                @robis Power or pace is used according to activity type. Power is used for example for cycling, but it should not be used for nordic walking. We will fix it, thank you for reporting it.
                • W Offline
                  wakarimasen Gold Members @Brad_Olwin
                  @Brad_Olwin Can you please explain this a little more?
                  Suunto Race Titanium
                  Suunto Ambit3 Peak
                  Polar H10
                  Polar OH1
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator @wakarimasen
                    @wakarimasen If I am maintaining aerobic metabolism below my aerobic threshold the S+ app will show good or a green number. If I an going too hard it will show red in real time.
                    Vector/T6c/Vertical 2 Ti
                    lexterm77L 1 Reply Last reply Reply Quote -1
                    • W Offline
                      Thanks @Brad_Olwin - that’s clear. Does this depend on the heart rate established during the reference period? I tried this app during a walk earlier in the week and saw negative and positive percentage values following the baseline being established.
                      Suunto Ambit3 Peak
                      Polar H10
                      Polar OH1
                      J 1 Reply Last reply Reply Quote 0
                      • lexterm77L Offline
                        lexterm77 Bronze Member @Brad_Olwin
                        @Brad_Olwin said in aerobic decoupling:
                        Assuming that entire run (including base evaluation time) has a constant grade. Else, not really because math and stuff.
                        H 1 Reply Last reply Reply Quote 0
                        • H Offline
                          halajos Bronze Member @lexterm77
                          I can’t get this S+ app to work properly on my S9B. I tried it when it was first introduced and then didn’t use it for long. Now I’m experiencing all kinds of issues with it. First I wasn’t able to activate it on the watch (when I tried to select it, the selection reverted to ‘none’). Then after a soft reset I could activate it, but had a crash during the run. Tried to reinstall the S+ app, then also the suunto app on my phone, but still have issues. Now I can select it, but the S+ screen is blank (while other S+ apps’ screen isn’t). Anyone else having issues?
                          • ? Offline
                            A Former User
                            I recently ran into this problem. Sometimes the GPS behaves strangely for known or unknown reasons (probably because I was under a 380kV power line…), and as shown in the image, where the speed suddenly went from ~7 to ~23 km/h (and then later from 7 to 14km/h) for several seconds, the decoupling recording was compromised. Can anything be done to filter out these spikes in the S+ app?
                            • J Offline
                              JVallS @wakarimasen
                              Using a S9B I cannot get S+ AD app to work for Treadmill activities. It works well for Run activities though: live Good/High green/red labels and % change on the watch after warm-up and baseline evaluation, and reasonable max/final 5-min rolling avg values and charts in SA.
                              For Treadmill activities I can select the AD app and start recording, warm-up and baseline show the countdown in the dedicated screen on the watch as usual, but from 20’ on I get a fixed screen with the High red label and dashes for % change. SA gets the laps (10’, 10’, and the rest), but there’s no record of decoupling at all. @Raimo-Järvi, could you report or look into this?
                              It’d be great–for the incline/speed (constant external) established during warm-up and settled as baseline for the activity–to see whether or not and when my HR (internal) decouples. Despite pace being off-the-mark on a treadmill, especially at an incline, the internal to constant external ratio can be a great indicator, and a treadmill provides repeatability for progress assessment.
                              I’d appreciate your comments, @Brad_Olwin.
                              S9B Black (S5 battery draining too fast then died on me)
                              S5 gen 1 (warranty replacement for SSTWHR)
                              Suunto App beta on Moto G8 Power
                                Raimo Järvi @JVallS
                                @JVallS Unfortunately I don’t work for Suunto any more, so I can’t do anything to fix this. I guess Aerobic decoupling app requires a power sensor for Treadmill activities, were you using one?
                                • J Offline
                                  JVallS @Raimo Järvi
                                  @Raimo-Järvi Thanks for writing back.
                                  Not using a Power meter at all and S+ AD never prompted me for one. Using a decent OHR armband (Scosche Rhythm+2.0) though. A chest strap is too much of a bother.
                                  I understood that aerobic decoupling works on Pace (and HR) ratios in running sports and Power (and HR) in cycling. The issue was addressed above (Q 29 Jan 2024: https://forum.suunto.com/post/137994; your response 30 Jan 2024: https://forum.suunto.com/post/138079).
                                  Again, thanks for writing back.
                                    Raimo Järvi @JVallS
                                    @JVallS I’m sorry, I should have read my own responses 😇 I think Aerobic decoupling app was fixed for nordic walking so that it uses pace. But treadmill still uses power: if I activate it in Suunto Vertical for a treadmill activity, it says “Power not available…”.
                                    I’m not sure why treadmill wasn’t changed like nordic walking, or if it was intentional. Since I didn’t reply anything about treadmill, maybe I just missed it and it was accidentally left to use power 😞
                                    • J Offline
                                      JVallS @Raimo Järvi
                                      @Raimo-Järvi Who do you think I should reach out to about this then? It’d be great to have it sorted out!
                                      Register Login
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
