    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    HRV and recovery
    Scheduled Pinned Locked Moved Suunto Vertical
    29 Posts 17 Posters 5.5k Views 16 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • jjpazJ Offline
      jjpaz Bronze Member @Brad_Olwin
      @Brad_Olwin Resources feature and recovery times will be corrected in next update? Those features aren’t working from the Vertical launch.
      Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
      Stefan KerstingS isaziI 2 Replies Last reply Reply Quote 0
      • Stefan KerstingS Offline
        Stefan Kersting Platinum Member @jjpaz
        @jjpaz why didn’t it work from the launch?
        Instagram: https://www.instagram.com/helgelandsbukken/
        https://www.instagram.com/suunto_adventures/
        IG: Helgelandsbukken, suunto_adventures
        Vimeo: vimeo.com/helgelandsbukken
        Blogg: https://turblogg.midnattsola.com
        jjpazJ 1 Reply Last reply Reply Quote 0
        • isaziI Offline
          isazi Moderator @jjpaz
          @jjpaz yes, no more firstbeat, all algorithms are new. Still some testing needed, it’s a big change, but coming Autumn 2023 (as far as I know).
          Blog: isazi's home
          DMytroD 1 Reply Last reply Reply Quote 4
          • DMytroD Offline
            DMytro @isazi
            @isazi to all devices that had firstbeat previously or only to the recent ones?
            isaziI 1 Reply Last reply Reply Quote 1
            • isaziI Offline
              isazi Moderator @DMytro
              @DMytro can’t comment, don’t know the plan for old UI devices.
              Blog: isazi's home
              • jjpazJ Offline
                jjpaz Bronze Member @Stefan Kersting
                @Stefan-Kersting There are two issues here:
                • 1: Resources “graph”: Resources increase when you rest and decrease when there is stress. OK but that decrease process is very random. Sometimes you go for a easy run and suddenly resources decrease to 0%. Also, when you charge the watch resources “reset” and start from 50%.
                  It is also not clear which HR value should be set as the resting HR value.
                  Some people configure the minimum HR when sleeping, some people the rest HR when resting sitting… If you configure the minimum HR is nearly impossible to reach 100% resources and is very easy to go 0% after a short easy run.
                  In my case I ignore the resource function.
                • 2: Recovery time: the timer is also random. You finish an activity and the watch shows a recovery time. With old watches that timer is decreasing hour by hour until reaching 0h, at least in my S9B and S9P was working that way. In the Vertical that timer is frozen several hours, then decrease by some hours, then freeze another time. Sometimes always shows the original recovery time until the hours are completed and changes to 0h… Random. And this feature was working fine in previous models.
                I understand that, if Suunto is changing the recovery algorithms, it has no sense to invest resources in correcting this feature but then I hope that this feature will be corrected with the new algorithm and software.
                Stefan KerstingS 1 Reply Last reply Reply Quote 3
                  @jjpaz yes it is important to find out the rest HR to configure the ressource calculation right. there are discussions aabout that in this forum too. I have not figured out which rest HR I should take. Anyway, I think it is not the right approach to get 100 % ressources when getting up in the morning. Our body is little more complex than that. A cold shower or a big pizza late in the evening will impact you stress level/HRV, so there are a lot of factors that are influencing you ressources.
                  I don’t use the recovery time that much. Often I get a recovery time of 120 hours, especially after some hours on skimo. I am listening more to my body and the recovery time seems to be a little bit unrealistic sometimes. Maybe the math is right, but my body doesn’t feel for a 5 day recovering period
                  • seanvkS Offline
                    seanvk
                    Using this existing thread to note that with the new Vertical update, my reported nightly HRV is consistently about 10 less than what my Garmin 7X is reporting. I will continue to see if it reconciles eventually.
                    Suunto Race Titanium
                    Suunto 9 Peak Pro Forest Green
                    Suunto 9 Peak Moss Gray
                    • W Offline
                      wakarimasen Gold Members
                      Not poking anyone and really not wanting to offend, but I see a number of these comments that ‘my Suunto is not the same as my…’ I work in the world of metrology, where nothing is ‘correct’ in absolute terms: i.e. everything has a level of permissible error. I have many conversations about this: just because you compare one thing with another, neither is necessarily ‘right.’ It’s a comparison between two devices. Arguably, the Suunto may be more accurate than the Garmin!
                      Suunto Ambit3 Peak
                      Polar H10
                      Polar OH1
                      1 Reply Last reply Reply Quote 9
                      Register Login
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
