    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Hardware: watch cutting my wrists
    Scheduled Pinned Locked Moved Suunto Vertical
    20 Posts 18 Posters 3.3k Views 16 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      darguelles Bronze Member
      I use the Suunto Vertical for mountain biking. Especially on descents, the watch tends to bounce around a lot. That bounce + the straight angles on the watch have often cut into my writs leaving some interesting cuts (images attached).
      Has anyone else had this issue? If so, any fixes/ tips?
      WhatsApp Image 2023-09-28 at 22.14.49.jpeg WhatsApp Image 2023-09-28 at 22.15.11.jpeg
      surfboomerangS mikekoski490M freeheelerF Mads Hintz-MadsenM ___Alejandro____ 6 Replies Last reply Reply Quote 0
      • surfboomerangS Offline
        surfboomerang @darguelles
        @darguelles on the last picture I see you’re wearing the watch very loose. I would suggest to tighten the strap a notch or two so that the watch is fixed on your wrist.
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        D 1 Reply Last reply Reply Quote 1
        • mikekoski490M Offline
          mikekoski490 Bronze Member @darguelles
          @darguelles Maybe get a handlebar mount and wrap it onto your bars instead?
          There is no way the bouncing around you are doing is getting any type of accurate OHR so if you need that metric get an HRM.
          Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
          Current: Suunto Race Ti
          Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
          Suunto App running on Google Pixel 8/Android 14
          • D Offline
            darguelles Bronze Member @surfboomerang
            @surfboomerang yup, that picture I’m not even closing the strap. It was just to show what’s the part of the watch hitting the wrist. I do wear it as tight as it’ll go when biking
            • freeheelerF Offline
              freeheeler @darguelles
              @darguelles
              bigger and heavier watches are in general not ideal for fast and long descents on bumpy, rocky and rooty trails (as you have mentioned in the other thread 😉)
              I don’t have this problem with my Vertical.
              but wrists are different. you could try a buff (maybe a modified one) between your glove and watch to reduce movement
              living sideways
              • Mads Hintz-MadsenM Offline
                Mads Hintz-Madsen Silver Members @darguelles
                @darguelles based on your cuts then it seems like you are wearing your watch so that it hits your wrist bone.
                General recommendation for best wrist-based OHR is to wear it so that there are two fingers width between your wrist bone an the watch, i.e. l, wear it higher up your forearm.
                Your arm is more round and potentially narrower there so that might help you.
                1 Reply Last reply Reply Quote 3
                • LechamoixL Offline
                  Lechamoix Bronze Member
                  Nothing from my side 🙂
                  • Martin VrskaM Online
                    Martin Vrska @darguelles
                    @darguelles I use the original Suunto watch holder 😉👍.
                    Suunto Vertical 2 - Arctic Gray - 2.56.18
                    Suunto Spark
                    Suunto Vertical - Steel Black, Strap Canyon Orange - 2.37.34 - SOLD
                    Suunto 9 Peak Pro - Titanium Sand - 2.22.60 - my wife
                    Google Pixel 9a - Android 17
                    Suunto App 6.12.7 beta
                    • SuperFlo75S Offline
                      SuperFlo75 Silver Members Bronze Member
                      I have no Problem with this after over 5 month using the SV
                      Suunto Vertical 2 Titanium Sage
                      Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
                      Suunto Wing
                      Suunto 9 Peak Pro Titanium (owns my wife now)
                      Suunto Spartan Ultra
                      SA iOS 3.12.0 (22937)
                      Instagram @superflo75
                      • Stoke80S Offline
                        Stoke80
                        I unfortunately had the same experience, but not quite as bad and only the upper side.
                        I think it is not the button that presses, but the edge of the metal where the bracelet is fixed. I think these edges are quite “sharp”, especially on the downside.
                        Wearing the Vertical tighter during biking definitely helped me.
                        Since I always have a HR belt on anyway, it would probably be even better to attach the watch to the handlebars.
                        Then you do not always have to let go of the handlebars to look at the clock.
                        Suunto Quest / Suunto Ambit 3 Peak / Sununto Spartan Sport Wrist HR / Suunto 9 Baro / Suunto 9 Peak Pro / Suunto Vertical / Suunto Race S / Suunto Race 2
                        • N Offline
                          nseslija Bronze Member @darguelles
                          @darguelles Never wear the watch on the wrist while riding, always on handlebar…
                          Ambit 2S
                          Ambit 3 Peak
                          Suunto 9 baro
                          Suunto Vertical Ti Solar
                          Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 3
                          • ___Alejandro____ Offline
                            ___Alejandro___ @darguelles
                            @darguelles You could wear it on your right arm instead. Should be much less wrist contact with the buttons.
                            • Łukasz SzmigielŁ Offline
                              Łukasz Szmigiel @nseslija
                              @nseslija basically this.
                              It’ll work like a bike computer and you’ll get better asc/dsc readings. However, you’ll need external sensor for HR.
                              S9PP 2.50.28
                              • Andrew_A Offline
                                Andrew_ @darguelles
                                @darguelles
                                Hi there!
                                So, while I have not personally experienced this, I have read ONE other report of it doing the same thing to someone else. This resulted in them returning their watch.
                                As someone else mentioned, by the location of your marks, it appears you’re wearing your watch right on your wrist bone. Also rather high on your wrist, which may not be optimal for casual use… comfort… and especially sports.
                                Keep in mind with flexion of the wrist, naturally (especially when MTB) you’re going to experience discomfort anywhere space is expanding and contracting with something be in that zone.
                                I’d recommend wearing it below the wrist bone, especially if you plan on giving it another shot. I believe that’s the opportunity here, but that’s just my OP.
                                • Suunto Vertical Steel, All Black
                                • Suunto Wing, Lava Red
                                • zhang965Z Offline
                                  zhang965
                                  Sad to see this…
                                  Winners Wear Winners
                                  • dreamer_D dreamer_ referenced this topic on
                                  • Olaf GottschalkO Offline
                                    Olaf Gottschalk Bronze Member
                                    I have exactly the same problem with my Race… 😞 My marks and scars on my arm are identical to yours and I did not find any position the sharp metal edges of the SR are touching the wrist bone. Wearing it higher with 2 fingers space between the wrist bone and the watch - how should that work? It will always losen and move downwards and then be too lose to detect my heart rate.
                                    I think the overall design of these watches is flawed massively. 😞
                                    • sartoricS Offline
                                      sartoric Moderator
                                      Yeah, sure.
                                      You know what is said “all wrists are created equals”
                                      SVTS - 2.50.28
                                      SSSWHR BARO Amber - 2.8.32
                                      Samsung A5 2016 - Android 7.0
                                      Suunto App Android 6.11.12 beta
                                      Mff73M 1 Reply Last reply Reply Quote 1
                                      • Mff73M Online
                                        Mff73 @sartoric
                                        @sartoric
                                        and some are more equals than others 😉
                                        SSU (retired), SV1, SV2
                                        Wife : S9PP
                                        SA: Always the latest beta :)
                                        Android + Galaxy S205G
                                        M 1 Reply Last reply Reply Quote 0
                                        • M Offline
                                          Mauerwegler @Mff73
                                          @Mff73 @sartoric I don’t know what is so funny about the problem discussed in this thread that warrants your jokes. There are a couple of users who report problems with the lugs of some watches and clearly it is bad design. There is no need to have such sharp corners on the lugs. The users can’t return them anymore because they have had the watches more than 14 days. They have to deal with an absolute unnecessary, bloody annoying problem. It’s not funny.
                                          Vertical All Black
                                          Spartan Ultra Stealth Ti (with Polar H10 or Suunto Smart Sensor)
                                          Vector
                                          iOS Suunto App (beta)
                                          Mff73M 1 Reply Last reply Reply Quote 0
                                          • Mff73M Online
                                            Mff73 @Mauerwegler
                                            @Mauerwegler
                                            with all my respect, we can laugh about everything, but not with everyone.
                                            We are not mocking people nor their problems, we are making generic humour.
                                            Watch design is unique, humankind wrists are not.
                                            Sorry if it is not funny for you.
                                            PS : i have such wrist which is not equal to Suunto’s design, my SV is “hurting” me as well, but my wife’s sometime as well, i can’t return it/her neither 🙂
                                            PS2 : https://en.wikipedia.org/wiki/Animal_Farm
                                            Wife : S9PP
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
