    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    SV clocking a 7.9mi loop at 8.15mi. Is this the general margin of error with Suunto?
    Scheduled Pinned Locked Moved Suunto Vertical
    25 Posts 12 Posters 3.3k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Andrew_A Offline
      Andrew_
      Hi all
      I’ve done this same 7.9mi trail run over 100 times. With the higher end GARMIN 955, Fenix 6-7, 7Pro. Generally, I fall at 7.8-8.3mi. However, Suunto, in “performance mode” with GPS lock confirmed, is over calculating.
      Is there a way to fix this, or is this just a characteristic of Suunto? Not taking a shot at Suunto, you should see the characteristics of my Tacoma, per Toyota lol.
      Anyway, on pavement, it’s within .04mi on courses I run. Which is totally cool, IMO. The GPS tracks, for this tree covered trail run, look almost identical GARMIN, it’s just recording a longer distance. It may be worth noting there is about 700ft of elevation. Little hillly
      I can accept the incredibly sensitive accelerometer, the horrible calorie counting estimates (which are wildly inaccurate on ANY wrist based fitness tracker, but Suunto’s are comically lol… That said, I need reliable GPS tracking within .05mi when I do my ultra 1-200’s
      Any thoughts?
      Yes, it’s up to date
      iPhone 14 Pro, latest OS, no beta
      My buddies that run use Coros, GARMIN, and an Apple Watch Ultra. They are clocked in about the same 7.9-8.3mi. The Suunto is the only one that off by more than I believe is acceptable.
      It’s also worth noting that this is a constant run, no stops, and the overall tracking is complete… with no breaks in the GPS track.
      I am overall pleased with the Suunto, so I’m hoping there may be an underlying problem 😜
      • Suunto Vertical Steel, All Black
      • Suunto Wing, Lava Red
      sartoricS M EzioAuditoreE leafs93L Mouse CruiserM 5 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @Andrew_
        @Andrewx01
        Am I missing it or, you didn’t mentioned the distance measured by SV ?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.12 beta
        Mff73M Andrew_A 2 Replies Last reply Reply Quote 0
        • Mff73M Online
          Mff73 @sartoric
          @sartoric
          Same question from me 😉
          SSU (retired), SV1, SV2
          Wife : S9PP
          SA: Always the latest beta :)
          Android + Galaxy S205G
          sartoricS 1 Reply Last reply Reply Quote 0
          • sartoricS Offline
            sartoric Moderator @Mff73
            @Mff73
            I mean, in the title the distance is the same as Garmin and company
            SVTS - 2.50.28
            • Andrew_A Offline
              Andrew_ @sartoric
              @sartoric
              To clarify, and I worded it poorly, a loop that is 7.9 miles is not being calculated as such from the SV
              SV measured 8.15mi
              GARMIN was 7.9
              Other GARMIN was 8.1
              • Brad_OlwinB Offline
                Brad_Olwin Moderator @Andrew_
                @Andrewx01
                1. How do you know the exact distance of the loop?
                2. If hilly are all watches tracking 3D distance?
                Vector/T6c/Vertical 2 Ti
                Andrew_A 1 Reply Last reply Reply Quote 1
                • Andrew_A Offline
                  Andrew_ @Brad_Olwin
                  @Brad_Olwin
                  Hey Brad!
                  I’m not 100% how it’s been officially measured. I know it a public race trail, that has mile markers.
                  I’m unsure if Garmin or Coros take the hills into perspective. I’d imagine the higher end Garmin’s may?
                  My buddy has a Fenix 7 pro, and the other has an Apex 2 Pro
                  Thanks for your help btw, I appreciate it.
                    @Andrewx01 said in SV clocking a 7.9mi loop at 8.15mi. Is this the general margin of error with Suunto?:
                    @Brad_Olwin
                    Hey Brad!
                    mile markers on my trails are not correct. This is a hard thing to actually figure out. I would try some roads where you know the distance. I have found my Vertical to be very accurate. Comparing to an Epix2 about one year ago they were more or less identical for distance. I can show you some examples if you like. I would not trust the Coros to be as accurate as the Garmin based on tests I have seen from the professional reviewers.
                    The Apex 2 Pro, however, is likely better. The best way to do this is get a measuring wheel and measure 3k or so (at least 3 times) then use the watches, wearing all that you are going to test, switch arms with the watches and test again.
                    zhang965Z 1 Reply Last reply Reply Quote 1
                    • zhang965Z Offline
                      zhang965 @Brad_Olwin
                      Brad_Olwin said in SV clocking a 7.9mi loop at 8.15mi. Is this the general margin of error with Suunto?:
                      Comparing to an Epix2Pro about one year ago they were more or less identical for distance.
                      Wow, comparing epix 2 pro about one year ago.
                      It looks like we found why this person’s s9p has wrist power. Loool
                      Winners Wear Winners
                      EgikaE 1 Reply Last reply Reply Quote -9
                      • M Offline
                        martin Bronze Member @Andrew_
                        8.15 < 8.3 isn’t it ? so the suunto is not the worse ?
                        • EgikaE Offline
                          Egika Platinum Member @zhang965
                          @zhang965 said in SV clocking a 7.9mi loop at 8.15mi. Is this the general margin of error with Suunto?:
                          I don’t know if you are having any personal issues, but what added value does your comment bring to this thread?
                          A zhang965Z 2 Replies Last reply Reply Quote 5
                          • A Offline
                            altcmd Silver Members @Egika
                            @Egika he doesn’t like his Garmin either 😄
                            1 Reply Last reply Reply Quote 4
                            • EzioAuditoreE Offline
                              EzioAuditore Gold Members @Andrew_
                              @Andrewx01 In my experience Garmin always ‘under-counts’. I’ve run with 3 watches simultanuosly (Suunto, Garmin and Apple) and the Suunto - Apple were basically showing the same distance (Even I was wondering how is that possible after HM). The problem with Garmin’s when you enter the trails (so under trees it uses some weird ‘smoothing’ and also their SatIQ kicks in). So to compare the best Suunto to Garmin is if you set the Garmin not to Auto in the Sattelite mode but to Best / 1s - even after this it undercounts but not by much roughly 200m in a HM).
                              So on a well measured track of 10.89km Suunto always gave me: 10.90 - 11km and Garmin 8.9km to 10.2 (of course this was with the terrible 6X, I’ve tried Forerruner 965 and the results are much better at: 10.75 to 10.90.
                              Suunto watches: Vertical 2 (Titanium Sage), Race 2 (Titanium Trail), Ocean (Sand), Race (Titanium Charcoal), Vertical (Titanium Solar Sand), 9 Baro (Ambassador Edition), Spartan Ultra (Copper Edition), Ambit 2, S6
                              Suunto Wing
                              Brad_OlwinB 1 Reply Last reply Reply Quote 3
                              • zhang965Z Offline
                                zhang965 @Egika
                                @Egika said in SV clocking a 7.9mi loop at 8.15mi. Is this the general margin of error with Suunto?:
                                To let you add your added value in this post, darling
                                EzioAuditoreE 1 Reply Last reply Reply Quote -9
                                  EzioAuditore Gold Members @zhang965
                                  @zhang965 I don’t care about added values. Its a forum after all not a scientific publishing platform 🙂
                                  Suunto Wing
                                  zhang965Z 1 Reply Last reply Reply Quote 0
                                  • zhang965Z Offline
                                    zhang965 @EzioAuditore
                                    @Hristijan-Petreski said in SV clocking a 7.9mi loop at 8.15mi. Is this the general margin of error with Suunto?:
                                    It’s why you are not Suunto’s target audience.
                                    A 1 Reply Last reply Reply Quote -2
                                    • A Offline
                                      altcmd Silver Members @zhang965
                                      @zhang965 is this your idea of entertainment? thought you found greener pastured on Garmin - how is the Garmin forum?
                                        Brad_Olwin Moderator @EzioAuditore
                                        @Hristijan-Petreski Interesting as my AWUltra is often less distance than the Vertical and I think (I cannot be fully certain, maybe I should test the loop I have used a wheel to measure distance) the Ultra is measuring short.
                                        EzioAuditoreE 1 Reply Last reply Reply Quote 0
                                        • zhang965Z Offline
                                          zhang965 @altcmd
                                          @altcmd said in SV clocking a 7.9mi loop at 8.15mi. Is this the general margin of error with Suunto?:
                                          Garmin’s forum is boring, less entertainment then Suunto community forum.
                                          tazidenT 1 Reply Last reply Reply Quote 0
                                          • tazidenT Offline
                                            taziden Gold Members @zhang965
                                            So you’ve already been banned over there, aren’t you luv.
                                            S9PP
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
