    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Training Peaks Guides Sync Issue
    Scheduled Pinned Locked Moved Suunto Vertical
    5 Posts 4 Posters 874 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • C Offline
      craigeggleton Bronze Member
      Couple of issues I am seeing with syncing Training Peaks Guides:
      If you change a strutured workout on the Training Peaks calendar they do not update update or sync immediatley to suunto guides on the app… Also the 5 guides that are showing on the app do not match up correctly with the training peaks calendar. The attached screenshot shows more dtails but the calendar dates are ooff by 2 days. Is this a known issue and is there an easy fix?
      GiPFELKiNDG stromdiddilyS 2 Replies Last reply Reply Quote 1
      • GiPFELKiNDG Offline
        GiPFELKiND Silver Members @craigeggleton
        @craigeggleton hey had this Problem too, i deleted the “older” planned Guiding Workouts in the Suunto App and resynchronizing it/ the Watch with suunto App and the new plan from Trainingpeaks 😀hope this works for you, too 🤗
        If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, 9 Baro, 9 Peak, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android🏃🏼🧗🚵
        C 1 Reply Last reply Reply Quote 0
        • C Offline
          craigeggleton Bronze Member @GiPFELKiND
          @GiPFELKiND i found this solution as well. It would be nice not to have to use this work around. appreciate the feedback.
          • stromdiddilyS Offline
            stromdiddily Gold Members @craigeggleton
            @craigeggleton said in Training Peaks Guides Sync Issue:
            I had same issue with TP and now have the same with HumanGo. The weird part is the Suunto App shows the wrong day but the watch will prompt the workout on the correct day…
            Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
            User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV :)
            isaziI 1 Reply Last reply Reply Quote 0
            • isaziI Offline
              isazi Moderator @stromdiddily
              @stromdiddily I just checked the guides on the app, and for HumanGo now I have three workouts: today, 21/09, and 03/10. Between 21/09 and 03/10 there are other workouts that are not synced. Not sure about the logic, nor if the workouts are pulled by Suunto or pushed by HumanGo (the latter I would guess). The good thing is that everything worked so far, every day the correct workout is there for me.
              Anyway, if people with wrong dates could send screenshots of both the source app and Suunto app, and logs (and everything in a PM to me), I will open a bug with Suunto, and app developers can check.
              Blog: isazi's home
              • First post
                Last post
              Suunto Terms | Privacy Policy
