    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Navigation - turn notififactions
    Scheduled Pinned Locked Moved Suunto Vertical
    21 Posts 15 Posters 4.1k Views 17 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • P Offline
      pmossy
      Re: turn by turn instructions to early
      I have now run often and for a long time with the watch. The navigation instructions are not usable in my opinion and very confusing. Too bad actually - because the clock otherwise does what I need.
      Please bring the instructions finally in a logical order and does not show me at the point of change of direction already the next instruction. I would expect:
      1. about 100m before the turn an instruction about change of direction
      2. approx. 10 m before the turn a hint.
      3. next instruction only AFTER completion of the previous change of direction.
      Vertical Titan
      Suunto 9
      Ambit 3
      Ambit 2
      Vector
      A D JacobusJ sky-runnerS M 5 Replies Last reply Reply Quote 26
      • A Offline
        altcmd Silver Members @pmossy
        @pmossy the person who built the logic for navigation has clearly never used it or navigated with it. Seems like a very poorly built logic which has not been addressed for years.
        1 Reply Last reply Reply Quote 17
        • D Offline
          duffman19 @pmossy
          Just discovered this problem as well. Perhaps it’s been discussed elsewhere, but, yes, the navigation prompts are a bit confusing. @pmossy described how it should function: initial prompt before turn, second prompt at or just before turn, and a “next turn” prompt some time after completing the turn.
          The fact that the next turn prompt displays before completing the current turn is just poor design. My guess is that the algorithm is set to prompt the next turn when within a certain distance of the current turn (seems to be ~10m), but doesn’t have the ability to discern whether you are located in front of or past the current turn POI relative to your direction of travel. I would guess this could be an easy fix since the watch presumably already knows your direction of travel, but I really don’t know.
          An even simpler fix would be to have the next turn prompt always show at a set distance, such as .5km. If the next turn is less than this distance, then it simply won’t show and you’d only receive the 100m turn prompt.
          Also, is it just me or are the turn notifications displayed for too short of a time? It seems to be about 4-5 seconds. If your watch is under a jacket or long sleeves and you’ve got gloves on, that’s certainly not enough time to dig under everything and view the prompt. 8-10 seconds would be preferred.
          Vertical Ti / S9PP Ti / S9P Ti
          1 Reply Last reply Reply Quote 3
          • JacobusJ Offline
            Jacobus @pmossy
            @pmossy I always have turn by turn turned off, I usually just run the route by briefly looking at my watch. Sometimes I start the same route with Komoot on my phone and then have voice prompts through my bone conduction headphones, which works quite handy in practice.
            A 1 Reply Last reply Reply Quote 1
            • isaziI Online
              isazi Moderator
              Agree, TbT prompts are wrongly timed and confusing, and this must change.
              Blog: isazi's home
              1 Reply Last reply Reply Quote 6
              • sky-runnerS Offline
                sky-runner Platinum Member @pmossy
                @pmossy The right solution would be to always display the next turn with the remaining distance at the bottom of the map (with or without the notifications). That’s what Garmin does, and that work really well.
                Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
                Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
                MarynM 1 Reply Last reply Reply Quote 13
                • MarynM Offline
                  Maryn Silver Members @sky-runner
                  @sky-runner Very good idea
                  Suunto Vertical, Suunto Race, Edge 530, Vantage V, Suunto Wings, Polar H10&Verity Sense
                  • A Offline
                    altcmd Silver Members @Jacobus
                    @Jacobus turning off TbT is not a solution even if that’s what most do.
                    Antoine LancrenonA 1 Reply Last reply Reply Quote 3
                    • Antoine LancrenonA Offline
                      Antoine Lancrenon Bronze Member @altcmd
                      @altcmd said in Navigation - turn notififactions:
                      yes, i have turned off the TbT also because of what its described here. I really hope Suunto is aware, they must have some stats from the watch usage? and see that nobody is using the TbT. and it is a shame!
                      Still, I love my watch! and it can only gets better!
                      isaziI 1 Reply Last reply Reply Quote 2
                      • isaziI Online
                        isazi Moderator @Antoine Lancrenon
                        @Antoine-Lancrenon kinda reported it again to Suunto, they are aware of the situation.
                        Blog: isazi's home
                        stromdiddilyS A 2 Replies Last reply Reply Quote 6
                        • stromdiddilyS Offline
                          stromdiddily Gold Members @isazi
                          @isazi said in Navigation - turn notififactions:
                          the Lord’s work 😄 😄
                          Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
                          User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
                          • A Offline
                            altcmd Silver Members @isazi
                            @isazi its the same way they are aware that their watch is laggy, atleast to Garmins and Ambits.
                            isaziI 1 Reply Last reply Reply Quote 0
                            • isaziI Online
                              isazi Moderator @altcmd
                              @altcmd they are also working on making the new watches less laggy, and according to most users the lag is pretty inconsequential when using the watch for real (not for YouTube) 🙂
                              Blog: isazi's home
                              1 Reply Last reply Reply Quote 4
                              • stromdiddilyS stromdiddily referenced this topic on
                              • outdoorramaO outdoorrama referenced this topic on
                              • outdoorramaO Offline
                                outdoorrama
                                Is there any progress or an interim status in solving this major problem?
                                Thanks!
                                outdoorramaO 1 Reply Last reply Reply Quote 4
                                • ? Offline
                                  A Former User
                                  Hi together!
                                  I have a short side-question, which i think belongs to this topic:
                                  Is it true that the turn-by-turn-notifications can only be used when the route was created in the Suunto App?
                                  If yes, how is it possible to turn them off, if i navigate with such a route? I only want to follow the route by looking at the route on my watch, without notifications.
                                  Thanks!
                                  Mff73M enriqueescomsE 2 Replies Last reply Reply Quote 0
                                  • Mff73M Offline
                                    Mff73 @Guest
                                    @flobru3101 said in Navigation - turn notififactions:
                                    False. 3rd party partners or specific gpx files can be used to create turn-by-Turn routes
                                    In route edit mode there is a switch to toggle turn-by-Turn on/off
                                    SSU (retired), SV1, SV2
                                    Wife : S9PP
                                    SA: Always the latest beta :)
                                    Android + Galaxy S205G
                                    • enriqueescomsE Offline
                                      enriqueescoms @Guest
                                      @flobru3101 Easy. When creating a route in the app you can enable/disable the little turn-by-turn tab.
                                      When you sync with your watch, if the route has turn-by-turn turned off, then there will be no turn warnings when you navigate that route.
                                      Suunto 9 Peak Pro (all black version)
                                      Suunto Race S (gravel gray)
                                        outdoorrama @outdoorrama
                                        @outdoorrama said in Navigation - turn notififactions:
                                        Thanks!
                                        This question still remains. And it is still a major problem.
                                        • D duffman19 referenced this topic on
                                        • J Offline
                                          Jonathan Schwarz Bronze Member
                                          Issue is still present as of May, 2024.
                                          Additional issues I would note;
                                          1. Text is too small to read easily when moving quickly
                                          2. Part of the instructions frequently get cut off (especially the street/trail name)
                                            3. It would also greatly improve the usability if a quick view of the map with the upcoming turn showed along with the notification (ie especially if you are on a data screen, for the notification to pop up with a small glimpse of the upcoming turn on the map). That way you have two ways to process the instruction - text and visual)
                                          Suunto Race Steel All Black -
                                          Suunto 9 Baro (retired)
                                          Suunto Ambit 3 Vertical Lime (retired)
                                          Suunto App - Always latest version
                                          • J Jonathan Schwarz referenced this topic on
                                          • M Offline
                                            Marco 4 @pmossy
                                            @pmossy completely agree, it is totally confusing and annoying receiving an upcoming turn still having to take the actual turn. But suunto does nothing about this making it very disturbing navigating with tbt activated…
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
