    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    remaining battery life
    Scheduled Pinned Locked Moved Suunto Vertical
    9 Posts 6 Posters 950 Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • yome77Y Offline
      yome77
      Why is it not proposed to display the amount of remaining battery in duration instead of percentages? In fact on a watch that lasts a long time between 2 recharges like the vertical, the choice of the duration in time is more interesting than the percentage.
      It is already an option that exists at Garmin, a shame not to find it at Suunto.
      Thanks
      TieutieuT Brad_OlwinB Łukasz SzmigielŁ 3 Replies Last reply Reply Quote 0
      • zhang965Z Offline
        zhang965
        Because suunto is not following anyone, suunto watches are made only for the hardcore ultra mountainers.
        Winners Wear Winners
        1 Reply Last reply Reply Quote -12
        • TieutieuT Offline
          Tieutieu Platinum Member @yome77
          @yome77 here is my opinion : battery life is so crazy that It is not very important IMHO.
          I personnaly never remember when I charged it last time, and never had the chance to went out of battery ! 😊
          PLUS : battery consumption depends on sport modes settings, the way you use your watch daily… So duration can’t be estimated as long the watch doesn’t know what uses are to come.
          And also : before starting an exercice, battery time-duration remaining is displayed, considering the settings you’re using for that mode.
          Suunto’s devices at home :
          Vertical titanium solar
          Suunto Race S
          S9pp titanium sand
          Suunto Wing
          S9B titanium Ambassador edition, A3P, X6
          1 Reply Last reply Reply Quote 9
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @yome77
            @yome77 What @Tieutieu stated, the critical information is needed for exercising and the battery life in hours is provided then.
            Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
            • yome77Y Offline
              yome77
              I agree with you, Suunto focuses on essential functions and that’s why I left Garmin. However, a widget that summarizes the different autonomy for our favorite activities would be a plus. And then for years our cars have been giving us the range in km in addition to the fuel gauge. Electric bikes do it too 🙂
              • Łukasz SzmigielŁ Online
                Łukasz Szmigiel @yome77
                @yome77 because it’s an absolute value, easy to relate to, especially after you learn how much battery in average an hour of workout burns.
                Showing estimated duration is very tricky as Suunto doesn’t strictly adhere to battery plan when the workout is set. You can start a workout with endurance mode but the watch will switch to the best battery mode whenever a navigation screen is active. So you can have an estimated 100 h battery time, but end up having only 50 when using the navigation.
                I wish there was a preference that would allow prioritising the battery over accuracy for scenarios where you really need the battery life.
                S9PP 2.44.52
                  @yome77 said in remaining battery life:
                  I used an Epix 2 for nine months and the battery summary was terrible. If maps or courses were used it was downright wrong. Got burned a few times with that. @Łukasz-Szmigiel said is correct, the battery life is not calculated until you select the options you want in an exercise, which as I stated before is critical. It is done on the fly and that is one reason there isn’t a widget.
                  TieutieuT 1 Reply Last reply Reply Quote 3
                  • TieutieuT Offline
                    Tieutieu Platinum Member @Brad_Olwin
                    @Brad_Olwin I also want to add that I use a lot the maps on the SV and it doesn’t affect that much battery consumption !
                    Suunto Race S
                    S9pp titanium sand
                    Suunto Wing
                    MiniForkliftM 1 Reply Last reply Reply Quote 1
                    • MiniForkliftM Offline
                      MiniForklift Platinum Member @Tieutieu
                      @Tieutieu I can agree with this. I did a two hour run in and around a forest at the weekend, the map screen was on the whole time and I think I used about 2% battery from memory
                      SV Titanium Solar Forest
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
