    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Distance measurement understimated
    Scheduled Pinned Locked Moved Suunto Vertical
    10 Posts 9 Posters 1.9k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • J Offline
      juza77
      Hi All, I’m using my Vertical a lot during my vacation on the Alps, and I’m facing an annoying issue. The reported distance is underestimated in comparison with all the route maps (on paper and online, like Gaia and Strava) I have checked. The total km at the end of the activity (trekking) is very far from the real route distance (even 3-4 km).
      Is there a way to calibrate my step length to increase distance accuracy, or a way to use GPS for the calculation of the distance instead of arm movement? Using sticks during my trekking I guess is creating such a discrepancy in the final distance measurement.
      Many thanks in advance for your support! Cheers!
      Simone
      sartoricS jjpazJ leafs93L 3 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @juza77
        @juza77
        maybe I don’t understand, but what do you mean saying
        are you recording a trekking activity ?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.8 beta
        • surfboomerangS Online
          surfboomerang
          To me it’s not really clear how you record your activity. I mean, if you start an activity type which supports GPS, it uses GPS for distance measurement. And that is really accurate on the Suunto Vertical.
          Some sport mode do not support GPS (mostly indoor sports) and then the distance is guessed by steps or other measurements. This can be highly inaccurate and causes your total distance to be way off.
          Can you tell us how you start your activity recording and what sport mode you’re using?
          Edit:
          I just checked the trekking activity type. It does support GPS. Please make sure that GPS is enabled in the settings right before you press Start.
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          • jjpazJ Online
            jjpaz Bronze Member @juza77
            @juza77 I suppose you are starting a Trekking activity with GPS enabled, wich battery mode are you using? Performance mode or another battery saving mode?
            Suunto Vertical Titanium Solar, Suunto Race 2 Ti & Suunto Wing.
            J 1 Reply Last reply Reply Quote 0
            • leafs93L Offline
              leafs93 Bronze Member @juza77
              @juza77 on the contrary, my vertical is always clocking in extra distance , like 300m more for a 10km run. In fact, with the dual band GPS, distance clocked between my vertical and suunto 9 peak and baro is similar. I wear my FR 955 and COROS apex 2 pro together and both of these watches always give me same or similar distance but suunto watches will have extra distance. I am not sure if the distance calculated is all from GPS, or could it also be from some algorithm within suunto software. As far as the run shown on map, it is really spot on for all 3 of my watches, just that vertical will clock in quite a significant extra distance .
              zhang965Z Kurt68K MiniForkliftM 3 Replies Last reply Reply Quote 0
              • zhang965Z Offline
                zhang965 @leafs93
                @leafs93 said in Distance measurement understimated:
                Both fr955 and apex2 use Airoha gps chipset, it’s not surprised me that they have similar performance.
                Winners Wear Winners
                • Kurt68K Offline
                  Kurt68 @leafs93
                  @leafs93 From my tests, I can say that the Suunto Vertical and the Fenix ​​7X almost always have exactly the same distance.
                  • MiniForkliftM Offline
                    MiniForklift Platinum Member @leafs93
                    Same for me, I run with three guys who all use Garmin and my SV always records a little more distance than each of them. With regards to altitude, that’s closer but if there is any difference then it’s their Garmin’s that record a bit more than my Suunto
                    SV Titanium Solar Forest
                    • J Offline
                      juza77 @jjpaz
                      @jjpaz and all, thanks for your replies. I was in the Alps with no possibility of replying to you.
                      I’m using basic Trekking activity (not personalized) with GPS enabled and battery mode on “performance”, so at the best accuracy possible. I noted that SV increases the distance 10 meters by 10 meters, and sometimes it skips to increase the overall distance, not recording one of the 10 meter “milestone”. I also noticed that the distance counter increases if I move my arm on which I wear the watch, simulating the arm movement during a step, but without advancing. So I’m wondering if I’m missing some settings that are impacting the accuracy of the distance measurement, or simply everything’s ok.
                      Many thanks to all for your patience on replying to me (and for my English level too 😊 )
                      • Brad_OlwinB Offline
                        Brad_Olwin Moderator @juza77
                        @juza77 That seems bizarre as arm movements should not affect GPS readings. Are you absolutely sure the GPS is active? The watch will interpret distance by movement if the GPS is not turned on.
                        Vector/T6c/Vertical 2 Ti
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
