    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Connect Vertical to personal hotspot.
    Scheduled Pinned Locked Moved Suunto Vertical
    wifihotspot
    11 Posts 4 Posters 2.1k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • arpoodleA Offline
      arpoodle
      I have unlimited data on my mobile plan so would like to be able to connect my Vertical to my phone’s hotspot for if I want to download a map without wifi.
      As we need to connect the watch to WiFi using the app on my phone, it obviously can’t see its own hotspot as a wifi connection.
      Is there any way to do this?
      Mff73M 1 Reply Last reply Reply Quote 0
      • Mff73M Online
        Mff73 @arpoodle
        @arpoodle
        it should be possible.
        Please check different advises here first (special characters, network frequencies, etc…)
        https://forum.suunto.com/topic/9188/can-t-connect-to-wifi-or-hotspot?_=1690804290777
        SSU (retired), SV1, SV2
        Wife : S9PP
        SA: Always the latest beta :)
        Android + Galaxy S205G
        arpoodleA 1 Reply Last reply Reply Quote 0
        • arpoodleA Offline
          arpoodle @Mff73
          @Mff73 I’ve looked at that, but the phone’s own hotspot doesn’t even show up. It’s a plain text name and a plaintext password. iPhone 12, iOS is up to date and ‘maximise compatibility’ is checked. You can’t change the frequency of the phone’s own hotspot
          Mff73M J 2 Replies Last reply Reply Quote 0
          • Mff73M Online
            Mff73 @arpoodle
            @arpoodle
            Ah, iOS ?
            I just checked with Android, and it is working fine.
            Sorry, can’t help more.
            Wife : S9PP
            • J Offline
              Jugger @arpoodle
              @arpoodle I just tried with Iphone 11 and it worked. On 12 you need to have both wifi and bluetooth on and ”maximise compatibility” switched on to use 2,4 GHz. On 11 it works even without ”maximise compatibility” because it’s using 2,4 GHz native.
              Suunto Vertical Titanium Forest
              Suunto Vertical 2 Titanium Sage
              • arpoodleA Offline
                arpoodle @Jugger
                @Jugger It’s just not showing up in the list of available networks in the Suunto app.
                Screen grab video
                • arpoodleA Offline
                  arpoodle @arpoodle
                  I had to disable personal hot spot.
                  reboot my phone
                  re-enable personal hotspot
                  And then it showed up.
                  Fixed now.
                  J Brad_OlwinB 2 Replies Last reply Reply Quote 1
                  • J Offline
                    Jugger @arpoodle
                    @arpoodle Good that it’s working. Did you connect wireless network through Suunto app? I just went to wireless network settings is SA and hotspot appeared there.
                    • arpoodleA Offline
                      arpoodle @Jugger
                      @Jugger Yes, via the Suunto app. I don’t see another way to add new networks
                      • Brad_OlwinB Offline
                        Brad_Olwin Moderator @arpoodle
                        @arpoodle I find that disable/enable the hotspot will usually work on iOS iPhone 13Pro.
                        Vector/T6c/Vertical 2 Ti
                        • arpoodleA Offline
                          arpoodle @Brad_Olwin
                          @Brad_Olwin Tried that originally. I had to reboot my phone. Works now…
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
