    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Altitude incorrect while hiking
    Scheduled Pinned Locked Moved Suunto Vertical
    45 Posts 14 Posters 9.2k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Łukasz SzmigielŁ Offline
      Łukasz Szmigiel @freeheeler
      @freeheeler cool, didn’t know about it, thanks.
      S9PP 2.50.28
      • Sergei LadeishchikovS Offline
        Sergei Ladeishchikov Bronze Member @Łukasz Szmigiel
        @Łukasz-Szmigiel I did not set the height, the FusedAlti had to set it.
          Sergei Ladeishchikov Bronze Member @babychai
          @babychai All the maps show the same height - 3450 m. Either my FusedAlti was blocked at the beginning of the trip, it was blocked due to and did not work during the trip, or FusedAlti did not work at all. 1/3 of the trip was forest, the rest mountains with open space.
          sartoricS 1 Reply Last reply Reply Quote 0
          • sartoricS Offline
            sartoric Moderator @Sergei Ladeishchikov
            @Sergei-Ladeishchikov
            Was the track ok ? Maybe there was some GPS reception issue
            SVTS - 2.50.28
            SSSWHR BARO Amber - 2.8.32
            Samsung A5 2016 - Android 7.0
            Suunto App Android 6.11.8 beta
            Sergei LadeishchikovS 1 Reply Last reply Reply Quote 0
              Sergei Ladeishchikov Bronze Member @sartoric
              @sartoric Yes, the track was ok, total ascent was correct, too. I compared with this route.
                Dimitrios Kanellopoulos Community Manager
                did you go into water?
                this is a huge difference
                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                Sergei LadeishchikovS 1 Reply Last reply Reply Quote 1
                  Sergei Ladeishchikov Bronze Member @Dimitrios Kanellopoulos
                  @Dimitrios-Kanellopoulos I did not go into the water, and there was no rain.
                  • EgikaE Offline
                    Egika Platinum Member @Sergei Ladeishchikov
                    @Sergei-Ladeishchikov I understand the other device was showing even lower altitude? That means with even bigger error?
                    Maybe this is a mapping problem and the actual GPS altitude is lower than on the sign post?
                      Sergei Ladeishchikov Bronze Member @Egika
                      @Egika another device (garmin) showed 3425 m. There were several peaks on my route, and everywhere there was a rather large difference down.
                      • EgikaE Offline
                        @Sergei-Ladeishchikov I am with one of the first replies: Let’s find out, if this was a one-time glitch out of whatever reason or if it persists.
                        What we can confirm is, tha FusedAlti is supposed to work also in Endurance or Custom battery modes.
                          How often does Alti need to calibrate altitude? at the start of the activity? during activity?
                          • EgikaE Offline
                            @Sergei-Ladeishchikov as stated before: It tries to calibrate during the beginning of the activity. It usually takes 12-15mins which will then correct the recorded altitude backwards from the start.
                            Right now I am not sure if the watch will try again if it fails after the first 15min…
                            Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                              Łukasz Szmigiel @Egika
                              @Egika what about sudden pressure drop due to storm happening i.e. 1+ hours after the start of activity? Won’t FusedAlti try to correct it after the initial calibration?
                              S9PP 2.50.28
                              isaziI 1 Reply Last reply Reply Quote 1
                              • isaziI Offline
                                isazi Moderator @Łukasz Szmigiel
                                @Łukasz-Szmigiel fusedalti works during the whole activity.
                                Blog: isazi's home
                                Sergei LadeishchikovS 1 Reply Last reply Reply Quote 2
                                  Sergei Ladeishchikov Bronze Member @isazi
                                  @isazi what can block the work of FusedAlti? or could it be a glitch? Does it make sense in such a case to send logs to check the work of FusedAlti?
                                  isaziI 1 Reply Last reply Reply Quote 0
                                  • isaziI Offline
                                    isazi Moderator @Sergei Ladeishchikov
                                    @Sergei-Ladeishchikov not sure, maybe related to you using good and then switching to best GPS mode. Logs make sense if you can send them after the activity, it may be too late now.
                                    Blog: isazi's home
                                      @isazi well, when i go camping, i will deliberately not calibrate the height myself, let the alti work.
                                      isaziI Mff73M 2 Replies Last reply Reply Quote 0
                                      • isaziI Offline
                                        @Sergei-Ladeishchikov I never use manual calibration, and my Vertical is usually very precise, or at most 5-6 meters different from the “real” altitude.
                                        Blog: isazi's home
                                        • Mff73M Offline
                                          Mff73 @Sergei Ladeishchikov
                                          Do you have an Android phone?
                                          If yes, you may have a look at the raw data file of this activity and check GPS altitude registered vs fusedalti corrected one.
                                          If yes, I will search for posts which explains how to do (too old now 😁)
                                          SSU (retired), SV1, SV2
                                          Wife : S9PP
                                          SA: Always the latest beta :)
                                          Android + Galaxy S205G
                                            Sergei Ladeishchikov Bronze Member @Mff73
                                            @Mff73 that’s interesting, never heard of it! Yes, I have an android. What should I do for analysis?
                                            EgikaE Mff73M 2 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
