    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Altitude incorrect while hiking
    Scheduled Pinned Locked Moved Suunto Vertical
    45 Posts 14 Posters 9.0k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Sergei LadeishchikovS Offline
      Sergei Ladeishchikov Bronze Member
      Hello! Today I went hiking in the mountains with my SV. I went through several peaks and the height on the SV did not match any of the heights of the peaks. SV has always shown a lower height with a difference of 60-80 meters. In the beginning, I used custom battery mode with good GPS accuracy. After I switched to performance, but nothing has changed. at its highest peak, SV was 75 meters short. Nearby was a man with a Garmin Fenix, and his height was 25 meters less than the peak. The weather was cloudless, no trees or anything like that. Tell me, is this normal or is there any problem? In the last campaign, I also noticed a difference in a smaller direction, but not so big.
      WhatsApp Image 2023-07-16 at 21.29.01.jpeg WhatsApp Image 2023-07-16 at 21.29.00.jpeg
      GiPFELKiNDG freeheelerF Łukasz SzmigielŁ 3 Replies Last reply Reply Quote 1
      • GiPFELKiNDG Offline
        GiPFELKiND Silver Members @Sergei Ladeishchikov
        @Sergei-Ladeishchikov 60 to 80m incorrect altitude is very much if i in the mountains. Sounds not good. Do you reset before start your trip on a known altitude correctly?
        If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
        Sergei LadeishchikovS 1 Reply Last reply Reply Quote 0
          Sergei Ladeishchikov Bronze Member @GiPFELKiND
          @GiPFELKiND I don’t reset or tweak anything at all, I let it work FusedAlti
          • freeheelerF Offline
            freeheeler @Sergei Ladeishchikov
            please observe your next hike if it happens again.
            normally FusedAlti detects when the altitude is wrong and corrects it.
            I’ve had a similar issue on a 1h run recently, when the watch showed 60m below actual altitude throughout the entire activity. once only, didn’t happen again.
            please let us know in case you observe it again
            living sideways
              I also noticed that for 10 hours of activity with an external heart rate sensor and without using S+, the watch took about 20-22% of the charge.
              freeheelerF 1 Reply Last reply Reply Quote 0
                that’s roughly 2%/h and ok-ish with external HR, IMO.
                internal OHR is more efficient than external.
                living sideways
                  Sergei Ladeishchikov Bronze Member @freeheeler
                  @freeheeler I also noticed that the total climb is the same as the route. Could it be that FusedAlti did not work in custom battery mode?
                    @freeheeler Is 2% a lot? I always do activities with an external heart rate sensor (Polar H10).
                      did you use maps, too?
                      2% is about to expect with external HR, but in case of maps being in use definitely it is realistic.
                      hmm, I am not aware of any setting that would deactivate FusedAlti. but for example a trail covered with trees could make it difficult for FusedAlti to measure correctly.
                      living sideways
                      Sergei LadeishchikovS 2 Replies Last reply Reply Quote 0
                        @freeheeler I did not use the map so often, I already knew where to go. At the beginning of the hike there were quite a lot of trees. So, if FusedAlti couldn’t make an altitude adjustment in the first 15 minutes, then he doesn’t do it anymore?
                          @freeheeler Thick trees started from the 7th minute of the hike.
                            normally it does the correction within 15min, but as I understand should check throughout the activity if something changes again, e.g. pressure drop due to bad weather
                            living sideways
                              @freeheeler Should I or the SV check altitude throughout the activity? Doesn’t SV know GPS altitude, especially in dual-band GPS/GNSS?
                              • Mitch9M Offline
                                Mitch9 Silver Members
                                For me the height accuracy of the SV is really great in the mountains. Mostly within 10 m for peaks which is amazing for such a device. Sometimes I calibrate the height (when the situation is right for it) but not always.
                                Watch: Suunto Vertical Titanium Solar (Sand)
                                SA: Android (beta)
                                HRS: Polar H10
                                • babychaiB Online
                                  babychai Silver Members
                                  the accuracy sometimes depend on the location. some mountains my SV show higher and some mountains show lower altitude at the peak. so far within 20 meter range.
                                  maybe the altitude shown on signboard at the peak doesn’t accurate as well. you can double check on the TOPO map.
                                  Suunto Vertical Titanium Solar Black
                                  S̶u̶u̶n̶t̶o̶ ̶V̶e̶r̶t̶i̶c̶a̶l̶ ̶B̶l̶a̶c̶k̶ ̶R̶u̶b̶y̶ ̶(̶S̶/̶S̶)̶
                                  S̶u̶u̶n̶t̶o̶ ̶V̶e̶r̶t̶i̶c̶a̶l̶ ̶A̶l̶l̶ ̶B̶l̶a̶c̶k̶
                                  Suunto 9 Peak All Black
                                  Suunto Spartan Trainer Wrist HR (Black)
                                  gone troppoG Sergei LadeishchikovS 2 Replies Last reply Reply Quote 1
                                  • gone troppoG Offline
                                    gone troppo Bronze Member @babychai
                                    My sv altitude is always very close on 1000+m mountains usually within 10m. I don’t calibrate it or anything before starting I just let it run
                                    • Łukasz SzmigielŁ Offline
                                      Łukasz Szmigiel @Sergei Ladeishchikov
                                      @Sergei-Ladeishchikov did you manually set elevation prior to the hike?
                                      S9PP 2.50.28
                                      freeheelerF Sergei LadeishchikovS 2 Replies Last reply Reply Quote 0
                                        freeheeler @Łukasz Szmigiel
                                        @Łukasz-Szmigiel
                                        that’s not necessary but doesn’t effect either
                                        living sideways
                                        Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                                          Łukasz Szmigiel @freeheeler
                                          @freeheeler I’ve read somewhere around the forum that if you set elevation manually prior to the workout it can disable fused alti for some time.
                                          S9PP 2.50.28
                                          freeheelerF 1 Reply Last reply Reply Quote 1
                                            @Łukasz-Szmigiel
                                            yes that was true until a date we can not tell anymore because it’s unknown 😉
                                            I did a test recently and it was confirmed by others. you can do what you want and when you want with manual calibration, FusedAlti will correct it anyway if necessary 👍
                                            living sideways
                                            Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 2
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
