    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Backlight
    Scheduled Pinned Locked Moved Suunto Vertical
    30 Posts 11 Posters 3.9k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Dusan DDDD Offline
      Dusan DDD
      Hi,
      I have opportunity to buy a second hand SV, what I noticed is a kind of uneven back light, small cloud formation noticable on white background, mainly next to the lower button. Nothing strange visible, when back light is off. Do you have even baklight, or would consider this as normal on SV? Thanks
      Now with pictures 🙂
      Dusan DDDD 2 Replies Last reply Reply Quote 0
        Dusan DDD @Dusan DDD
        @Dusan-DDD
        How to upload picture from mobile phone here?
        freeheelerF 1 Reply Last reply Reply Quote 0
        • freeheelerF Offline
          freeheeler @Dusan DDD
          @Dusan-DDD
          living sideways
          Dusan DDDD 1 Reply Last reply Reply Quote 0
            Dusan DDD @freeheeler
            @freeheeler
            Thanks, but does not work, when I push the button, it makes puts following text ![alt text](image url)
            inkognitoI 1 Reply Last reply Reply Quote 0
            • inkognitoI Offline
              inkognito Platinum Member @Dusan DDD
              @Dusan-DDD You’re pushing different button. There are more icons to the right, you have to swipe to see them on mobile phone.
              SV: fingers crossed :D
              S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
              Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
              Despite some pretty bad luck, I still love Suunto!
              Dusan DDDD 1 Reply Last reply Reply Quote 1
                Dusan DDD @inkognito
                @inkognito
                Thanks
                  @Dusan-DDD
                  Hi, any feedback please? Would you consider this type of uneven backlight as normal? The spot bothers me a little bit…especially on watch face, but otherwise consider I the watch to be pretty OK.
                  freeheelerF ? 2 Replies Last reply Reply Quote 0
                    @Dusan-DDD
                    we’ve had this topic with S9PP and I recall @Dimitrios-Kanellopoulos commenting it is something called light-leaks or backlight bleeding. it’s neither a fault nor harmful and shouldn’t get worse.
                    https://www.samsung.com/ph/support/mobile-devices/backlight-bleeding/#:~:text=Backlight bleeding is an effect,most devices at some point.
                    living sideways
                    • ? Offline
                      A Former User @Dusan DDD
                      @Dusan-DDD If it bothers you, you might want to consider contacting support. They might send you a replacement watch.
                        freeheeler @Guest
                        @Ilya-Sul
                        yes, they might do that.
                        but from my personal sustainability point of view, I would recommend not to do so.
                        a potential replacement watch might be better, it might be worse as well, when I read the samsung comment.
                        in any case, carbon footprint will increase
                        living sideways
                        GiPFELKiNDG 1 Reply Last reply Reply Quote 0
                        • GiPFELKiNDG Online
                          GiPFELKiND Silver Members @freeheeler
                          @freeheeler @Dusan-DDD @Ilya-Sul why you post a Samsung link? It is a suunto product question. Why dont suunto make a Statement for the Display light “Problem”? The carbon Footprint is not so important, if the user is not happy with the shown on his Display. And this should not be on a 800€ watch. Can understand the user sending back to get a new one. And sure it could be that the new one is more bad, that spokes then agains suunto if this happens more times again. But otherwise there is an Option that the new one is much better, the thing is the user should be happy with this cheap product. And when the Display is not correct or had bad looking --> sent it back so Long that he got a perfekt watch!
                          If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
                          freeheelerF 2 Replies Last reply Reply Quote -1
                            freeheeler @GiPFELKiND
                            @GiPFELKiND
                            well… I think I can not add anymore value here 🙂
                            the samsung link is just an example with a technical explanation that is generally valid for any screen with this technology
                            living sideways
                            GiPFELKiNDG S 2 Replies Last reply Reply Quote 2
                              @GiPFELKiND
                              I do have a general question anyway:
                              my Pixel phone has a punch hole camera in the screen and the lens itself isn’t 100% concentric inside the screen’s punch hole… is this worth a refund?
                              and my business laptop has 1 dead pixel, I see it frequently but it’s not hindering me from doing my work properly… is this worth a refund?
                              both, economically and ecologically…
                              living sideways
                              GiPFELKiNDG 1 Reply Last reply Reply Quote 3
                                @freeheeler okay 👍👍👍👍
                                  @freeheeler you are right 👋👋
                                  freeheelerF 1 Reply Last reply Reply Quote 1
                                    @GiPFELKiND
                                    don’t get me wrong, I’m aiming for high quality when it’s possible, always. but in some cases it’s too much and I ignore my inner urge to have it perfect.
                                    I have several examples, personally… but I take them as a chance to overcome my slightly autism-ish tendencies 🙊
                                    living sideways
                                      @freeheeler hey @freeheeler sorry Back trip fromm croatia to Braunschweig the last days 👋 your thinking is well 👍and yes perhaps i have to reduce some autism 😜
                                      • S Offline
                                        Schoda
                                        Hello. I’m completely new to Suunto and come from Garmin. Immediately after unpacking the vertical I noticed that the backlight was very uneven. is that normal? I have a halo at the bottom right of the display.!
                                        • Brad_OlwinB Offline
                                          Brad_Olwin Moderator @Schoda
                                          @Schoda Photos would help.
                                          Vector/T6c/Vertical 2 Ti
                                          S 1 Reply Last reply Reply Quote 0
                                          • S Offline
                                            Schoda @Brad_Olwin
                                            @Brad_Olwin
                                            Thank you for your answer.
                                            I dont know how to use the photo function.
                                            I Hope it IS allowedcto create a Google photo Link.
                                            https://photos.app.goo.gl/gypjahqxpijS2a1i6
                                            sartoricS 1 Reply Last reply Reply Quote 0
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
