    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Batteries replacement
    Scheduled Pinned Locked Moved Spartan
    5 Posts 4 Posters 2.9k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • B Offline
      Bluedragon38
      Hello.
      I wanted to know where to have a new batteries for my SPARTAN.
      Parts number is 352828.
      If someone knows where to have it (i will obviously buy from aliexpress if there is no place like amazon to have it . because its obviously produce there… )
      Ps : and answer like
      “Only Suunto service can replace the battery. The watches are not intended to be opened by consumers. You are likely to affect the water resistance.”
      Please , its a basic SEAL who protect the inside from water 🙂
      Thanks in advance 🙂
      H sartoricS I 3 Replies Last reply Reply Quote 0
      • H Offline
        halajos Bronze Member @Bluedragon38
        @Bluedragon38 try searching at fccid.io for the FCC ID on the back of your watch and you may find a photo of the battery. Not sure if the battery vendor’s part number can be identified though…
        B 1 Reply Last reply Reply Quote 0
        • sartoricS Offline
          sartoric Moderator @Bluedragon38
          This post is deleted!
          • B Offline
            Bluedragon38 @halajos
            @halajos Thanks i will give it a try 🙂
            edit : i’ve got this page : https://fccid.io/RYP24601
            • I Offline
              ierisch Bronze Member @Bluedragon38
              @Bluedragon38 352828 means lwh 35mm x 28mm x 2.8mm, as for connector, maybe you can remove the kapton tape that protects the battery and the bms, put it back and you’re done. I’ve done this with my trainer outdoor once year ago
              Register Login
              • First post
                Last post
              Suunto Terms | Privacy Policy
