    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    HotFix release 2.25.66
    Scheduled Pinned Locked Moved Suunto Vertical
    78 Posts 31 Posters 20.3k Views 32 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • sartoricS Offline
      sartoric Moderator @unocz
      @unocz
      In fact, if you keep your watch always under water there is no way for the GPS signal to reach it.
      SVTS - 2.50.28
      SSSWHR BARO Amber - 2.8.32
      Samsung A5 2016 - Android 7.0
      Suunto App Android 6.11.12 beta
      unoczU 1 Reply Last reply Reply Quote 2
      • unoczU Offline
        unocz @sartoric
        @sartoric
        Wow, ok so I have to deal with that….
        Thanks anyway😊
        freeheelerF 1 Reply Last reply Reply Quote 0
        • freeheelerF Offline
          freeheeler @unocz
          @unocz
          yes, but that’s the same for every watch.
          satellite signals do not enter the water at all. no chance to calculate your position when the watch is submerged only a tiny little bit
          living sideways
          unoczU 1 Reply Last reply Reply Quote 1
          • unoczU Offline
            unocz @freeheeler
            @freeheeler
            Yes I just realised that 😕
              freeheeler @unocz
              @unocz
              what you could do, if you prefer breaststroke, get an inflatable safety buoy with a small wallet compartment and put the watch in there. of course you need external HR and stroke will not be counted, but distance will be correct. downside: you can’t see your time and distance during the activity.
              alternatively put the phone in there and track with SA?
              living sideways
              • lexterm77L Offline
                lexterm77 Bronze Member
                I got another crash, Had battery performance, target distance, heart rate z1, S+ weather insights and active look, breadcrumb nav, it crashed exactly before target 50% notification. This also happened before right at 50% of target set last time.
                • L Offline
                  Luis Andés Olmedo Bronze Member
                  This weekend, while navigating an MTB route with my SV, the watch reset iself to “clock mode”. I had to initiate MTB activity again… I have two records in the app, one with the first part of my workout and another one with the second part.
                  Is this a known issue?
                  Thank you.
                  markeczzzM 1 Reply Last reply Reply Quote 0
                  • markeczzzM Offline
                    markeczzz @Luis Andés Olmedo
                    Same thing happened to me today.
                    I went for a run, and after 900m Vertical exited to watch screen and i had to start activity again.
                    I had Aerobic Decoupling and Ghost Runner turned on and everything else default for Running (Basic).
                      I can’t reproduce any of my previous crashes. I try same route and settings.
                      • Antoine LancrenonA Offline
                        Antoine Lancrenon Bronze Member
                        Small bug I noticed. I am using quite a lot the flashlight during the night when reading the last story to my daughter, having a deem light like the watch is perfect to create the sleeping atmosphere I am looking for .
                        I have set my watch to get very few notifications, and if I receive one during the flashlight, it makes the light power going down, like I was in watch mode. And I have to reset the flashlight again to get the flashlight potential light.
                        It repeats after each notification
                        It is not much, put yeah, I think it is worth mentioning… May be it is the willing behavior?
                        mikekoski490M 1 Reply Last reply Reply Quote 0
                        • mikekoski490M Offline
                          mikekoski490 Bronze Member @Antoine Lancrenon
                          @Antoine-Lancrenon You could try turning off ‘Recieve Mobile Notifications’ before you do your nighttime routine, that way avoiding the notifications.
                          Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
                          Current: Suunto Race Ti
                          Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
                          Suunto App running on Google Pixel 8/Android 14
                          Antoine LancrenonA 1 Reply Last reply Reply Quote 0
                            Antoine Lancrenon Bronze Member @mikekoski490
                            @mikekoski490 Yes true. But it doesn’t bother me receiving a notification, as I said I only receive the most critical one… I would rather a quick fix… The work around is easy to do 🙂
                            • L Offline
                              Likarnik Gold Members
                              How are losing bluetooth connections handled? Last weekend I went on a bike ride and had watch on handlebars. While on pause I went out of BT range (I guess), because I got – after resuming ride. After 15mins belt connected and showed HR for the rest of activity. Is that normal? I am using H10. Please do not recommend Suunto HR belt as it does not meet my requirements. I just got a powermeter and it goes off after 5min (it can be changed) of inactivity. Is this going to be the same? I tried yesterday with a dummy activity and after 10min of pause (powermeter was off) resume resulted in watch reboot. Second test went ok, powermeter woke up and watch received watts. Should this work or am I going to be anxious on every ride?
                                markeczzz @markeczzz
                                @markeczzz said in HotFix release 2.25.66:
                                Same thing again.
                                Weird thing is, it crashed almost same like last time. It crashed after 900m, on exactly same route, with same s+ apps running.
                                No crashes between this 2 activities, and there were like 30 activities between, some on same route.
                                  I got my first real crash since June.
                                  I went for a run with a route, with interval and forth months I decide to set up a Suunto app last km/mile…
                                  And it crashed/reboot the whatch.while being in activities…
                                  From my point of view, even if the Suunto app are great ideas , it seems to create a lot of instability… Between battery drainage and crash. I will stop using Suunto app, I am very happy with core feature.
                                  Also, most of the Suunto app were built for baro 9 or peak version… Most probably not optimized to work fully with vertical. It is just a theory.
                                  Is the next update willl give more stability with Suunto app?
                                  I love my Vertical, my real running/adventure friend hahaha
                                  Mff73M 1 Reply Last reply Reply Quote 2
                                  • Mff73M Offline
                                    Mff73 @Antoine Lancrenon
                                    @Antoine-Lancrenon
                                    Agree with you, SV is amazing companion.
                                    I add two crashes, and never talk too much about them (why)
                                    Not happy, when happened, noticed the reboot quickly, but after all, life is still nice.
                                    OK, i thought about something : crash is not nice, must not happen, but … If only the watch could buzz and ring when rebooted, it could enable at least to notice quickly that something happen and react (if not in a hurry race 🙂 ).
                                    SSU (retired), SV1, SV2
                                    Wife : S9PP
                                    SA: Always the latest beta :)
                                    Android + Galaxy S205G
                                    J 1 Reply Last reply Reply Quote 5
                                    • Andrew_A Offline
                                      Andrew_
                                      Deleted Comment
                                      • Suunto Vertical Steel, All Black
                                      • Suunto Wing, Lava Red
                                      • J Offline
                                        jussim Bronze Member @Mff73
                                        @Mff73 said in HotFix release 2.25.66:
                                        if only the watch could buzz and ring when rebooted, it could enable at least to notice quickly that something happen and react (if not in a hurry race 🙂 ).
                                        I was thinking the exact same thing! Where should this suggestion go so that the folks at Suunto would see it and maybe implement it in the upcoming year or two?
                                        9PP since 09-2025.
                                        • isaziI isazi unpinned this topic on
                                        Register Login
                                        • First post
                                          Last post
                                        Suunto Terms | Privacy Policy
