    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Solar Symbol in the Watchface
    Scheduled Pinned Locked Moved Suunto Vertical
    11 Posts 5 Posters 1.4k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • SuperFlo75S Online
      SuperFlo75 Silver Members Bronze Member
      My watch did the update to the hotfix, as I charged yesterday evening and loaded some Maps. Today I noticed a different, crazy behavior of the round solar symbol upper right in the watch face. I go into bright sunshine, and in the symbol, I only see the flash sign in the middle… when I push any button, the symbol shows the correct status of the charging… this could be a bug?
      Suunto Vertical 2 Titanium Sage
      Suunto Vertical Titanium Forest/Dark Ruby/UTMB/Courtney_Edition
      Suunto Wing
      Suunto 9 Peak Pro Titanium (owns my wife now)
      Suunto Spartan Ultra
      SA iOS 3.7.2 (21451)
      Instagram @superflo75
      sartoricS mikekoski490M 2 Replies Last reply Reply Quote 1
      • sartoricS Offline
        sartoric Moderator @SuperFlo75
        @SuperFlo75 said in Solar Symbol in the Watchface:
        What do you mean ?
        Isn’t the picture correct ?
        You’re also fully charged, so solar should (afair) stop charging
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.7.12 beta
        SuperFlo75S 1 Reply Last reply Reply Quote 0
          SuperFlo75 Silver Members Bronze Member @sartoric
          @sartoric The picture was taken after activating the screen, you can see the seconds… the correct solar symbol appears after pressing a button… before there is only the flash in the middle…
          Suunto Wing
            Today, I tried it again… it‘s different than before the update…
            I hope you can see…
            This is directly after going in the sun
            This is only after pushing the middle button and activating the watch face, without changing the place of the watch…
            Last week, before the update, the solar symbol was actual without pressing any button…
            Can somebody explain this?
            Suunto Wing
            E surfboomerangS sartoricS 3 Replies Last reply Reply Quote 1
            • E Offline
              el2thek Bronze Member @SuperFlo75
              @SuperFlo75 would that not be the desired behaviour so the screen is not constantly refreshing?
              • surfboomerangS Online
                surfboomerang @SuperFlo75
                @SuperFlo75 I do notice updates of the solar ring and graph bars sometimes when unlocking the watch but I also remember having read that the watch isn’t charging on solar as long as it has more then 95%. No idea if this is the case for you right now.
                I’m at 81% and the solar rings on my watch react almost instantly.
                Suunto Vertical Titanium Solar
                OnePlus Nord 4
                • sartoricS Offline
                  @SuperFlo75
                  Is it the same if you are in a dark environment ?
                  I mean, it is for sure some way to avoid useless battery consumption, but I’m wondering if the flash in dark environment is green, that to me means something like “the sun light is ok for recharging”
                  SVTS - 2.50.28
                  • mikekoski490M Offline
                    mikekoski490 Bronze Member @SuperFlo75
                    @SuperFlo75 I didn’t notice this before the hotfix so can’t comment on that, but…would it not make sense that if the screen was ‘locked’ that the solar icon would not update until you press a button and activate the screen dynamic? Same with seconds…they dont show/change unless a button press is made. I assume this is a battery save thing?
                    Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
                    Current: Suunto Race Ti
                    Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
                    Suunto App running on Google Pixel 8/Android 14
                    sartoricS 1 Reply Last reply Reply Quote 0
                    • sartoricS Offline
                      sartoric Moderator @mikekoski490
                      @mikekoski490 said in Solar Symbol in the Watchface:
                      yep, but then wouldn’t you argue that the watch is not charging even if it showing a good sun “strength” (and maybe it’s actually not charging due to weak sun light) ?
                      SVTS - 2.50.28
                        Hey guys, I think the problem is solved! As the battery reached 95% this afternoon, the behaivior is like before… when I‘m in the sunlight, I can see the charging circle… there might be another behavior over 95%? But I was confused because in the second day being a Vertical owner, I loaded the watch from 97% up to 100% in 1 hour in the sun… at this time, the behavior was different. Perhaps the effect of calibrating the battery? I wish you a nice and sunny weekend!!! 😎🌞
                        Suunto Wing
                          @sartoric In dark light, the Flash in the middle of the circle is black
                          Suunto Wing
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
