HotFix release 2.25.64
Sun icon for night weather forecast in weather widget was not corrected.
Had some spike this morning on a run. I thought I did not wait for green GPS icon, but there is also a spike in power
Easy steady run… or is it that pace is also a v variable for calculating power?
@Likarnik said in HotFix release 2.25.64:
Wrist power is calculated by speed
I still receive notification randomly on my watch from iphone. Should it work or should I wait for fix?
I didn’t see it in the release notes, but is the issue resolved regarding the excessive battery use when you use one or more S+ apps?
@surfboomerang no. Using S+ apps will use more battery.
@isazi said in HotFix release 2.25.64:
Sorry for the off topic, and not sure you can answer this: what is the reason/advantage to still have s+ on devices like the vertical? Wouldn’t be better to have it on the firmware ?
I understand for low resources devices such as the s9b, but the rest… -
@André-Faria that you don’t need to wait for firmware updates. Partners can write apps and deploy them instantly on all watches, and update them as often as they want.
Version 2.25.66 currently downloading on SuuntoApp. Did I miss a post on the forum ?
What’s new ? In relation with Suunto’s Strava segment announcement from today ?On Suunto website, it is mentionned only about openwater swim accuracy improvement
Thank you for taking the time to explain it. Clear for me
@v-sacre said in HotFix release 2.25.64:
Yes, and this is what it is about: improvement for OWS
I isazi unpinned this topic on
With your input, this post could be even better đź’—
Register Login
