    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Vertical battery modes
    Scheduled Pinned Locked Moved Suunto Vertical
    55 Posts 19 Posters 12.3k Views 21 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Brad_OlwinB Offline
      Brad_Olwin Moderator @MKPotts
      @MKPotts I am going to send you a PM in chat.
      Vector/T6c/Vertical 2 Ti
      • D Offline
        dzembronja @isazi
        @isazi Hello, after the last update or not, I do not know what this is due to the vertical clock, I can not change the default mode to Performance in all sports, please tell me how to do it
        • D Offline
          dzembronja @isazi
          @isazi I started the activity in a different mode, nothing helps, are these update errors? For some reason, I have all the user mode, I can’t change to Performance mode
          • S Offline
            sneike
            Hi, thank you all so much because this is the only resource I could find trying to clarify about GPS accuracy and navigation in Suunto watches, whereas the user manual, faqs and support pages are all contradictory.
            So, to recap, can you confirm that with Vertical1/Vertical2/Race2 and other watches of the family, you can use the navigation even when in Endurance or Ultra mode? It will only switch to GPS accuracy “best” while the map screen is open, or if you have an ETA data field open?
            So according to this, if you are navigating a route but you leave the screen on regular data fields, you could expect the battery life of Endurance or Ultra mode, right? In this case, does the watch notify the approaching of a turn in the navigation? Or if you’re going off track?
            Thanks for your help
            S Brad_OlwinB 2 Replies Last reply Reply Quote 0
            • S Offline
              sneike @sneike
              After a lot of thinking I finally decided to get a brand new Race 2, and I just found out:
              1. There is no custom battery mode!
              2. There is no way to use the map and navigation feature unless you are on performance mode
              This is so disappointing. And it is so frustrating not being able to find clear information about this online. Ive been spamming forums and groups trying to understand, but I still didn’t get the full picture. Considering if I have to return the watch. And get a Vertical instead? Still looking for confirmation if map navigation can be used with another battery mode that’s not performance though.
              VoiGASV sky-runnerS 2 Replies Last reply Reply Quote 0
              • VoiGASV Offline
                VoiGAS Gold Members @sneike
                @sneike as far as I know this is how all current Suunto Watches behave. So you will have the same issues with the Vertical
                Race S
                Vertical Titanium Solar
                Ambit3 Vertical
                  Brad_Olwin Moderator @sneike
                  @sneike The only watch that lets you use maps in Custom mode is the Vertical. Using maps in Endurance or Ultra on AMOLED watches won’t give you much better battery life than Performance mode. On the upside, charging with the newest watches is very fast.
                  sky-runnerS S 2 Replies Last reply Reply Quote 1
                  • sky-runnerS Offline
                    sky-runner Platinum Member @sneike
                    @sneike Unless you run 200+ mile ultramarathons, Race 2 or Vertical 2 battery life in performance mode should be more than sufficient. With Race 1 I’ve never used other performance modes and going forward I don’t think I’d ever use a battery mode other than Performance, at least not unless I forget to recharge the watch before a multi-hour run and the watch battery is almost empty.
                    But I agree that not allowing the map in other battery modes is an odd limitation. Is there a real technical reason for that?
                    What is your use case?
                    Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
                    Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
                      sky-runner Platinum Member @Brad_Olwin
                      @Brad_Olwin said in Suunto Vertical battery modes:
                      Let’s consider the following case - someone does an activity like thru hiking. They want to occasionally use the map, perhaps 5% of the time, and look at a different data screen 95% of the time. So 95% of the time they would still take advantage of battery saving in a more economical battery mode. Why not allow users a choice?
                      This limitation seems odd to me. I don’t see why there would be a technical reason other than perhaps not being able to fulfill the specified battery life claims.
                      Brad_OlwinB 1 Reply Last reply Reply Quote 2
                      • S Offline
                        sneike @Brad_Olwin
                        There are contradictory information online, are we 100% sure of this?
                        @sky-runner said in Suunto Vertical battery modes:
                        That’s exactly my use case, thru hikes and/or long term bikepacking in remote places. In the latter case I would have the watch on the handlebar and eventually check the map only approaching turns.
                          Brad_Olwin Moderator @sky-runner
                          The problem is that the map is still using energy even if you are not on the map screen. I’ve tested this and with a friend who tests for Suunto as well we verified this for AMOLED watches. We reported our tests and I do not know whether this is a firmware limitation or not. I do know that using maps will likely erode any benefit obtained in Endurance or Ultra modes.
                          sky-runnerS 1 Reply Last reply Reply Quote 1
                            @sneike said in Suunto Vertical battery modes:
                            Which watches would you like me to test. I have race, race 2, race S, vertical ocean and vertical 2. The only one I can enable maps in a custom battery mode is the vertical.
                              That seems strange to me. I’m sure there is a reason for that, perhaps some sort of prefetching of map data into memory to avoid any delay in case if the data screen is switched to the map. But perhaps that could be done more intelligently. I understand that loading from the flash memory is relatively slow. But again if user expectations are right, perhaps users could acknowledge that there will be more lag and enable the map in non-performance mode.
                              • S Offline
                                sneike @Brad_Olwin
                                Thank you for clarifying that. Do you also confirm that if we start an activity with a custom battery mode and set the GPS accuracy to OK, we can expect the battery life of the Ultra mode as long we don’t keep the map (or the ETA data fields) on the screen all the time?
                                  I think if you run maps at all it will impact battery life in Ultra mode. If you save the mode for a specific custom sport profile the battery estimate shown on the watch should be reasonable. I assume you need battery to last 280h?? I used my V1Solar for a fast pack trip in August that was 4d with sleep tracking, OHR, etc enabled and about 12h of GPS per day. My battery estimates in Performance mode ranged from 62h to 90h. I did not charge the watch and had 38% left by the end of the trip. I use Performance unless I need the extra battery and then would use Endurance. Unlikely for me I would need 280h of continuous tracking.
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
