    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Ressources in Vertical /how does it works?
    Scheduled Pinned Locked Moved Suunto Vertical
    47 Posts 15 Posters 7.7k Views 16 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User @SuperFlo75
      @SuperFlo75 Yeah, the common “workaround” is to set a higher RHR than you actually have. The problem is that that probably affects various other metrics.
      • S Offline
        Sascha Domres Bronze Member @freeheeler
        @freeheeler the support said that it takes a long time for the watch to ‘learn’… it’s important to wear the watch 24/7 for a long time… but I don’t know more details… I’ll stick with the HR minimum AVG settings for now. .
        GiPFELKiNDG 1 Reply Last reply Reply Quote 0
        • GiPFELKiNDG Offline
          GiPFELKiND Silver Members @Sascha Domres
          @Sascha-Domres said in Ressources in Vertical /how does it works?:
          I have the following settings: the minimal HF is not the rest HF. Trying to explain: the minimal HF in night is the HF beats per minutes in totally chilling. The rest HF you can make a measurement in daytime, sit down 5 minutes and rest. Then make HF measurement. Thats your Rest HR. In daytime you will never get your night minimal HF. so you must set the day rest HF. mine minimal at night is between 46-50. I have set my day Rest HF to 70. So i get really good stress and Ressourcen goals. Try it! Frome the medical physician the minimal HF at night can never be the same as the rest HF.
          If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android Insta: @gipfelkind
          gone troppoG freeheelerF 2 Replies Last reply Reply Quote 1
          • gone troppoG Offline
            gone troppo Bronze Member @GiPFELKiND
            Like zhang965 posted above I use the absolute minimum hr that I have seen at night as my resting hr which was 38 for me as per the suunto website? I read that as the minimum achieved not the average am I wrong?
            • freeheelerF Offline
              freeheeler @GiPFELKiND
              @GiPFELKiND
              @gone-troppo
              I’ve discussed this topic with other, more experienced people.
              I was convinced that RHR was gipfelkind’s suggestion: daily inactivity HR, which is basically nightly avg HR +10 (as a rule of thumb… maybe elbow…)
              others have had good results with setting exactly 7 nights avg lowest HR as RHR, as it says in the manual.
              I’ve again set it to this and will observe now for a longer period than 3-4 hours
              living sideways
              • L Offline
                Likarnik Gold Members
                For me, resources in Vertical are not working like in S9P. Not sure which one is right, but I have higher resources with Vertical. I did not get below 9% on Vertical after a 100+km trail race which left me shattered. Next day I was back above 40%. On S9P I was at 0%, next day barely any positive numbers 😄 - same race 1 year apart. Same was with other races or very hard/long training runs/rides. I think S9P managed resources better. Settings were the same.
                • Jamie BGJ Offline
                  Jamie BG Bronze Member @zhang965
                  @zhang965
                  That is because I believe this is all based off or is still using the first beat algorithms - and for Garmin’s this is how it works - off your min sleeping HR- which Garmin refers to as you RHR.
                  Register Login
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
