    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Strava Live Segments
    Scheduled Pinned Locked Moved Suunto Vertical
    stravalive segmentsnavigation
    38 Posts 14 Posters 9.6k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • isaziI Offline
      isazi Moderator @lauser
      @trailcafe I don’t have Strava premium so cannot test.
      Blog: isazi's home
      • isaziI Offline
        @trailcafe said in Strava Live Segments:
        @isazi I unstarred all my segments, refreshed S+ apps forth and back, starred segments, refreshed S+ apps again but no Strava Segements S+ app appears in the Suunto App S+ App section
        You mean the S+ guides section right, not the app? Segments are implemented as guides, not apps, so you cannot find them there.
        Blog: isazi's home
        L 1 Reply Last reply Reply Quote 0
        • L Offline
          lauser Bronze Member @isazi
          @isazi oh ok, my fault. Thank you.
          • M Offline
            Mi_chael Bronze Member
            @isazi
            After I followed all your advice, i can’t add Strava Live Segment in my Suunto Guide’s.
            I can’t understand what is the problem.
            Are you sure SLS is back to all ?
            isaziI 1 Reply Last reply Reply Quote 0
            • v.sacreV Offline
              v.sacre Silver Members @isazi
              @isazi it worked properly for Cycling segments but nothing for Running segments.
              Can you confirm it is two separate guides ? In my memory it is but I am not very sure about it.
              Any idea why I only see cycling segments ?
              It is actually not them I want to have but running segments. For cycling, I use a garmin edge.
              A3S | S9B | S9P | S9PP | SV1 Ti | SV2 Ti
              Suunto Wing
              Suunto App: Android Beta
              • isaziI Offline
                isazi Moderator @v.sacre
                @v-sacre you should have both. I will report the issue, I am not even sure if Strava segments are already enabled for everyone as the other watches still need an update (June?).
                Blog: isazi's home
                • isaziI Offline
                  isazi Moderator @Mi_chael
                  @Mi_chael it should, can you also try to disconnect and then reconnect to Strava?
                  Blog: isazi's home
                  M 1 Reply Last reply Reply Quote 0
                  • M Offline
                    Mi_chael Bronze Member @isazi
                    @isazi
                    Yes, with no success.
                    • isaziI Offline
                      @Mi_chael after reconnecting, repeat the process I described before. Thanks.
                      Blog: isazi's home
                      • M Offline
                        @isazi
                        Ok, i will try
                        Thanks
                        • VylliV Offline
                          Vylli Bronze Member
                          I just tried live segments and they work as promised. The only problem I have is that I can’t add new segments. It only shows the segments that I had starred before and it does not sync new segments at all. Any solution for this? I don’t want to delete all started segments just to try it because I don’t want to lose my starred segment list.
                          • L Offline
                            larrybbaker
                            What is the “official” status of he live segments? I had read in several places that it was a “backend” issue that Suunto/Strava have to fix. I have disconnected/reconnected my Strava account multiple times with no luck in getting my live segments to show up/load. SV/iOS both on lates versions/code.
                            Vertical Ti Solar
                            Vertical 2
                            Race 2
                            iPhone 17 Pro
                            • isaziI Offline
                              isazi Moderator @larrybbaker
                              @larrybbaker status is that they have been released in production, both Suunto and Strava announced it publicly, even Ray mentioned it.
                              Blog: isazi's home
                              • L Offline
                                larrybbaker @isazi
                                @isazi So any suggestions on getting it to work?
                                Vertical Ti Solar
                                Vertical 2
                                Race 2
                                iPhone 17 Pro
                                • isaziI Offline
                                  @larrybbaker have you tried this already?
                                  first, try to add a new segment in Strava, and then go to Suunto App and refresh the guides. If this does not work, another trick that used to work in the past (cannot tell you if still works) was to go to Strava, delete all segments, go to Suunto App, refresh guides, go back to Strava, add segments, back to Suunto App, refresh again.
                                  Blog: isazi's home
                                  • isaziI Offline
                                    isazi Moderator
                                    BTW the official support page from Strava:
                                    https://support.strava.com/hc/en-us/articles/15843793867021-Strava-Live-Segments-on-Suunto
                                    Blog: isazi's home
                                    • MdzOttM Offline
                                      MdzOtt
                                      They do work. Initially, there was a problem that required unlinking SA and Strava, potentially re-installing SA (and a few other steps). But once it started working, it does sync additional segments (or drops the ones that you un-starred in Strava).
                                      One big gotcha is that Strava will not let you sync any segments that have a negative gradient (even minimally negative) and there is no feedback on that (you keep adding segments and only some of them come across). But this is a Strava issue (I guess, safety related).
                                      R2
                                      S9 Baro
                                      SA on Android
                                      Ambit 3 Peak
                                      Ambit 2 Sapphire
                                      • L Offline
                                        larrybbaker @isazi
                                        @isazi Thank you - yes I have connected/disconnected the SA and Strava, deleted all my segments and added a few back. Still not showing.
                                        Vertical Ti Solar
                                        Vertical 2
                                        Race 2
                                        iPhone 17 Pro
                                        Register Login
                                        • First post
                                          Last post
                                        Suunto Terms | Privacy Policy
