    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Charging
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    13 Posts 7 Posters 2.0k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Martin VrskaM Offline
      Martin Vrska
      At what battery condition are you charging your S9PP at? Today I received a notification from the watch at 20% that the battery is empty. On my first charge (since 24.12. I only charged once đŸ€­) I let them charge with 9% and it was still possible to play sports with the best settings for 3 hours 👍.
      And what about you? Thanks.
      Suunto Vertical 2 - Arctic Gray - 2.56.18
      Suunto Spark
      Suunto Vertical - Steel Black, Strap Canyon Orange - 2.37.34 - SOLD
      Suunto 9 Peak Pro - Titanium Sand - 2.22.60 - my wife
      Google Pixel 9a - Android 17
      Suunto App 6.11.8 beta
      mikekoski490M Ɓukasz SzmigielƁ 2 Replies Last reply Reply Quote 2
      • mikekoski490M Offline
        mikekoski490 Bronze Member @Martin Vrska
        @Martin-Vrska Hi there. Good question! I might initially ignore the 20% battery notification, but more than likely I’ll just quickly fish out the charger (usually I forget where Ive put it because I charge it so infrequently) and with the quick charge feature, it will be topped up to 100% in around 45 minutes and ready for another adventure.
        Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
        Current: Suunto Race Ti
        Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
        Suunto App running on Google Pixel 8/Android 14
        • Ɓukasz SzmigielƁ Offline
          Ɓukasz Szmigiel @Martin Vrska
          @Martin-Vrska between 5 and 20%. Although I wonder if it’s safe for the battery to go under 20% and above 80%.
          S9PP 2.50.28
          sartoricS 1 Reply Last reply Reply Quote 0
          • sartoricS Offline
            sartoric Moderator @Ɓukasz Szmigiel
            @Ɓukasz-Szmigiel
            Well
 it’s safe (in terms of possible danger) but not recommended to avoid battery wear
            SVTS - 2.50.28
            SSSWHR BARO Amber - 2.8.32
            Samsung A5 2016 - Android 7.0
            Suunto App Android 6.11.8 beta
            freeheelerF 1 Reply Last reply Reply Quote 2
            • freeheelerF Offline
              freeheeler @sartoric
              @sartoric
              what I never know in general: do manufacturers control these limits?
              I mean if it is wearing the battery so much a company that strives for sustainability should charge and use within these limits, no?
              living sideways
              mikekoski490M Ɓukasz SzmigielƁ sartoricS 3 Replies Last reply Reply Quote 1
                mikekoski490 Bronze Member @freeheeler
                @freeheeler That’s a good point. I never really understood the 80% thing, from the point of view of if its that impactful, shouldn’t everything be set to stop at 80% charge out of the box, with an option to charge to 100% if you plan a big outing away from a charging source, no?
                  Ɓukasz Szmigiel @freeheeler
                  @freeheeler if 20 - 80% is beneficial for battery life, I’d like to know it from Suunto as an official statement. I see no need to go over 80% with S9PP with its battery capacity and quick charge.
                  S9PP 2.50.28
                  • sartoricS Offline
                    sartoric Moderator @freeheeler
                    @freeheeler said in Charging:
                    In fact I wouldn’t say “so much” but “more”
                    That said, if you don’t fully charge it, you won’t be able to squeeze all the juice you need out of it 😁
                    You should be able to choose (like you can do with some mobile phone) to stop at 80%, but maybe you won’t increase the longevity that much to justify additional hardware/software management, considering you don’t need to charge it frequently.
                    After 5+ years of use without too much care 😁 my Spartan is still (touching wood) ok
 and we don’t know if that 100% we see refers to 100% battery capacity
                    SVTS - 2.50.28
                    EgikaE 1 Reply Last reply Reply Quote 3
                    • EgikaE Offline
                      Egika Platinum Member @sartoric
                      this discussion is rather academic.
                      A state of the art LiIon battery used between 20% and 100% charge has like 1000 charging cycles before degrading significantly.
                      When only charged to 90% full this number is almost doubled to 2000 charging cycles.
                      As the Suunto 9 Peak Pro under normal conditions needs to be charged like once a week, it will last around 20 years with 20-100% charging.
                      This is long enough to not make me think about it.
                      If you are a “wrap TV remote into plastic bag” kind of person, then you might want to charge 20-80%. Otherwise just use it.
                      (me myself I charge whenever it fits into my daily routine - like during morning shower.)
                      Ɓukasz SzmigielƁ 1 Reply Last reply Reply Quote 5
                        Ɓukasz Szmigiel @Egika
                        @Egika but what if we wrap the watch into a plastic bag? Will it help? 😄
                        S9PP 2.50.28
                        EgikaE isaziI 2 Replies Last reply Reply Quote 3
                        • EgikaE Offline
                          Egika Platinum Member @Ɓukasz Szmigiel
                          @Ɓukasz-Szmigiel 😊 👏
                          • isaziI Offline
                            isazi Moderator @Ɓukasz Szmigiel
                            @Ɓukasz-Szmigiel if you wrap it tight, it improves OHR performance 🙂
                            Blog: isazi's home
                            Ɓukasz SzmigielƁ 1 Reply Last reply Reply Quote 3
                              Ɓukasz Szmigiel @isazi
                              @isazi but only on full moon 😉
                              S9PP 2.50.28
                              Register Login
                              • First post
                                Last post
                              Suunto Terms | Privacy Policy
