    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Altitude recording issue
    19 Posts 9 Posters 2.4k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      giuliosq
      Hi everyone
      I went ski touring with my suunto 9 baro. The altitude was correct. When I started recording my tour at 1500mt the watch started recording the ascent wrong stating always something like (at the end of the tour) 1000mt more. I ended the tour at 2650mt so the total ascent should have been 1150mt (as in the picture from my Wikiloc recording) but my suunto app recording (even though the altitude was always right) said 2569mt total ascent. It’s quite annoying because I was climbing up checking the ascent and it always said more than I was doing tricking so my exercise. I realised later that the watch was calculating it totally wrong. Is there a solution or should I send the watch in assistance?!
      Thanks!!ACA61E22-A974-4BF5-8A57-01DCBAC5DD2D.jpeg A31231F7-8EC7-4BA4-9045-A240A02BB0F3.jpeg
      sartoricS 1 Reply Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @giuliosq
        @giuliosq
        Well, you should show the altitude graph.
        I guess you have a bumpy one.
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.8.9 beta
        G 3 Replies Last reply Reply Quote 1
        • G Offline
          giuliosq @sartoric
          • G Offline
            giuliosq @sartoric
            @sartoric well… don’t know why it started from 0 when - on the other hand - the altimeter was well aware at what altitude we were
            freeheelerF 1 Reply Last reply Reply Quote 0
            • G Offline
              giuliosq @sartoric
              @sartoric
              It started its recording from 0 as the graph but it states that lower point was 1400 something and the highest the peak of the mountain at 2600. So… what’s the deal? 74C71864-5B7C-4714-A0A9-F63C63AF62C0.jpeg
              • zhang965Z Offline
                zhang965
                if it happened only once, let it be, if it happened again or very often on your watch, I think you’d better contact suunto support
                Winners Wear Winners
                • freeheelerF Offline
                  freeheeler @giuliosq
                  @giuliosq
                  0 belongs to x-axis and is ok as it shows duration.
                  how does the graph look when you zoom into it?
                  I have experienced that baro holes (famous topic in this forum) were blocked every now and then. this leads to increased pressure, drops in alti graph and adds more ascent meters to your total ascent, once the baro holes are free again. if you wear your watch tight this might be the reason.
                  if so, try to wear it a bit loser next time.
                  living sideways
                  L 1 Reply Last reply Reply Quote 4
                  • L Offline
                    Likarnik Gold Members @freeheeler
                    @freeheeler or maybe too low on wrist. My friend went cycling with watch on hand and it counted almost double elevation. He had no clue why. When I gave him my bike mount, everything was ok. He was ‘pumping’ on baro holes entire time 🙂 S9P has holes on better place. But still, I thing they should be on other side - 12 o’clock. When it is raining/snowing, water can block them and you get false reading, because normally you tilt your wrist and 6 o’clock is up. Maybe I am missing something… otherwise I give this info to Suunto for free 😄
                    G 1 Reply Last reply Reply Quote 1
                    • G Offline
                      giuliosq @Likarnik
                      @Likarnik
                      Thanks you’re all being very nice. Thought it would make a sort of mix in between gps/barometer for the altitude. Like if you calculate right the altitude from point a to b why should you tell me my elevation is 1000 my more. Like, I don’t understand honestly… you all got that the altitude is correct, right? Why the elevation uphill is wrong?!
                      isaziI Mff73M 2 Replies Last reply Reply Quote 0
                      • isaziI Offline
                        isazi Moderator @giuliosq
                        @giuliosq can you zoom on the altitude to check if the readings are as good as they seem, or spiky? Otherwise it’s very strange. If you export the fit or gpx file and import it somewhere else, do you also get this high ascent?
                        Blog: isazi's home
                        G 1 Reply Last reply Reply Quote 2
                        • Mff73M Offline
                          Mff73 @giuliosq
                          @giuliosq
                          very briefly
                          point a to point b can be 1200m +, but in between, if recordings are wavy, each up/down will count.
                          not to say it is your real case.
                          But maybe you could zoom a little to your altitude graph and see.
                          SSU (retired), SV1, SV2
                          Wife : S9PP
                          SA: Always the latest beta :)
                          Android + Galaxy S205G
                          S 1 Reply Last reply Reply Quote 1
                          • S Offline
                            Spree Bronze Member @Mff73
                            @Mff73 And just to expand a bit: this sort of scenario, when the fibrillation is excessive and doesn’t correspond to reality, causing excessive asc/dsc, is often caused by one of the below:
                            • Rain + wind
                            • Obstructed pressure sensor - either temporarily by clothing or contact with skin, or by snow; or by being dirty, rincing carefully and long can help
                            • Damaged pressure sensor
                              Dimitrios Kanellopoulos Community Manager
                              So if you climbed from 1500 to 2700 that the suunto watch recorded that is 1500 ascent.
                              Maybe share a link with us to analyze what happened .
                              Thanks a lot
                              Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                              • sartoricS Offline
                                sartoric Moderator @Spree
                                @giuliosq
                                @Spree said in Altitude recording issue:
                                • Rain + wind
                                and bad gps+baro combo
                                SVTS - 2.50.28
                                • G Offline
                                  giuliosq @Dimitrios Kanellopoulos
                                  @Dimitrios-Kanellopoulos
                                  So… the only things I could extract are the link to my move https://api.sports-tracker.com/apiserver/v1/workouts/export/AHoIJ7p8KEPn7s1A6X-QU8E6Jsp53iWK9YlzE8BWz3Ow82Tvkuf1jai0rP5Z_28vOg==?brand=SUUNTOAPP
                                  And here attached the detailed climb km by km which let you understand that there are obvious drops here and there for which the ascent calculation goes nuts.
                                  I had the watch to my wrist, no gloves, the sensor it was always free. I’m afraid here and there things like jacket and garments might have stuck it. I should wear it on the artist but in top of the jacket then. AF6F7CFF-7566-4FB9-AA81-8A157A68CCEC.png
                                  G isaziI 2 Replies Last reply Reply Quote 0
                                  • G Offline
                                    giuliosq @giuliosq
                                    @giuliosq
                                    Have not put all the screens but here is how it goes. And then in one km it states that I climbed 1700 (I guess to justify the altitude I got to).
                                    • G Offline
                                      giuliosq @isazi
                                      @isazi
                                      I have exported the training gps here:
                                      On top of this - funny enough - my watch is linked to my Wikiloc account so after each training it saves it there too. And the Wikiloc screenshot states that my ascent was correct (but I guess that’s only a calculation made afterwards, from starting point to arrival). It does not tell any climb average for example.
                                      • isaziI Offline
                                        @giuliosq was this the first time it happened? If so, probably the sensor was blocked by something. If not, maybe cleaning the sensor could help (warm water, baby toothbrush, I leave it in the water for 30 minutes or one hour, turning it around sometimes, then brush it gently without sticking the brush inside and under running water).
                                        Blog: isazi's home
                                        • G Offline
                                          giuliosq @isazi
                                          @isazi
                                          I just changed that now front eh suunto 7. So it was the very first ski test I did. I used that for running and trekking. Trekking it worked. Running it takes ages to get the gps signal and sometimes after a minute from the beginning the training app reboots. So that’s another problem too. Anyways. I bought it refurbished so I might send it in again. One other thing I noticed in comparison with the 7 I had is that the running pace on a threadmill indoor with no gps is totally wrong. The calculation made on the moving on the wrist (indoor with no gps) for the pace on the 7 was correct (identical to the one on the threadmill) on the 9 is totally wrong. Tells me I run with a 2’30” per km pace…
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
