    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    [solved] Reboot during activities
    135 Posts 31 Posters 43.2k Views 32 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • freeheelerF Offline
      freeheeler @Bradleyd
      @Bradleyd
      what GNSS combination do you and all you guys experiencing this issue use?
      GPS only or a combo of GPS and others?
      I’m using external HR always with S9B, and most of the time S+ climb, burner or zones. I’ve never had a crash with the latest firmware. I’m always using GPS and Galileo.
      If it was GNSS related, maybe it’s worth a try to switch system combo or go for GPS only, over avoiding using S+ or soft-resetting and waiting 15min in the cold on a daily basis.
      living sideways
      inkognitoI 1 Reply Last reply Reply Quote 1
      • inkognitoI Offline
        inkognito Platinum Member @freeheeler
        @freeheeler I had crashes with GPS+Galileo and GPS+BeiDou. Didn’t try the other…
        I had perfectly fine exercises with various SuuntoPlus apps without any crash, only to find it crashing next time with the same setup…
        I also had crashes when I didn’t use SuuntoPlus at all…
        I had crashes with external HR monitor and with watch OHR…
        Instead of trying crazy things like rebooting the watch on daily basis or hoping that hard reset will save us (it does not), the best would be if someone from Suunto would tell us what their analysis showed 🙂 Well and provide some fix asap…
        SV: fingers crossed :D
        S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
        Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
        Despite some pretty bad luck, I still love Suunto!
        freeheelerF 1 Reply Last reply Reply Quote 5
          freeheeler @inkognito
          @inkognito
          Suunto does not communicate much, but as I understand @isazi 's statement they seem to be on it ✊
          living sideways
          • isaziI Offline
            isazi Moderator
            Suunto sent us a message, we need some information from people having crashes, please contact me with a DM for more info. Thanks.
            Blog: isazi's home
              I had another reboot today… In fact, I went like “let’s combine many functions together and see if it crashes” 😄
              So I used:
              • Sport mode: Walking - custom with ETE/ETA fields
              • SuuntoPlus: Burner
              • Navigation: Route
              • I set target HR zone to Zone 1
              Watch crashed and rebooted around 26 minutes after start… I was stationary at that moment (taking a photo with my phone), I looked at my watch and saw a black screen and then, several seconds later, the watchface…
              But this made me realise one thing! This was not the first case my reboots happened like this. In fact, I had multiple crashes just after I stopped for a while! Usually due to photos, road crossings etc… I did not use pause or autopause…
              I tried to replicate this immediately after with no luck… I went on for another 40 minutes with the same setup without any problem…
              Anyone with similar experience (crash happened when you stopped for a while)?
              freeheelerF 1 Reply Last reply Reply Quote 0
                @inkognito
                I did groceries today and didn’t stop the activity when I was inside the building. navigation, hill climb, external HR etc… no crash at all. but I never had a crash with the latest firmware.
                I recommend @isazi 's suggestion ✊
                living sideways
                inkognitoI 1 Reply Last reply Reply Quote 0
                  @freeheeler I’m in contact with @isazi 😎 I was just currious whether I might have found some pattern in those reboots or not… To me, it happened multiple times exactly after I stopped for a while. It is becoming hard to believe that this is just a coincidence 🙂 But I am definitely not saying my watch rebooted everytime I stopped…
                  Anyway, when you stop without pause, many things happen at the same moment, like:
                  • Sony GNSS chip probably recognizes that you don’t move and triggers some clever algorithm to filter the data
                  • your HR decreases, you probably go from higher zone to lower, this affects the Burner app calculations…
                  • ETA/ETE values are changing rapidly
                  • Navigation starts using compass… etc.
                  I can imagine that these many simultaneous things that are going on might bring better chance that something goes wrong 😄
                  C 1 Reply Last reply Reply Quote 2
                  • C Offline
                    chargerunner Bronze Member @inkognito
                    @inkognito From what I experienced myself and from the other users, I think each one has faced a different “pattern”, so various that there can’t be a single pattern for these reboots 😂
                    For me it’s nearly always at the beginning of a running exercise (only once at the beginning of a cycling exercise). At first I noticed that the hear rate didn’t show up on the watch face before the reboot, so I thought it had something to do with the HRM (I use the watch’s HRM), and I always waited for the hear rate to appear at the beginning of the activities to be sure there wouldn’t be a reboot. Then later I found out that sometimes the heart rate also showed up before some reboots, and I don’t know what is the pattern of those reboots anymore 😂
                    • ReinerR Offline
                      Reiner Bronze Member @chargerunner
                      @chargerunner said in Reboot during activities:
                      @Reiner Glad to hear it @Reiner . How long has it been since you downgraded? I would wait at least one week before being a bit more sure about the issue not coming back😧 After the hard reset (still not downgraded), my watch went on for one week without error before the crash came back…
                      No more crashes after downgrading to previous firmware since 10 days - 5 “running” workouts. Before it crashed on every workout 1-2 times. Unusable.
                      It looks like the right decision.The “process” and suunto statements for a quick solution are not satisfying.
                      Watch: Suunto Race S
                      C 1 Reply Last reply Reply Quote 3
                      • C Offline
                        chargerunner Bronze Member @Reiner
                        @Reiner It’s encouraging. Could you keep us updated after maybe 10 more days?
                        I didn’t downgrade my watch. It went through a hard reset, imposed by Suunto Link, and still stays with the latest software version. It’s been more than 3 weeks since the hard reset now, and the crash happened already 3 times. The encouraging sign is that it didn’t crash as often as before the hard reset, and also didn’t crash during the last 10 days. I think in the end I will also downgrade the software as you did.
                        F ReinerR 2 Replies Last reply Reply Quote 2
                        • F Offline
                          fecek @chargerunner
                          @chargerunner I’ve also downgraded the version from 2.23.20 -> v2.20.30.682 cause that bug and lack of reaction from Suunto are pissing me off. When I reported the bug on live chat they told me to hard reset and if it is not working then send the watch to the service 😵
                          Will let you know after week or two if its okay.
                          freeheelerF 1 Reply Last reply Reply Quote 1
                            freeheeler @fecek
                            @fecek
                            just as a general reminder. Suunto does not seem to be inactive. @isazi has sent us a message about that.
                            I don’t have crashes fortunately (and unfortunately).
                            if you do have crashes and some patience, before you downgrade it would be helpful in long term for all to get in touch with @isazi
                            living sideways
                            ADHDMonkeyA F 2 Replies Last reply Reply Quote 0
                            • ADHDMonkeyA Offline
                              ADHDMonkey Bronze Member @freeheeler
                              @freeheeler no disrespect meant to anyone but I’d rather have an official statement from suunto for reassurance. Comes across as sly if I’m completely honest.
                              freeheelerF isaziI 2 Replies Last reply Reply Quote 4
                                freeheeler @ADHDMonkey
                                @ADHDMonkey
                                I know what you mean. Suunto does not comment on issues, improvements or roadmaps.
                                my observation is that the issue came up slowly. at first only one or two users reported crashes and now reports are becoming more frequent.
                                it still seems to be a rare case and Suunto can only investigate with feedback and reports. let’s hope it gets solved, soon ✊
                                living sideways
                                ReinerR 1 Reply Last reply Reply Quote -1
                                • ReinerR Offline
                                  Reiner Bronze Member @freeheeler
                                  @freeheeler
                                  I’m sure there are still a large number of other affected users. Very most of them are not registrated here in Suunto forum.
                                  They will probertly contact official support, when i read supports answer “send the watch to the service” oh no… The distribution of the buggy firmware has not been stopped until today.
                                  SimonHummS 1 Reply Last reply Reply Quote 2
                                  • SimonHummS Offline
                                    SimonHumm Bronze Member @Reiner
                                    @Reiner To be honest, if I’m told to return my watch to Suunto for something that is almost certainly a firmware issue then I’m probably done with Suunto. Likewise if they don’t/can’t fix the firmware. Can’t keep going out and not knowing if it will work or not.
                                    EgikaE 1 Reply Last reply Reply Quote 5
                                    • isaziI Offline
                                      isazi Moderator @ADHDMonkey
                                      @ADHDMonkey my guess is that it’s affecting very few watches to warrant an official statement. Since we asked for info to affected users we’ve got less than 20 responses, and this includes this forum, various Facebook groups, and national communities.
                                      Blog: isazi's home
                                      ADHDMonkeyA glaucidium.passerinumG 2 Replies Last reply Reply Quote 1
                                      • EgikaE Offline
                                        Egika Platinum Member @SimonHumm
                                        @SimonHumm said in Reboot during activities:
                                        From the fact that issues started happening with a certain FW version, you cannot conclude that it is not HW or accessory related. This is why sending in a watch will not necessarily be useless.
                                        But as I understand, this is a super rare issue and this is why it is not easy to get to the root of it.
                                        Forum reports are of course super biased and are not representing all users.
                                        Let’s help Suunto gather the necessary data of the circumstances of this issue. 👍
                                          inkognito Platinum Member @Egika
                                          @Egika Just two notes:
                                          There are multiple people who complained about this on reddit as well… Both S9 and S9P users. One even claims, that they sent the watch to service and they changed the core… It did not help…
                                          My feeling is, that not everyone is as crazy as we here. Normal user probably does not record one (or even multiple) activities daily. Therefore, even if they had the same issue, it would probably happen like once or twice since the firmware update (given the fact that I have problems in like 10% of cases). In such a case, I personally wouldn’t seek support yet as I wouldn’t be annoyed enough 😄
                                          isaziI EgikaE 2 Replies Last reply Reply Quote 2
                                          • isaziI Offline
                                            isazi Moderator @inkognito
                                            @inkognito that’s why we forwarded logs to Suunto devs, and are collecting statistics for Suunto, so that they can assess the root cause. I hope in a fix soon.
                                            Blog: isazi's home
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
