    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    power saving
    Scheduled Pinned Locked Moved Suunto 9 Peak
    16 Posts 4 Posters 1.9k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      hello and happy new year to all.
      a couple of days ago I went for a run in the mountains and when I ended the session I realized I forgot to turn off power saving.
      I know that PS turns off all vibration, daily HR and bt so I was surprised that:
      i) vibration was still active (not a problem though)
      ii) HR reported via chest belt was ok during session but the HR zone in the watch face did not work i.e. cursor locked in Z1, why?
      iii) sycing HR data when ending session took a great amount of time to finish. maybe because it had to download all the data from the suunto sensor to the watch (btw I love this feature)?
      DMytroD ? 2 Replies Last reply Reply Quote 0
      • DMytroD Offline
        DMytro @Guest
        @gi0vanni
        i) afaik power saving is outside activity only - for activity there are specific battery modes i.e. performance/endurance/…
        ii) dunno
        III) yep, that’s the reason. Sometimes it’s a bit quicker, sometimes it takes longer - don’t think it’s because of power saving.
        • ? Offline
          A Former User @DMytro
          @DMytro said in power saving:
          thanks for answering.
          ii) dunno
          imo it’s a bug
          DMytroD 1 Reply Last reply Reply Quote 0
          • DMytroD Offline
            DMytro @Guest
            @gi0vanni probably, let’s wait for sb else to comment on this, I never had this behaviour.
            Did it happen more than once?
            freeheelerF ? 2 Replies Last reply Reply Quote 0
            • freeheelerF Offline
              freeheeler @DMytro
              @DMytro
              @gi0vanni
              I remember barely that I once saw this behavior on my watch with a HR chest strap, too.
              but it’s a long time ago, happened only once and hence I consider it a rare bug.
              if it keeps happening, please report
              living sideways
              • ? Offline
                If I turn on power saving, this problem occurs systematically (cursor stuck in Z1) when I use the chest belt
                freeheelerF DMytroD 2 Replies Last reply Reply Quote 0
                  freeheeler @Guest
                  @gi0vanni
                  I will try tonight and see if I can replicate it
                  living sideways
                  • DMytroD Offline
                    DMytro @Guest
                    @gi0vanni that’s a bug well spotted, hopefully sb can forward it to the devs. You could also contact support to file a bug complaint, they’ll also forward it to devs.
                    ? 1 Reply Last reply Reply Quote 1
                    • ? Offline
                      @DMytro for sure! I will do more tests to be sure…
                      freeheelerF 1 Reply Last reply Reply Quote 2
                        freeheeler @Guest
                        @gi0vanni
                        I have tried twice but was not able to replicate this issue. (once with chest strap and once with verity sense)
                        I understood you are using power saving mode, start an activity and your HR values go up and down while the dial remains in Z1 and does not move at all.
                        just to be sure: this is not the case when power saving is disabled? and your HR zones are either default or manually but correctly set?
                        living sideways
                        • ? Offline
                          A Former User @freeheeler
                          @freeheeler said in power saving:
                          w/ ps disabled it’s ok
                          manually and set correctly (verified twice).
                          freeheelerF 1 Reply Last reply Reply Quote 1
                            freeheeler @Guest
                            @gi0vanni
                            I see some disadvantages with power saving, as I was struggling to connect my watch after running… I am not used to power saving and it is not my routine to toggle it off again. the battery life is so amazing that I honestly never used it. 😂
                            I will ask. please PM me when it happens again.
                            living sideways
                            thanasisT ? 2 Replies Last reply Reply Quote 0
                            • thanasisT Do not disturb
                              thanasis Bronze Member @freeheeler
                              @gi0vanni
                              I don’t use the powersaving but not because the battery is great but because it gives little benefit to the duration.
                              It is just better to disable the features not needed and indeed increases it
                              • ? Offline
                                @freeheeler PS was not used on purpose just forgotten there after tinkering with the watch. Tomorrow I have planned a run and I will let you know. Thanks!
                                • ? Offline
                                  A Former User @Guest
                                  @gi0vanni said in power saving:
                                  I have probably sorted out the (non) problem. I apologize in advance for the noise, especially @freeheeler for wasting your time with testing. That said, I have been manually changed my HR zones and have recently been in recovery mode due to some heart problems, so I try to stay in Z1 as much as possible. My current Z1 upper limit is 123bpm and I have noticed that the dial starts moving around 111bpm or so (yesterday I stayed around 109-110 and probably the other days as well). The fact that I could see the HR values at the chest and the dial did not move made me think it was not working… 😊
                                    freeheeler @Guest
                                    @gi0vanni
                                    no worries! I’m happy you found the root cause.
                                    happy to help next time again 🙂 👍
                                    living sideways
                                    Register Login
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
