    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Maximum activity duration (storage space)
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    60 Posts 13 Posters 13.0k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Brad_OlwinB Offline
      Brad_Olwin Moderator @MKPotts
      @MKPotts So a couple questions. I have had the same problems in the past. I ran Fat Dog in Canada (200k) when Ambit 3 Peak was the current watch and wanted data in 1s mode. It took 40h to finish. I split my run into 2 events. My main repository for data is TrainingPeaks so combining the files in TP worked fine. I just left these as two files in MC, now SA.
      1. Do you use SA as your primary analysis tool?
      2. If not I agree with @herlas on this and we should be able to import large fit files.
      I am going to raise this with Suunto as I am considering doing a 320k or longer next year. Personally, the watch should not be limited, I could accept reduced HR sampling or no HR for a 120 race to record as one file. Current watches should handle that. I suspect it boils down to costs……
      Vector/T6c/Vertical 2 Ti
      DMytroD M 2 Replies Last reply Reply Quote 1
      • DMytroD Offline
        DMytro @Brad_Olwin
        @Brad_Olwin I also wonder if such things affect battery life, since during the prolonged recording the file is ‘open i.e. constantly being fed the data’, so I suppose keeping larger files ‘active’ puts more strain on memory and processing power thus also affecting the battery.
        This is just my guess as sb who never had a CS class and also I can’t guess how the energy consumption scales with increasing activity duration (hard to imagine the effect being exponential tho).
        • M Offline
          MKPotts Bronze Member @Brad_Olwin
          @Brad_Olwin
          When I’m doing more structured training I use TP (premium) as my primary tool for planning and analysis. At other times I’ll mainly use SA. I didn’t know I could combine fit files within TP, that’s helpful to know, thank you. I also send data to Strava but only for connecting with friends, I don’t find their analysis tools any use.
          With splitting races into multiple files, the main reason I want to avoid it is because it’s something else to do/forget/mess up at checkpoints, when there’s already so many things to try to do efficiently (especially in winter).
          I had/have an A3P but never went longer than 13hrs with it, so didn’t run into memory issues. But I know you could change the recording interval. Maybe reintroducing the option to do that in the S9 watches - e.g. still acquiring data every second for navigation but only writing to the file every 5sec - would be a way to extend run time without hardware changes.
          Regardless, the S9 watches are still the best fit for my needs/priorities, so I’ll stick with them unless/until a better option comes along.
            @MKPotts You cannot combine within TP but after combining no data is lost upon TP import.
            • M Offline
              Hi,
              I bought a S9PP and used it for my race, so I thought it may be helpful to others to share what I found out about watch storage space.
              I’m assuming the logbook in the S9PP functions in the same way as the S9P/S9B - i.e. if the graphs are still present for altitude etc, the full activity data is still stored, otherwise it has been overwritten with just a summary remaining.
              For the race I used the S9PP in a custom running profile, in endurance mode, HR off, no external sensors connected and auto laps every 10km. I split the race roughly two-thirds/one-third - 58:25 & 31:57 - so a total time of 90hrs 22mins. Both activities are still stored in the watch (altitude graph and intensity chart still showing), so I could have kept the watch running rather than split the activity. This included about 6hrs with the watch paused - i.e. total watch “on” time was about 96hrs - I know it keeps connecting to GPS when paused but I’m not sure if it writes anything to the data file.
              The watch also still has 4hrs 11mins of previous activity stored - all running, in performance mode with an external HR sensor connected (Polar Verity Sense). I guess this would equate to 5-10hrs without HR data.
              Overall, my experience indicates the S9PP can store about 95-100hrs of data in endurance mode, without HR or external sensors, when used for running.
              Hope this helps anyone else looking to use the watch for multi-day events.
              isaziI 1 Reply Last reply Reply Quote 13
              • isaziI Online
                isazi Moderator @MKPotts
                @MKPotts thanks for sharing your experience! How was the race?
                Blog: isazi's home
                Brad_OlwinB 1 Reply Last reply Reply Quote 1
                  Brad_Olwin Moderator @isazi
                  @isazi said in Maximum activity duration (storage space):
                  Thanks for the information and as @isazi said, how was the race?
                  • matthinshM Offline
                    matthinsh Bronze Member
                    Super feedback on how the 9PP handled the race. Fantastic result @MKPotts 5th male overall! Absolutely over that distance. https://live.opentracking.co.uk/spinerace23/
                    Did you use it for navigation also?
                    M 1 Reply Last reply Reply Quote 1
                    • M Offline
                      The race was really, really good. It’s the third time I’ve done it - twice in winter, once in summer - so I knew what to expect.
                      The weather was good this year after the first few hours - cold (by UK standards) with lows down to about -6°C with snow and ice at all levels - but relatively light winds and clear skies. As always, managing sleep deprivation was probably the hardest thing - I only slept for 3.5hrs in a total time of 101hrs - and had to sleep for 20mins in the snow on the last night when I kept falling asleep on my feet. Unfortunately I had a tendon problem from about halfway which meant I had to walk a lot of the second half, but I managed not to slip too far back in the field.
                      Irunfar.com have posted a summary of the races (I’m the one shown crossing the finish line with my children). For anyone interested the race also publish excellent daily video summaries, on their Facebook page and YouTube channel.
                      Brad_OlwinB 1 Reply Last reply Reply Quote 4
                      • M Offline
                        MKPotts Bronze Member @matthinsh
                        @matthinsh said in Maximum activity duration (storage space):
                        Yes, I used it to navigate throughout the race and it was generally excellent. I also added key waypoints into the race gpx files - really easy to do with SA - and used ETE/distance to fields in the watch, which was very helpful for making decisions about whether to push on, sleep etc.
                        The only problem I had was on the last overnight stretch when the watch was struggling to orientate the navigation track and often doing so with a 180° error. I’m not sure if this was a compass calibration error - because I couldn’t find a way to manually calibrate it during an activity - so I had to switch to my handheld gps (mandatory to carry one).
                        I’ll test it a few times (once I’ve recovered) to see if the behaviour repeats itself. I also need to test the barometer because altitude readings were wrong throughout the race - consistently about 10% to high for the first recording and 10% too low for the second - but I wasn’t using altitude for navigation so it didn’t cause a problem in the race.
                        isaziI 1 Reply Last reply Reply Quote 7
                        • M Offline
                          Also to add, I had my S9P on my other wrist, recording in Endurance mode. FusedTrack produced a very impressive track, considering it was only getting a satellite fix every 60sec. Total distance was also close, showing 422km vs 435km with the S9PP in 1sec mode.
                          I can post links to the activities for comparison if anyone would find this useful.
                          jasoncJ 1 Reply Last reply Reply Quote 7
                            @MKPotts Congratulations!!! that was awesome. Read the report on iRunFar and sounds like a stout event this year.
                            • isaziI Online
                              @MKPotts in the navigation options, lower button on navigation screen, you should find compass calibration.
                              Blog: isazi's home
                              M 1 Reply Last reply Reply Quote 0
                              • M Offline
                                MKPotts Bronze Member @isazi
                                @isazi
                                Thank you. I’ve now found it under “navigation settings”. During my race when navigating a route, I’d looked under “compass” and couldn’t find it.
                                I assume the compass lost calibration when I was charging the watch, though I’m not sure why it didn’t ask me to calibrate it.
                                Hopefully, if I get track orientation issues in the future, calibrating the compass will fix it. It’s only ever been a problem when moving slowly on long races, I assume when moving more quickly gps is used for orientation.
                                • jasoncJ Offline
                                  jasonc @MKPotts
                                  @MKPotts Well done on the Spine. You were one of the dots I was watching. I’m thinking about doing a race like TOR/Swiss Peaks/Spine with my S9PP next year so I’d love to see a link to your activity for the race.
                                  Suunto: Ambit 3 Peak > Spartan Ultra > 9 > 9PP > Vertical > Race
                                  • quattrojamesQ Offline
                                    quattrojames
                                    I have nothing constructive to say on the actual topic, but from someone who is half way through the couch 2 5k program the fact you can run 268 miles in just over 100 hours continuously is staggering!
                                    I have huge respect for you 🙌
                                    Suunto Race
                                    Pixel 6 pro
                                    M 1 Reply Last reply Reply Quote 7
                                      '@MKPotts said in Maximum activity duration (storage space):
                                      @isazi
                                      The other issue to consider is magnetic interference. If you have magnets on your pack to hold pockets together or to hold your bladder tube, these could interfere with the compass in the watch and require recalibration.
                                      • M Offline
                                        MKPotts Bronze Member @jasonc
                                        @jasoncuddy said in Maximum activity duration (storage space):
                                        I’m not sure how to best share activities in SA, so if these links don’t work, let me know what I need to do.
                                        Two activities recorded with S9PP:
                                        https://maps.suunto.com/move/markpotts/63c71eb414f9267dafeea053
                                        https://maps.suunto.com/move/markpotts/63c95010a3fc32176b5be341
                                        (In the first one particularly, I didn’t pause the watch when inside checkpoints, so you’ll see wandering of the track at these points).
                                        One activity recorded with S9P in endurance mode (so 60sec/FusedTrack):
                                        https://maps.suunto.com/move/markpotts/63cbb13478d4d17415e65650
                                        • M Offline
                                          MKPotts Bronze Member @quattrojames
                                          @James-Howes said in Maximum activity duration (storage space):
                                          Thanks! It’s not as hard as it looks though - there’s a lot of walking, even if I hadn’t developed tendinitis. And I find that after a point, the distance no longer really matters, you can just keep going if you look after the basics (feet, food, sleep).
                                          I’m not saying it’s easy but, in a different way, shorter ultras (e.g. fast, runnable 100km) are as hard/harder. Definitely don’t be put off if you’re thinking of something similar in the future.
                                          1 Reply Last reply Reply Quote 3
                                          • M Offline
                                            Hi,
                                            An update about storage space on the S9PP after I’ve continued to use my watch as I get back to running.
                                            The original estimate I gave was too low - I forgot that the watch firmware updated after I used it for the first time and this is why the first activity showed summary data only (not because it had been overwritten). My watch has just now overwritten (graphs/tables no longer available) the first activity I recorded after the firmware update. I had the following stored in the watch:
                                            90.4hrs running in endurance mode - with power but no HR.
                                            19.2hrs running in performance mode - power and HR data (Polar Verity Sense - I assume the same/very similar contribution to file size to the watch OHR but less than a belt because r-r interval data isn’t recorded).
                                            7hrs walking in performance mode - HR data (watch sensor).
                                            A total of about 117hrs of mixed use. From this I’d estimate at least 120hrs of activity storage space if recording in endurance mode without HR data.
                                            All of the above assumes that the presence/absence of graphs and tables in the watch file still indicates that it does/doesn’t remain in the watch memory.
                                            Hope this is useful to anyone else looking to record continuous multi-day activities.
                                            1 Reply Last reply Reply Quote 14
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
