    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Maximum activity duration (storage space)
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    60 Posts 13 Posters 13.0k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • DMytroD Offline
      DMytro @MKPotts
      @MKPotts said in Maximum activity duration (storage space):
      It couldn’t accurately display a route track, so was of little use for detailed night navigation (often at least 30-40m off the actual route)
      Don’t know about s9p, but my s9 often has the same behavior in the mountains due to the GPS reception quality. On the flat/open areas it obviously performes much better, rarely diverging too far off trail.
      M 1 Reply Last reply Reply Quote 0
      • M Offline
        MKPotts Bronze Member @DMytro
        @DMytro
        I’ve not had that problem with my S9B or S9P.
        With the Enduro, that definitely wasn’t the problem. If I followed a path and ignored the route track, the breadcrumbs showed exactly where I’d been (so gnss signal was good). It was the uploaded track that was wrong because the watch was removing many of the track points. This would happen with any gpx track I uploaded that was more than about 30-40km, no matter how I created it or transferred it to the watch.
        DMytroD 1 Reply Last reply Reply Quote 0
        • DMytroD Offline
          DMytro @MKPotts
          @MKPotts ah ok, I see. So it is not quite the same problem I’ve had.
          thanasisT 1 Reply Last reply Reply Quote 0
          • thanasisT Offline
            thanasis Bronze Member @DMytro
            So based on this thread
            What is the suggested approach for a multi day activity? End and save the activity per day ? I assume the save would apply to s9p which I have.
            How can you merge the parts afterwards?
            Also , if you don’t have coverage on your phone will you be able to process those saves ?
            Thanks
            isaziI 1 Reply Last reply Reply Quote 0
            • isaziI Offline
              isazi Moderator @thanasis
              @thanasis you can sync activities with SA also if you don’t have internet connection.
              Blog: isazi's home
              thanasisT 1 Reply Last reply Reply Quote 1
              • thanasisT Offline
                thanasis Bronze Member @isazi
                @isazi said in Maximum activity duration (storage space):
                Thanks @isazi , shall I assume that for the rest is as I mention?
                so saving them (stop it ,save, synchronise) on a daily basis?
                but on the merging of the parts?
                freeheelerF isaziI 2 Replies Last reply Reply Quote 0
                • freeheelerF Offline
                  freeheeler @thanasis
                  @thanasis
                  I wonder why you want to have one activity if a multi day activity is done on different days with dinner and sleep in between? Don’t get me wrong, everyone has his/her own process and philosophy.
                  personally I would record day by day and if you want to look at your entire track, load all relevant activities into quantified-self.io and merge them.
                  living sideways
                  L DMytroD 2 Replies Last reply Reply Quote 1
                  • L Offline
                    Likarnik Gold Members @freeheeler
                    @freeheeler there is a difference between for example Moab 240 and Marathon Des Sables. Moab 240 - one activity, Marathon Des Sables - six activities 🙂 Btw, I’m far for competing in those races, just an example how I would like to have them stored 🙂
                    freeheelerF 1 Reply Last reply Reply Quote 2
                    • DMytroD Offline
                      DMytro @freeheeler
                      @freeheeler I bet 200k in one go looks more impressive in SA than 4x50km haha.
                      But apart from that I think at such severe level of tiredness one may as well forget to finish/start an activity, so it’s more for a peace of mind I suppose.
                      1 Reply Last reply Reply Quote 3
                      • isaziI Offline
                        @thanasis you would need to export the FIT files and stitch them together somewhere else, then import them back in SA.
                        Blog: isazi's home
                        L 1 Reply Last reply Reply Quote 0
                        • L Offline
                          Likarnik Gold Members @isazi
                          @isazi and lose data by design 😞
                          https://forum.suunto.com/topic/8404/original-suunto-fit-file-loses-too-many-stuff/4?_=1672998761998
                            freeheeler @Likarnik
                            @Likarnik
                            I am aware for this topic for races. But when I go on a skitour for multiple days and it is not a race, personally I don’t see a reason why multiple days should be one activity… maybe what @DMytro says 😜
                            I know people who record the commute there and back in one activity… but in between there is 10h of being at work 🤷 again: philosophy question 👍
                            living sideways
                            isaziI 1 Reply Last reply Reply Quote 2
                            • isaziI Offline
                              isazi Moderator @freeheeler
                              @freeheeler I am with you here. If I wanted to do a race of this kind, I would like to have a single activity. But my usual multi-day activity is climbing/hiking/mountaineering and I consider it a collection of daily activities, because I eat and sleep in between 🙂
                              Blog: isazi's home
                              L 1 Reply Last reply Reply Quote 2
                              • L Offline
                                @isazi @freeheeler I agree with you on multi day trips, but as far as I understand, @MKPotts is talking about races
                                @freeheeler philosophy question? Maybe we should include ski touring/backcountry skiing/skimo in here😂
                                isaziI freeheelerF M 3 Replies Last reply Reply Quote 1
                                • isaziI Offline
                                  isazi Moderator @Likarnik
                                  @Likarnik yes, and for that unfortunately we cannot go more than ~70 hours apparently. Future watches may be different in this regard.
                                  Blog: isazi's home
                                  DMytroD 1 Reply Last reply Reply Quote 3
                                    @Likarnik
                                    you’re right @MKPotts asked for that, but I was more focusing on the request from @thanasis , since the request from @MKPotts is not solved, but at least answered 🙂
                                    … skitouring… well, priority number one is: we desperately need snow, everything else is priority number 2 or 3 🙈
                                    I use skitouring for telemark skitours and snowboard tours (no splitboard) and I’m fine with that. The activity basically is the same: sweating heavily uphills and grinning from one ear to the other on the downhill 😁
                                    living sideways
                                    • DMytroD Offline
                                      DMytro @isazi
                                      @isazi should we start an s9ppp thread already? XD
                                      • M Offline
                                        MKPotts Bronze Member @Likarnik
                                        @Likarnik said in Maximum activity duration (storage space):
                                        Yes, I was talking only about races. If doing a multiday trip (e.g. backpacking, I can’t ski!), I’d want it as separate activities. So agree with all the comments.
                                        Also agree there are workarounds for long races - saving, syncing, merging later etc - but they have downsides (especially when you’re sleep-deprived!).
                                        I know very little about the design limitations and trade-offs with watches, file management etc, so would be interested to know why activity storage is still even a consideration on modern devices. Is the fit file size in SA indicative of storage needed on the device? If so, then looking at file sizes for some of my 12-24hr races, suggests a 120hr activity would only be about 10MB. Is that more challenging than it sounds?
                                        • isaziI Offline
                                          isazi Moderator @MKPotts
                                          @MKPotts it is challenging only in the way that current Suunto watches have very little storage available, so nothing can be done with current models I’m afraid.
                                          Blog: isazi's home
                                          • Brad_OlwinB Offline
                                            Brad_Olwin Moderator @MKPotts
                                            @MKPotts I used an Epix 2 for 8 months and had similar experiences but nothing as long as you have done. I sold my Epix 2.
                                            Vector/T6c/Vertical 2 Ti
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
