    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Increased battery drain
    Scheduled Pinned Locked Moved Suunto 7
    49 Posts 8 Posters 8.7k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • BinoWorld UKB Offline
      BinoWorld UK Bronze Member @isazi
      @isazi same here, battery last for about 1.5 day with about 29% left.
      Overnight, 9/10% battery drain with the watch set to airplane mode and theatre mode. Sleep tracking on.
      • Q Offline
        qtkiguis
        I have the same battery problems as many users for the last 2 weeks. And in the Suunto telegram group in Spain there are also several users. Even with the previous version of wear os and deactivating wallet, fit and even sleep monitoring, my consumption skyrockets at night (with cinema mode activated… is it because of that?). Tonight wear has reached 65% battery usage. I don’t have any extras installed after doing a hard reset. Inadmissible
        The difference between Mobvoi and other manufacturers with Suunto is that at least they put pressure on Google to fix the bug and Suunto doesn’t even say anything. It is one thing not to develop a watch anymore and quite another to not worry about the correct and basic operation of the watch
        1 Reply Last reply Reply Quote -1
        • J Offline
          judnoe
          Good morning.
          Those who have the version that in theory drains the battery (2.59.0.471251175), @isazi @flypg @BinoWorld-UK do you have Google Fit enabled? O Google actualizado? Thank you.
          isaziI ? BinoWorld UKB 3 Replies Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @judnoe
            @judnoe Google Fit is installed but I don’t use it. I have all standard apps, plus few more I installed myself. I only use the watch during the day, and don’t use HR monitoring at all. Haven’t noticed anything different in battery life, so it may be related to something I don’t use.
            Blog: isazi's home
            J 1 Reply Last reply Reply Quote 0
            • J Offline
              judnoe @isazi
              @isazi Gracias.
              • ? Offline
                A Former User @judnoe
                @judnoe Buenos días, Google Fit since the first day disabled. All apps up to date. HR 24/7 ON. Hope that helps.
                • J Offline
                  judnoe
                  Well, now I don’t know whether to update Wear OS, or wait? Will Google Fit be the problem instead of Wear OS? I think I’m going to wait, as it is now working well for me. Thanks a lot.
                    BinoWorld UK Bronze Member @judnoe
                    @judnoe No Google fit disabled, no wallet, no use of hey google…. Plain Suunto watch
                    • J Offline
                      judnoe
                      Good morning. Yesterday after going for a run, sync with the suunto app and then enter the wear-OS app of the mobile (just to browse), and the watch began to drain the battery again very quickly. From 19:30 to 23:00 drain 40%. Then I had read in the Mobvoi group to remove the GPS, and so I did and the battery returned to normal consumption during the night.
                      • J Offline
                        judnoe
                        So I don’t know what causes the problem anymore. The wear os app of the mobile when connected, the GPS. The do not have problems use Android or IOS?, do you always have active location from connectivity?
                        • K Offline
                          Kramble
                          Wear Os watch 2.46.0.365651031.u
                          Fit disabled
                          Wallet disabled
                          GPS always
                          No drain issue
                          Ambit 3 peak saphir
                          Spartan Ultra (sold)
                          S7 graphite copper
                          S9 peak all black
                          Vertical titanium green forest
                          Wings
                          • J Offline
                            judnoe @Kramble
                            @Kramble And you have entered the Wear Os application of the mobile (connected the watch)?, I suspect that if you enter it with the location of the mobile activated, something is caught in the clock that does not disconnect the location of the watch and drains the battery.
                            K 1 Reply Last reply Reply Quote 0
                            • K Offline
                              Kramble @judnoe
                              Edited
                              @judnoe It’s possible that I didn’t activate the GPS on the phone in wear os. My phone GPS is usually disabled. I activate it only when I use it .
                              I use my watch and phone normally since 10 days without issue. Before this I reset factory the watch, then I uninstalled the wear Os update on the watch (I didn’t touch the wear os on the phone). I may have made some clean cache on apps.
                              Ambit 3 peak saphir
                              S7 graphite copper
                              S9 peak all black
                              Wings
                              • quattrojamesQ Offline
                                quattrojames
                                This mystery deepens.
                                After about a day on Wear OS 2.46 my watch starting randomly vibrating and no matter what I did I couldn’t stop it. A hard reset solved it but now I’m back to 2.59 again 🤔
                                I’ve had a busy few days and haven’t had time (or inclination) to mess about with it, so I’ve just got into the habit of twice daily top -up charges.
                                I’ll try and fiddle with a few things and see if I can pin-point the problem for me, I’m hoping Google will see the error of their ways soon and release an improved update! I don’t use Google Wallet, but I do use Google Fit so I’d quite like to keep that if possible.
                                Since last nights charge WearOS is responsible for 24% battery drain at this time!
                                Suunto Race
                                Pixel 6 pro
                                BinoWorld UKB 1 Reply Last reply Reply Quote 0
                                  BinoWorld UK Bronze Member @quattrojames
                                  @James-Howes how about using the S7 without WearOs app connect at all. Basically just use the Suunto app when you want to sync the activity. I think this method can eliminate all doubts about What version WearOs or it’s potential Bluetooth battery drain.
                                  • J Offline
                                    judnoe
                                    Good morning.
                                    On 18/12 at 9:30 I reset the factory, 76% of battery remains.
                                    I leave Wear OS and Google unupdated, disable Google Fit, update Google Wallet, GPS active.
                                    At 23:02 there is 49% battery left, no activity done, and in airplane mode. Turn off GPS for sleep.
                                    This morning 19/12 at 7:44 I have 44% left.
                                    Today I will try to go for a run and synchronize it with the Sunnto app, without entering Wear OS of the phone.
                                    I hope it helps.
                                    BinoWorld UKB 2 Replies Last reply Reply Quote 2
                                      @judnoe sounds promising! I would also use the watch normal and charge it at least three to 4 times before coming to a conclusion. The battery normally improve after few cycles. Cheers
                                        @judnoe I had to do a hard reset on my S7 due to a glitch and now WearOs is responsible of 37% of battery consumption!!! I am going to give this few days and see if it settles down. If it doesn’t then Weaos is totally corrupt or some features in the Suunto UI are not that well adapted. Could be wifi, Bluetooth and anything else.
                                        • J Offline
                                          judnoe @BinoWorld UK
                                          @BinoWorld-UK @BinoWorld-UK Hello, it is not a Suunto thing, other watches with Wear OS also happen that the consumption of wear is skyrocketing, I advise you, if you do not need, to remove the GPS, you will see how you do not spend so much battery and remove the latest version of Wear OS. I charged on 12/20 at 9:49 and today it still has 52% battery, but I only have the minimum and no GPS, no activity, no Google Fit. I want to try it before putting more apps back.
                                            @judnoe can you please clarify what you mean by (advise you, if you do not need, to remove the GPS, you will see how you do not spend so much battery and remove the latest version )
                                            How do you remove the latest version? And remove GPS?
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
