    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Baro AGPS n/a
    61 Posts 20 Posters 11.6k Views 19 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Johannes MaierJ Offline
      Johannes Maier
      Hi,
      I am very disappointed about Suunto. After having a lot of problems regarding AGPS n/a and trying to fix it with help of the support, I sent my watch to the support center and got a new S9 Baro six weeks ago. The new watch worked perfect in the beginning! But now the problems start again šŸ˜ž I’m not able to get AGPS synchronized any more. Worked through a lot of tips in this forum without success. Did anybody found a solution, so that this 500€ watch is doing its basic work (GPS) correctly? Why is Suunto not able to fix this basic problems!???
      If there is no permanent solution, I will buy another watch, but certainly no Suunto any more. Firmware and Suuntolink and SuuntoApp are the newest version.
      Regards
      Johannes
      sartoricS E 2 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @Johannes Maier
        @Johannes-Maier
        I guess you should read this : https://forum.suunto.com/topic/8120/suuntolink-site-down/21
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.10.7 beta
        • E Offline
          el2thek Bronze Member @Johannes Maier
          @Johannes-Maier Just had a look and mine also says Assisted GPS N/A. Trying to get a gps fix it took longer than normally, about 30 seconds I’d say. No major issue for me.
          Johannes MaierJ 1 Reply Last reply Reply Quote 0
          • F Offline
            fritzbt2013 Bronze Member
            Had this issue Friday, rebooting watched fixed!
            • isaziI Offline
              isazi Moderator
              It’s been reported to Suunto. In case you don’t have AGPS available, just leave your watch outside for 15/20 minutes looking for GPS, for example recording an activity that you can discard after. The watch will download the ephemeris directly from the satellites this way.
              BTW the AGPS files come from Sony, so it may even not be Suunto’s fault in this case (just to be clear).
              Blog: isazi's home
              Johannes MaierJ 1 Reply Last reply Reply Quote 2
                Johannes Maier @fritzbt2013
                @fritzbt2013 thanks for your hint, but I rebooted several times.
                  Johannes Maier @el2thek
                  @el2thek thanks for your reply. GPS fix lasts several minutes with my watch.
                    Johannes Maier @isazi
                    @isazi what makes me wonder: Had the same symptom some weeks ago with my old watch and the Suunto support sent me a new watch. But what you are describing seems to be a software problem…
                    sartoricS 1 Reply Last reply Reply Quote 0
                    • sartoricS Offline
                      @Johannes-Maier said in Suunto 9 Baro AGPS n/a:
                      AGPS not in sync is commonly a ā€œdataā€ issue, but it could be also an hardware issue (your watch cannot sync due to some hardware failure)
                      That said, AGPS it’s just a way to speed up GPS fix so if you’re problem was also a very long fix time, maybe something was faulty in your gps hardware
                      SVTS - 2.50.28
                      • cosme.costaC Offline
                        cosme.costa
                        Today I got the AGPS file.
                          Johannes Maier @cosme.costa
                          @cosme-costa Me too! Let’s hope!
                          • PrenjP Offline
                            Prenj
                            Me 2. šŸ‘
                            Suunto Race
                              cosme.costa
                              Today I do not have AGPS file again.
                              I relay on the background sync and when I went for my morning run, the watch wasn’t able to get a GPS lock, I checked and AGPS was missing. Because in the morning I do not have much time I had to start my run without GPS signal so you can imagine how bad is the track.
                              After the run I did a soft reset and killed the app in the mobile but I still don’t have AGPS file.
                              I think that someone at Sony or Suunto should check what happens with the AGPS file. I do not want to imagine that this happens to me just before a race.
                              Mitch9M ? 2 Replies Last reply Reply Quote 1
                              • Mitch9M Offline
                                Mitch9 Silver Members @cosme.costa
                                @cosme-costa Today and yesterday it takes very long to get a fix, too.
                                But how can I check the AGPS data? Watch or App?
                                Watch: Suunto Vertical Titanium Solar (Sand)
                                SA: Android (beta)
                                HRS: Polar H10
                                freeheelerF 1 Reply Last reply Reply Quote 1
                                • ? Offline
                                  A Former User @cosme.costa
                                  @cosme-costa yeah, I was asking a few times now for an option in Suunto app to be able to switch off automatic GPS optimization, I think the watch will do fine even with a few days old GPS data, but it could help in such cases. I’m also almost in hurry like you said, and I do not want to waste time with checking GPS data is okay or hanging there for get a fix. šŸ™‚
                                  • freeheelerF Offline
                                    freeheeler @Mitch9
                                    @Mitch9
                                    under settings, general, about… recently on Friday and weekend days it seems AGPS is missing.
                                    it always says N/A.
                                    with resetting the watch it will not come back. as it is missing completely, we can’t rely on an older file.
                                    the only thing is to wait until satellites are locked and start the activity only then.
                                    it also took me couple of minutes, sometimes 10… but it’s better than having a completely wrong track… if time allows of course!
                                    living sideways
                                    Mitch9M ? MiniForkliftM 3 Replies Last reply Reply Quote 0
                                    • Mitch9M Offline
                                      Mitch9 Silver Members @freeheeler
                                      @freeheeler Thx!
                                      Yes, also N/A on my watch. This really limits the usage.
                                      SA: Android (beta)
                                      HRS: Polar H10
                                      • ? Offline
                                        A Former User @freeheeler
                                        @freeheeler said in Suunto 9 Baro AGPS n/a:
                                        You just gave me an idea: I should make another sport profile with GPS turned off as mostly I don’t care about the track, but I should check first how correct some of the metrics will be reported without GPS. šŸ¤” If this works, then when in hurry I use the one without GPS and other times the complete one šŸ˜‰
                                        • MiniForkliftM Offline
                                          MiniForklift Platinum Member @freeheeler
                                          @Mitch9
                                          it always says N/A.
                                          Same for me actually šŸ™„
                                          SV Titanium Solar Forest
                                          freeheelerF 1 Reply Last reply Reply Quote 0
                                            freeheeler @MiniForklift
                                            @MiniForklift
                                            it was like that in the last couple of weeks, not sure about the root cause… we’ll see
                                            living sideways
                                            With your input, this post could be even better šŸ’—
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
