    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Fused track in extreme conditions?
    15 Posts 8 Posters 1.8k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • H Offline
      halajos Bronze Member
      The coming weekend I’ll run a race, which has a specialty of going into a cave for 2 km. I’ll be using performance mode. Will fused track be activated in this scenario? What kind of track to expect between the points of losing GPS signal and its recovery?
      a) an approximation of the track?
      b) a straight line?
      c) possibly weird artifacts?
      Does any of you have such experience with the S9B?
      isaziI Brad_OlwinB DMytroD L EgikaE 5 Replies Last reply Reply Quote 1
      • isaziI Offline
        isazi Moderator @halajos
        @halajos I’ve got no experience, but I’d like if you shared the results with us after.
        Blog: isazi's home
        H 1 Reply Last reply Reply Quote 1
        • H Offline
          halajos Bronze Member @isazi
          @isazi I will 😉
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @halajos
            @halajos Fused Track will not activate but the watch should use the information it has gathered on your running to approximate distance and pace.
            Vector/T6c/Vertical 2 Ti
            freeheelerF 1 Reply Last reply Reply Quote 0
            • DMytroD Offline
              DMytro @halajos
              @halajos sorry for off-topic, is this cave by chance in Europe?
              H 1 Reply Last reply Reply Quote 0
              • L Offline
                Likarnik Gold Members @halajos
                @halajos straightl line and probably it will count twice the distance. At least it does for me when I run through a tunnel. Except if you have old firmware before March 2021, it worker ok before 🙂
                • freeheelerF Offline
                  freeheeler @Brad_Olwin
                  @Brad_Olwin
                  would it help if @halajos switch battery mode just before the cave and switch back after?
                  …if so: I would practice the button “workflow” so you can concentrate on the trail and don’t look so much while pressing
                  living sideways
                  • H Offline
                    halajos Bronze Member @DMytro
                    @DMytro yes, in Hungary
                    M 1 Reply Last reply Reply Quote 1
                    • H Offline
                      halajos Bronze Member @Likarnik
                      @Likarnik double-counting is bad, I’d like to avoid. Probably could avoid it by using 'snap to route. I’ve got the track, which has a straight line between the two ends of the cave segment.
                      • EgikaE Offline
                        Egika Platinum Member @halajos
                        @halajos usually you would get a straight line between last and first position with GPS reception. Due to reflections there might be some artifacts (mis-calculations) noone can predict.
                        • M Offline
                          marcrie Bronze Member @halajos
                          @halajos but not in Balatonfüred on Sunday???
                          • H Offline
                            halajos Bronze Member @marcrie
                            @marcrie no, starting from Aggtelek on Saturday
                            • H Offline
                              @isazi the watch produced a straight line between the two ends of the cave and accounted the distance between the two points twice as @Likarnik suspected.
                              The ‘replay’ of the track in SA looks like this: The time difference between the last point before GPS signal was lost and the first point when it got recovered is only a few seconds (the cave section was about 2km, I’m not that fast 😀). When GPS signal recovered the watch added the distance between the two points, which is 2km, then it fast-forwarded to the correct time and added the 2km accumulated (probably taken from accelerometer data) during that period again.
                              EgikaE 1 Reply Last reply Reply Quote 1
                              • EgikaE Offline
                                @halajos uh? I thought this “tunnel double distance bug had been fixed some time ago?” are you using the latest FW?
                                @Dimitrios-Kanellopoulos
                                • H Offline
                                  halajos Bronze Member @Egika
                                  @Egika yes, my S9B is up to date
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
