    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Peak Pro?
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    1.5k Posts 145 Posters 737.2k Views 126 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Piotr GrygielP Offline
      Piotr Grygiel
      Snorkeling 😠
      Suunto Race 2
      Google Pixel 8 pro
      Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 1
      • Łukasz SzmigielŁ Offline
        Łukasz Szmigiel @Piotr Grygiel
        @Piotr-Grygiel ouch.
        S9PP 2.50.28
        • HighlandsH Offline
          Highlands
          As of yesterday the weather widget on the watch has stopped working and it says the same: sync with SA. Sync doesn’t solve it. Haven’t tried rebooting as the reboot didn’t solve it the first time. Do I have to reinstall the SA?
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Offline
            isazi Moderator @Highlands
            @Highlands are you sure you have location permissions for the app?
            Blog: isazi's home
            HighlandsH 1 Reply Last reply Reply Quote 0
              Highlands @isazi
              @isazi Thanks for chipping in. I hadn’t paid attention that I had disabled that setting.
              I guess, this means when I’m in the mountains without a phone, I won’t have correct data on the widget?
              Now the widget works as expected.
              • EgikaE Offline
                Egika Platinum Member @Highlands
                @Highlands said in Suunto 9 Peak Pro?:
                Correct. You need some online connection to update the weather forecast. How else should the watch know…?
                Offline in the mountains you still have the barometric pressure trend to judge yourself.
                Great!
                HighlandsH 1 Reply Last reply Reply Quote 1
                  Highlands @Egika
                  @Egika Totally makes sense.
                  When you open the weather widget on the watch, does the watch starts instant sync with the SA and refreshes instantly the data in the widget or you see unrefreshed data in the widget and in order to get refreshed data, first you need to unlock the phone and refresh the SA?
                  isaziI EgikaE 2 Replies Last reply Reply Quote 1
                  • isaziI Offline
                    @Highlands the widget syncs every now and then, and stores future forecast (not sure if 12, 24, or 48 hours).
                    Blog: isazi's home
                    HighlandsH 1 Reply Last reply Reply Quote 2
                    • EgikaE Offline
                      @Highlands maybe you want to have a look first.
                      Then you will see that the widget next to the weather forecast also is showing the time elapsed since last sync.
                        Highlands @isazi
                        @isazi I think I figured how it works - refreshing the SA refreshes the data in the widget as well but just going in the widget doesn’t readership the data in it. All in all, the widget works very well for me. Only have to figure how often it refreshes by itself if I don’t touch the SA.
                        @Egika Yes, when you scroll in the widget first thing you see is the time of sync. In my upper post I meant to ask whether if just going through the first page of the widget refreshes data but I wrote when you go in the widget. So, my bad.
                          Highlands
                          For the last update of the data in the weather widget it took a bit more than two hours. Then it got updated by itself without opening the SA.
                          Is it possible to send a sync request from the watch to the app without opening the SA?
                          • isaziI Offline
                            @Highlands the watch syncs itself, you do not need to open the app, but the forecast is not updated every minute 🙂 There are hours passing before a new update is available.
                            Blog: isazi's home
                              Highlands @isazi
                              @isazi I’m not expecting the watch to update the widget every minute. My question is, is there a way to tell the watch to update the widget without opening the app.
                              • isaziI Offline
                                @Highlands this is what I already said. The watch updates on its own when talking with the app, no need to open the app. If you trigger a manual sync opening the app, then of course the forecast is also updated. Also, the data itself is not updated every minute because weather forecasts do not work like that, update time from weather models are 3 hours or more, so there is no need for you watch to update more often than that.
                                Blog: isazi's home
                                  Highlands @isazi
                                  @isazi All this is more than clear to me. What I don’t know is, is there a way I can manually sync from watch to SA.
                                  Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                                    Łukasz Szmigiel @Highlands
                                    @Highlands the widget always displays latest forecast and there is no way to force sync from watch. Although in normal conditions, it shouldn’t update less often than once per three hours.
                                    It’s typically around 40 minutes in my case.
                                    S9PP 2.50.28
                                      Highlands @Łukasz Szmigiel
                                      @Łukasz-Szmigiel Thanks a lot for this clarification. Hopefully they add force sync from watch to SA in the next update(s).
                                      With my short Suunto experience, I appreciate any info I get from you, guys.
                                        @Highlands ok but why? Why would you want to force sync from the watch if it’s being automatically refreshed?
                                        S9PP 2.50.28
                                          @Łukasz-Szmigiel The automatic refreshing doesn’t happen frequently enough which on Friday gave me totally unreliable forecasting: the day was sunny and the widget was giving me raining. If I have to go in the SA to refresh it, before I get to the app itself, I’ll have had a look already at the widget of the weather app of my phone which gives more or less ok-ish data. And if the weather widget refreshes less often at say 2-3-4 hours, that’s not enough when the weather is more prone to changes. I noticed that if I go away from the phone and the BT disconnects, then when I come back and the BT reconnects, the weather widget updates. Ideally, it would be great if the watch force syncs to the app when you go to weather widget. Thus you know you get the latest possible data.
                                          Brad_OlwinB 1 Reply Last reply Reply Quote 3
                                          • Brad_OlwinB Offline
                                            Brad_Olwin Moderator @Highlands
                                            @Highlands There is a Suunto+ App for weather that should pull a current and projected forecast when you start an activity. Check it out, this may be what you need.
                                            Vector/T6c/Vertical 2 Ti
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
