    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Peak Pro?
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    1.5k Posts 145 Posters 645.2k Views 126 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • freeheelerF Offline
      freeheeler @Guest
      @skifun
      but you can setup custom battery mode, activate touch and then swipe back to the previous screen
      living sideways
      • ? Offline
        A Former User @freeheeler
        @freeheeler I need a back button to take me back to the watch face. But as I understand this is not possible.
        DMytroD EgikaE 2 Replies Last reply Reply Quote 1
        • DMytroD Offline
          DMytro @Guest
          @skifun no. There are only workarounds, which are: use touch, use small number of screens (like 3), use carousell ( data values on one screen are cycled through).
          Oh, sorry, I missunderstood. I thought you were speaking of going to the next screen and then returning to the previous one. For this case the above answer applies.
          • EgikaE Offline
            Egika Platinum Member @Guest
            @skifun back to watch face from a running activity currently is not possible
            • ? Offline
              A Former User
              Today morning during my walk activity I used the save CO2e Suunto plus app. Where in the app can I see the result of the CO2 saved? The activity is uploaded in the app.
              • Brad_OlwinB Offline
                Brad_Olwin Moderator @Guest
                @skifun said in Suunto 9 Peak Pro?:
                It should be marked as a Commute, if not use Suunto Commute Tag and the CO2 will show up in a widget in Suunto app but not on the watch.
                Vector/T6c/Vertical 2 Ti
                • ? Offline
                  A Former User
                  @Brad_Olwin Thanks, it worked.
                  • A Offline
                    Artyrekb @herlas
                    @herlas Hi, have you solved the GPS problem? I have the same problem in S9PP. At the beginning of each workout in nature, there is a sharp jump speed and pace.IMG_0530.jpg IMG_0533.jpg IMG_0536.jpg IMG_0535.jpg
                    freeheelerF 1 Reply Last reply Reply Quote 0
                      freeheeler @Artyrekb
                      @Artyrekb
                      you’re asking about strange speed and pace bumps at the beginning, but you post screenshots of your tracks. I guess you have also bad tracks when I look at these pics, correct?
                      how long do you wait before you start the activity, after the arrow in start screen is filled green?
                      I usually get bad tracks when I hit start too soon.
                      living sideways
                      ? A 2 Replies Last reply Reply Quote 1
                      • ? Offline
                        @freeheeler I know that I have to wait. But I’ve never had such bad tracks on my 9pp.
                        • ? Offline
                          A Former User
                          Is it there a way to predefine a Suunto plus app for an outdoor activity (doesn’t matter the activity), so that every time when I use that activity, it starts with the same Suunto plus app, so that I don’t have to go down the list every time and pick up this activity? When I start activity I want to press once the upper button, then scroll to the activity and press the middle button twice and have the activity started. If I want to change my own settings, then I’ll go down the menu and change what I want to change.
                          • U Offline
                            Ultrawalker
                            Where can i find my estimated fitness age on 9PP? Or in the app?
                            Suunto Spartan Ultra
                            Suunto 9 Peak Pro All Black
                            Suunto Vertical
                            isaziI DMytroD 2 Replies Last reply Reply Quote 0
                            • isaziI Offline
                              isazi Moderator @Ultrawalker
                              @Ultrawalker in the VO2max widget
                              Blog: isazi's home
                              ? 1 Reply Last reply Reply Quote 1
                              • DMytroD Offline
                                DMytro @Ultrawalker
                                @Ultrawalker I don’t think it’s present in SA
                                  @skifun Not yet.
                                  EfejotaE 1 Reply Last reply Reply Quote 1
                                  • A Offline
                                    Artyrekb @freeheeler
                                    @freeheeler hi. it’s always different. sometimes I click right after the green arrow appears, sometimes I wait a couple of minutes. I didn’t have that in S9B.
                                    zhang965Z 1 Reply Last reply Reply Quote 0
                                    • zhang965Z Offline
                                      zhang965 @Artyrekb
                                      @Artyrekb said in Suunto 9 Peak Pro?:
                                      If you want a good gps performance, you’d better wait the gps icon being green and stable, then begin the activity.
                                      Winners Wear Winners
                                      A 1 Reply Last reply Reply Quote 1
                                      • EfejotaE Offline
                                        Efejota Bronze Member @Brad_Olwin
                                        @Brad_Olwin “yet” sounds very good 😉
                                        • ? Offline
                                          A Former User
                                          Man, I even read the manual 😂
                                          • zhang965Z Offline
                                            zhang965 @Guest
                                            Welcome to Suunto community forum
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
