    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Peak Pro?
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    1.5k Posts 145 Posters 668.9k Views 126 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • mikekoski490M Offline
      mikekoski490 Bronze Member @wakarimasen
      @wakarimasen Can you post a photo of it with the different band?
      Past Suuntos: X-Lander/Observer/T6/X9/X10/X6HR/CORES/Ambits/Spartan/9P/9PP Ti/Vertical Ti
      Current: Suunto Race Ti
      Past other GPS watches: Polar Vantage V; Garmin 6X Pro Solar; Coros Vertix 2
      Suunto App running on Google Pixel 8/Android 14
      W 2 Replies Last reply Reply Quote 0
      • A Offline
        altcmd Silver Members
        Can one adjust the Guide data screens?
        isaziI 1 Reply Last reply Reply Quote 0
        • isaziI Offline
          isazi Moderator @altcmd
          @altcmd no, they are designed by the third party making the guides. Maybe something could be done for the SA workout creator.
          Blog: isazi's home
          A 1 Reply Last reply Reply Quote 1
          • W Offline
            wakarimasen Gold Members @mikekoski490
            @mikekoski490 will do!
            Suunto Race Titanium
            Suunto Ambit3 Peak
            Polar H10
            Polar OH1
            • A Offline
              altcmd Silver Members @isazi
              @isazi that would be awesome as a one-size-fits-all approach is not ideal. For instance, for an interval workout, TP shows avg target HR when I would rather see the actual range.
              herlasH 1 Reply Last reply Reply Quote 0
              • herlasH Offline
                herlas Silver Members @altcmd
                @altcmd indeed not one fits all, I found that avg value in TP workout really useful, I do 400m track intervals based on 120% of Stryd CP, and reviewing the avg power tells me if I hit the target or not. I mostly use TP guides for this type of workout
                SRS Ti
                SRun (primarily road runner so testing SRun is a must ;))
                A 1 Reply Last reply Reply Quote 0
                • A Offline
                  altcmd Silver Members @herlas
                  @herlas Good to hear it works for you. Unfortunately for me, hitting a single number is more difficult than keeping to a range that is visible on the watch. Plus there is the absense of out-of-target-range vibration/tone which I understand is being added to the next update.
                  • isaziI Offline
                    @altcmd said in Suunto 9 Peak Pro?:
                    I am not aware of this being added to next update, I only know this has been communicated as something most people want.
                    Blog: isazi's home
                    A KetoohsK 2 Replies Last reply Reply Quote 0
                    • A Offline
                      @isazi Got it - thanks for the clarification.
                      • KetoohsK Offline
                        Ketoohs Silver Members @isazi
                        @isazi Killjoy 😁
                        Karoo3 (2024)
                        Vertical allBlack (2023)
                        9 Peak Black (2022)
                        Spartan WHR Black (2017)
                        Ambit 2 Black (2013)
                        • Ɓukasz SzmigielƁ Offline
                          Ɓukasz Szmigiel
                          Assuming that I have standby set to adaptive and rise to wake to enabled - when does the standby kick in? It seems to me that in such configuration only the regular backlight works? Or does the backlight ignore the brightness setting (low, mid, high) and light up according to light sensor readings?
                          S9PP 2.50.28
                          • isaziI Offline
                            isazi Moderator @Ɓukasz Szmigiel
                            @Ɓukasz-Szmigiel with raise to wake enabled that has precedence over everything, so backlight is off and only turns on when you move your wrist.
                            Blog: isazi's home
                            Ɓukasz SzmigielƁ 1 Reply Last reply Reply Quote 1
                              Ɓukasz Szmigiel @isazi
                              @isazi oh OK. So in order to use standby I’d have to disable rise to wake? Do you have any idea if it was considered to add rise to wake “only when not in workout”? So that rise to wake is used in time mode but standby in workout mode?
                              S9PP 2.50.28
                              • EgikaE Offline
                                Egika Platinum Member @Ɓukasz Szmigiel
                                @Ɓukasz-Szmigiel just use raise to wake as your normal setting.
                                In the activity options available before the start and during the activity, there is a separate option to enable the backlight constantly.
                                Ɓukasz SzmigielƁ 1 Reply Last reply Reply Quote 0
                                  Ɓukasz Szmigiel @Egika
                                  @Egika I know, but such backlight is strong, isn’t it? I prefer very dim backlight for workouts as it doesn’t leave an afterglow.
                                  S9PP 2.50.28
                                  • A Offline
                                    Updated to 2.18 on iOS but am not seeing the supposed two new widgets as claimed in the update.
                                    • Brad_OlwinB Offline
                                      Brad_Olwin Moderator @altcmd
                                      @altcmd What widgets?
                                      Vector/T6c/Vertical 2 Ti
                                      • A Offline
                                        altcmd Silver Members @Brad_Olwin
                                        @Brad_Olwin description says Ascent and Minimum HR last 7 days.
                                        lexterm77L 1 Reply Last reply Reply Quote 0
                                        • lexterm77L Offline
                                          lexterm77 Bronze Member @altcmd
                                          @altcmd
                                          Thats SA widget, not related to S9PP.
                                          omunozO A 2 Replies Last reply Reply Quote 1
                                          • omunozO Offline
                                            omunoz Silver Members @lexterm77
                                            @lexterm77
                                            I’m this new SA version appear for S9PP the possibility to put the widget’s with the order that you like .
                                            The main page of SA have new dashboard of heart ❀ : Resume new dashboard
                                            • Tags.
                                            • Sunto Plus+ Data in the workout
                                            Watches: SV Fw: 2.50.28
                                            SR2 Fw: 2.53.42
                                            IPhone 17 (Sim) IOS 26.5.1
                                            macOS Tahoe 26.5.1 M1 & M2
                                            Apps IOS: 3.11.0 (22452)
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
