    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Peak Pro?
    Scheduled Pinned Locked Moved Suunto 9 Peak Pro
    1.5k Posts 145 Posters 731.5k Views 126 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Online
      dulko79 @Guest
      @mountainChris matte titanium is perfect finish for my taste. Enjoy your watch. šŸ¤—
      App: beta
      Phone: Iphone
      iOS
      • DuÅ”an KovićD Offline
        DuÅ”an Ković
        Agree for vibration, it is a bit stronger but the vibration itself is loud, like cheap loud.
        SR2
        SA latest beta
        Polar Verity Sense
        Polar H10
        Vivo x300 Pro
        • K Offline
          krakra Bronze Member @isazi
          @isazi ā¤
          isaziI 1 Reply Last reply Reply Quote 0
          • isaziI Online
            isazi Moderator @krakra
            @krakra I always report to Suunto bugs and comments, even when they don’t affect me šŸ™‚
            Blog: isazi's home
            1 Reply Last reply Reply Quote 4
            • freeheelerF Offline
              freeheeler @DuÅ”an Ković
              @DuÅ”an-Ković said in Suunto 9 Peak Pro?:
              But that should be written in huge letters on the box
              I usually don’t read this part of the manual either šŸ˜‰
              … sometimes it would be interesting to read the ā€œwhyā€ šŸ™‚
              living sideways
              EfejotaE K 2 Replies Last reply Reply Quote 2
              • EfejotaE Offline
                Efejota Bronze Member @freeheeler
                @freeheeler You are right, but I would have understood it as the typical general warning. I guess that some of the S9PP users will come from the S9P and may have spare cables. Being apparently the same, I would recommend to specifically warn about the risk of using the older cable or any other with strong magnets. Maybe it is not so difficult to do in the online web.
                IMO
                J
                freeheelerF isaziI 2 Replies Last reply Reply Quote 1
                • ? Offline
                  A Former User
                  Sleep HR values extraordinary high, especially in the beginning where is deep sleep. I think there could be something wrong. Not comparable with S9B. I also have interruptions during sleep. Graph shows gaps. Which value is displayed in warming up phase of sensor in HR widget? Average from last measure? Is this counted in? Think this will be corrected. Still early days with S9PP.
                  The number on the widget is always jumps up in the beginning in first 1-2s and after 10-20s it falls to correct values…
                  D 1 Reply Last reply Reply Quote 0
                    freeheeler @Efejota
                    @Efejota
                    fully agree!
                    if you can damage a product with an accessory from the same supplier, to me (personally!) it would be mandatory to either put a huge warning sign on the accessory itself or better: design the new interface so it doesn’t accept the potentially dangerous accessory.
                    that’s my own view from machine engineering perspective
                    edit: it is solved by software, as we have learned only short time later šŸ™‚ šŸ‘
                    living sideways
                    M ? 2 Replies Last reply Reply Quote 7
                    • K Offline
                      krakra Bronze Member @freeheeler
                      @freeheeler i ineed grap old s9p cable and use it but i got error on watch that i should use original cable. Did i damaged battery, or any other part of watch. 🤯😱
                      sartoricS isaziI 2 Replies Last reply Reply Quote 0
                      • sartoricS Offline
                        sartoric Moderator @krakra
                        @krakra
                        I suppose you didn’t, as you didn’t get any other error message 😁
                        SVTS - 2.50.28
                        SSSWHR BARO Amber - 2.8.32
                        Samsung A5 2016 - Android 7.0
                        Suunto App Android 6.11.12 beta
                        • isaziI Online
                          isazi Moderator @Efejota
                          @Efejota there is NO risk for the user. If they connect the old charger, a screen comes up saying something like ā€œCHARGER NOT COMPATIBLE REMOVEā€. And that’s it.
                          Blog: isazi's home
                          • isaziI Online
                            @krakra no that error message is there for this exact reason, to let you know that you cannot charge with the old cable.
                            Blog: isazi's home
                              DuÅ”an Ković @Brad_Olwin
                              @Brad_Olwin said in Suunto 9 Peak Pro?:
                              @DuÅ”an-Ković The strong magnet charger for the S9Peak can brick the 9Pro so don’t use it. The 9Pro won’t accept charging from that adaptor for the reasons @isazi described.
                              @isazi said in Suunto 9 Peak Pro?:
                              We have two conflicting opinions.
                              Are magnets a problem or not? Will the watch brick?
                              SR2
                              SA latest beta
                              Polar Verity Sense
                              Polar H10
                              Vivo x300 Pro
                              isaziI EgikaE 2 Replies Last reply Reply Quote 0
                              • isaziI Online
                                isazi Moderator @DuÅ”an Ković
                                @DuÅ”an-Ković what two conflicting opinions, @Brad_Olwin said exactly that yesterday, that if you connect the S9PP to the old cable it will not charge and give you a warning.
                                Blog: isazi's home
                                DuÅ”an KovićD 1 Reply Last reply Reply Quote 0
                                  DuÅ”an Ković @isazi
                                  @isazi He also said that watch will brick = die - not be usable again. Than you said there is NO risk for the user
                                  SR2
                                  SA latest beta
                                  Polar Verity Sense
                                  Polar H10
                                  Vivo x300 Pro
                                  isaziI M 2 Replies Last reply Reply Quote 0
                                  • isaziI Online
                                    @DuÅ”an-Ković I said there is no risk because the watch will tell you that it cannot charge with the old cable. Suunto put in place this software measure to avoid people using the old cable, so people will not use the old cable (because it cannot charge your new watch) and there will be no harm.
                                    Blog: isazi's home
                                    freeheelerF Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                    • EgikaE Offline
                                      Egika Platinum Member @DuÅ”an Ković
                                      Technical explanation:
                                      The GPS chip in the watch could be damaged Edit: rendered unusable in the case of:
                                      Charger with strong magnet attached
                                      AND
                                      Charge current flowing.
                                      As the watch is detecting the old charger it will show the warning and at the same time not start the charging current to flow. So everything is safe.
                                      Mff73M EfejotaE 2 Replies Last reply Reply Quote 5
                                      • M Offline
                                        MoeJito Bronze Member @freeheeler
                                        @freeheeler A much easier/safer way would be to pull the hazardous accessory from the market and replace the charger included in the S9P set with the new one.
                                        S9PP
                                        FR 935
                                        FR 210
                                        T6D
                                        T3D
                                        isaziI S 2 Replies Last reply Reply Quote 0
                                        • isaziI Online
                                          isazi Moderator @MoeJito
                                          @MoeJito please just read all messages and learn that nothing will happen to your new watch with an old charger, it will not even charge!
                                          @Brad_Olwin was talking about watch prototypes before the new charger was even designed and produced!
                                          Blog: isazi's home
                                          1 Reply Last reply Reply Quote 3
                                          • S Offline
                                            Spree Bronze Member @MoeJito
                                            @MoeJito Where do you get this impression that it would be ā€œeasierā€?
                                            With your input, this post could be even better šŸ’—
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
