    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 way out on descent and ascent
    2 Posts 2 Posters 310 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • B Offline
      Boris786
      I suspect this may be a wider issue than just for the Suunto 9.
      My Suunto 9 is measuring up and down very poorly - it is underestimating by between a third and a fifth.
      I have noticed this on cycling mode but I suspect it is the case more generally.
      I have followed the Suunto advice and synch regularly and have set to performance and use GPS+QZSS+Galileo.
      I have done one or two events where the descends and ascents have been know and it is consistently inaccurate against Komoot and other apps.
      Is there anything I can do about this and would a baro version be better (plenty of criticism of that which surprises me) or even switching to a different make?
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Boris786
        @Boris786 you may have a clogged or broken sensor. I do not have this issue. Do you have the baro or non-baro model? Never mind, the non-non-baro is ok on large hills but is poor on small rolling hills. Not much can be done for this
        Vector/T6c/Vertical 2 Ti
        Register Login
        • First post
          Last post
        Suunto Terms | Privacy Policy
