    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Body resources random increase!!
    Scheduled Pinned Locked Moved Suunto 7
    11 Posts 6 Posters 945 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • BinoWorld UKB Offline
      BinoWorld UK Bronze Member
      Folks
      Anyone noticed a body battery increase after a plain restart of the S7?!
      Mine had 16% and straight after the restart it was 44%. Abnormal!
      Can this be rectified?
      ? ChrisAC 2 Replies Last reply Reply Quote 0
      • ? Offline
        A Former User @BinoWorld UK
        @BinoWorld-UK Yes, happens for me regularly. I restarted at 0% and now I’m at 38%.
        BinoWorld UKB 1 Reply Last reply Reply Quote 1
          BinoWorld UK Bronze Member @Guest
          @Metalmi we need a fix for this @Brad_Olwin.
          What do you think?
          Cheers
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @BinoWorld UK
            @BinoWorld-UK said in Body resources random increase!!:
            What do you think?
            Cheers
            I need to wear mine to see. I don’t recall this happening. However, a restart will clear memory and default to 50% until a new reading. Best not to restart.
            Vector/T6c/Vertical 2 Ti
            • ? Offline
              A Former User @Brad_Olwin
              @Brad_Olwin If I remember correctly, it was that it defaults to 70% if you don’t wear it for few hours, and not charging it.
              freeheelerF BinoWorld UKB 2 Replies Last reply Reply Quote 0
              • freeheelerF Offline
                freeheeler @Guest
                @Metalmi
                S9B goes to 50% always (not wearing, charging) and S7 is similar (or equal) if I remember from last winter
                living sideways
                • ChrisAC Offline
                  ChrisA Platinum Member @BinoWorld UK
                  @BinoWorld-UK that’s what all my Suuntos (S5s S9s and can’t remember S7) did after restarting or recharging them - they default to 50% . If you wear if for some hours it nearly comes down to the level you had before. I would prefer, that it starts at the same level again it had when you restarted/ recharged it. Don’t know if Suunto can fix it, since the resources metrics comes from Firstbeat (afaik).
                  Currently Race I
                  • ? Offline
                    A Former User @freeheeler
                    @freeheeler S7 doesn’t change resources when charging, at least for me. Tested - I charge it every day. That wouldn’t make any sense if it did - resources would be completely unusable.
                    BinoWorld UKB 1 Reply Last reply Reply Quote 0
                      @Metalmi that’s correct, it doesn’t change if on the charger for less than an hour I believe.
                        @Metalmi Not at all, I don’t wear my S7 all day and it predicts the drop based on my past history. I did this vs my Garmin Fenix 6 worn and I found the S7 to lose the same amount my Fenix did whilst sat at my desk.
                        • István TörökI Offline
                          István Török
                          It’s been a year, I just purchased a 9Peak Pro and experienced the same issue, after a simple restart Resources defaults back to 50% from 16. Latest software so clearly hasn’t been fixed. Makes Resources useless in my opinion.
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
