    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Open water swimming mode customization – swim distance always zero and no temperature
    Scheduled Pinned Locked Moved Suunto 9 Peak
    18 Posts 6 Posters 2.6k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • B Offline
      bbx100 Bronze Member
      Hi,
      When I try to customize Open water swimming sport mode to show temperature and swim distance fields it doesn’t work. It shows swim distance field always 0 and doesn’t display temperature field at all.
      I had the same problem regarding the swim distance field on my old spartan baro, but it at lest showed sea temperature. So this problem is worse than on my old spartan baro
      Btw temperature reading in altitude/temp screen works OK and soft reset didn’t help
      Here is my old post regarding the swimm distance field
      https://forum.suunto.com/topic/4735/open-water-swimming-mode-customization-swim-distance-always-zero?_=1655921583073
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @bbx100
        @bbx100 temperature should be fixed in next update (if I’m not wrong), using the weather S+ app gives temperature in the meanwhile.
        Which field are you adding for distance?
        Blog: isazi's home
        PavlasP B Piotr GrygielP 3 Replies Last reply Reply Quote 0
        • PavlasP Away
          Pavlas @isazi
          @isazi Today my watch showed the temperature during outdoor swimming, but only after 7 minutes of swimming. Maybe after the temperature stabilized? Maybe it’s just showing the average temperature?
          🔺Vertical All Black
          ex:
          Ambit2 Black
          Ambit3 Peak Sapphire
          Spartan Ultra Stealth Titanium
          S9B All Black
          Ocean All Black (for testing only)
          >>> YouTube Channel <<<
          B 1 Reply Last reply Reply Quote 0
          • B Offline
            bbx100 Bronze Member @isazi
            @isazi Ok thx for info about temperature bug. Regarding swim distance field I use field called “Swim distance”. As I noticed swim distance field on the watch shows always 0, but after sync with the phone swim distance is shown in the app ok. It is just not shown on the watch so when you swim it is always 0. I fixed it on my old Spartan in a way that I used regular distance field which showed distance in km rather than meters as swim distance should. I’m suprised that this bug is still not fixed for 2 years after I reported it on this forum
            • B Offline
              bbx100 Bronze Member @Pavlas
              @pavlas On my old Spartan baro it worked OK. You had temperature and average temperature fields. Temperature showed sea temp continuously and you could see changes as watch cooled to ambient temp. It is very useful to see what is sea temperature when you swimm…
              Average temperature filed would show average temp…
              PavlasP 1 Reply Last reply Reply Quote 0
              • PavlasP Away
                Pavlas @bbx100
                @bbx100 Yeah, it was the same on the S9. But since a certain update, it’s been acting weird. It’s been discussed here a few times.
                🔺Vertical All Black
                ex:
                Ambit2 Black
                S9B All Black
                >>> YouTube Channel <<<
                • Piotr GrygielP Offline
                  Piotr Grygiel @isazi
                  @isazi said in Open water swimming mode customization – swim distance always zero and no temperature:
                  I do not believe 😢
                  (GNSS does not work underwater).
                  Suunto Race 2
                  Google Pixel 8 pro
                  • isaziI Offline
                    isazi Moderator @Piotr Grygiel
                    @piotr-grygiel it should already be fixed in testing firmware, to be honest. And temperature has nothing to do with GPS 😄
                    Blog: isazi's home
                    Piotr GrygielP 1 Reply Last reply Reply Quote 1
                      @isazi Topic is about swimming distance and temperature 😋
                      Suunto Race 2
                      Google Pixel 8 pro
                      • isaziI Offline
                        @piotr-grygiel the issue is that open water swim uses distance, not swimming distance, because swimming distance is pool length multiplied per turns, and that does not work in OWS, which uses GPS instead. It is not an issue, it is by design. As for temperature, as I said should be fixed very soon.
                        Blog: isazi's home
                        B Z 2 Replies Last reply Reply Quote 0
                        • B Offline
                          @isazi Ok thank you for clarification regarding swimming distance but it is not clear from the name of the field that it is only for swimming pool. I hope that temperature will be fixed soon as you said
                          • B Offline
                            As somebody noticed in previous posts, S+ Weather screen seems to solve a problem as a workaround. If you activate this screen (Weather) and if you return to screen where temp field is displayed than it works ok, it shows temp. It seems like a temp sensor is off when you start activity and if you activate S+ Weather than it turns on… this is the bug
                            1 Reply Last reply Reply Quote 3
                            • Z Offline
                              zucchero @isazi
                              @isazi Today I noticed for the second time that the Open Water distance shown on my Race is 0m, which is wrong, and after searching I found this thread. I understand that for pool swimming the swimming distance is pool length multiplied per turns. But in Open Water GPS could be used to show a distance greater than 0m. Is it a bug on the Race or what could be the reason?
                              EgikaE isaziI 2 Replies Last reply Reply Quote 0
                              • EgikaE Offline
                                Egika Platinum Member @zucchero
                                @zucchero a 3min swim? Also no temperature logged?
                                where and how long did you swim?
                                Did you have a GPS fix before entering the water (green arrow)?
                                Z 1 Reply Last reply Reply Quote 0
                                • isaziI Offline
                                  isazi Moderator @zucchero
                                  @zucchero the bug for 0 distance in the pool has been found and fixed (as far as I know) and will be available in next update. For openwater, as in your case, do you have the track available in the app?
                                  Blog: isazi's home
                                  • Z Offline
                                    zucchero @Egika
                                    @Egika The 3 min have only been a test swim, but the issue was indeed that I did not wait for the green GPS arrow. I already was outside near the lake far away from tall buildings and I thought the watch already has a GPS signal.
                                    • Z Offline
                                      zucchero @isazi
                                      @isazi Issue solved. See above. User error. 😢
                                      When I start an activity like my swim without a GPS signal and, if the watch gets a GPS signal a few minutes later, does it then track the distance?
                                      • EgikaE Offline
                                        @zucchero said in Open water swimming mode customization – swim distance always zero and no temperature:
                                        It should do so
                                        Register Login
                                        • First post
                                          Last post
                                        Suunto Terms | Privacy Policy
