    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9B keeps forgetting Verity Sense/H10
    20 Posts 12 Posters 2.2k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • wmichiW Offline
      wmichi
      Hello, I have a S9 Baro, Polar Verity Sense and Polar H10. My watch always forgets the paired HR sensor after every training session. This is my “workflow”:
      1. I pair the the Verity Sense
      2. I start a training session using the paired Verity Sense and do my thing (all works fine, no issues)
      3. Finish training and sync the watch
      4. I start another training session -> Verity Sense can not be found, although it is the last used HR sensor
      5. So I pair the Verity Sense again
      6. I start a training session using the paired Verity Sense and do my thing (again everything works fine)
      7. Finish ans sync the watch
      8. Guess what comes now… the watch forgot the paired sensor
      I think I have paired my Verity Sense hundreds of times because the watch always forgets this sensor. And it’s the same with the H10.
      I have disabled all goodies on the Polar sensors (ANT+, multiple BLE connections) and they are definitely not connected to anything else (no other watch, no smartphone). The sensors have the latest firmware installed (also the S9)
      I had the exact same issue with the Suunto 9 Peak (which I have sold). With Garmin and Polar watches everything works fine. So it seems to be a Suunto issue. Has anyone similar experience and maybe a solution? 🙂
      Agustin Gonzalez Perez CorralA DMytroD freeheelerF inkognitoI 4 Replies Last reply Reply Quote 0
      • Agustin Gonzalez Perez CorralA Offline
        Agustin Gonzalez Perez Corral @wmichi
        @wmichi I feel your pain. VERY annoying.
        • DMytroD Offline
          DMytro @wmichi
          @wmichi don’t have those sensors, but everything worked fine with a decathlon HR strap, so is the suunto one. Maybe it somehow depends on the sensor itself?
          • freeheelerF Offline
            freeheeler @wmichi
            @wmichi
            I’ve had the issue with my S9B, too, but only once.
            I’m not sure if it is a watch or a sensor issue? I’ll check if syncing to polar (by laptop and phone) could worsen the situation.
            If I notice it happening again with my watch, I’ll let you know.
            living sideways
            • wmichiW Offline
              wmichi
              Thanks for your feedback everyone. I am sorry to hear that I am not the only one.
              @freeheeler As far as I can tell, this does not make any difference. It also makes no difference, If I activate the multiple BLE connections of those sensors and use both my Polar and the Suunto watch.
              Maybe Suunto should think about the sensor management and make it a little bit less crappy cumbersome.
              freeheelerF sartoricS 2 Replies Last reply Reply Quote 0
              • inkognitoI Offline
                inkognito Platinum Member @wmichi
                @wmichi My Verity Sense works great with my S9 without any such issue 🤔
                SV: fingers crossed :D
                S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
                Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
                Despite some pretty bad luck, I still love Suunto!
                  freeheeler @wmichi
                  @wmichi
                  I’m not sure if it is a Suunto issue, as my previous Suunto chest belt connected without any issues
                  living sideways
                  • sartoricS Offline
                    sartoric Moderator @wmichi
                    @wmichi
                    Did you try a soft reset ? Maybe there’s just something stuck.
                    SVTS - 2.50.28
                    SSSWHR BARO Amber - 2.8.32
                    Samsung A5 2016 - Android 7.0
                    Suunto App Android 6.11.8 beta
                    • pilleusP Offline
                      pilleus
                      S9B and Verity Sense/H10 and no problems until now. 👍
                      https://www.instagram.com/moves.are.life/
                      Suunto Vertical Black Lime
                      Suunto 9 Peak Pro Black
                      Suunto Spartan Ultra Stealth Titanium
                      • wmichiW Offline
                        wmichi
                        I tried soft resets and factory resets on the Baro and the Peak without success. Maybe only newer devices are affected? I have the Suunto 9 Baro Granite Blue Titanium… Or the problem is not the watch but the sensor(s). I don’t know. I will contact support.
                        Mff73M 1 Reply Last reply Reply Quote 0
                        • Mff73M Offline
                          Mff73 @wmichi
                          @wmichi
                          are you 100% sure these sensors are not paired with something else which stole the connection after each activity ?
                          SSU (retired), SV1, SV2
                          Wife : S9PP
                          SA: Always the latest beta :)
                          Android + Galaxy S205G
                          wmichiW 1 Reply Last reply Reply Quote 1
                          • Mitch9M Offline
                            Mitch9 Silver Members
                            For me the combination S9B and Polar H10 works without connection problems.
                            Watch: Suunto Vertical Titanium Solar (Sand)
                            SA: Android (beta)
                            HRS: Polar H10
                            • wmichiW Offline
                              wmichi @Mff73
                              @mff73 Yes, 100% sure.
                              I went into the basement out of reach of every other bluetooth device and tried to switch back and forth between the sport selection screen and the screen that follows (where you wait for gps signal and actually start the activity). Out of 10 tries, 8 times the watch could not connect to the paired Verity Sense. It worked 2 times
                              The same with H10: 7 out of 10 without success. 🙂
                              So it does work sometimes.
                              cosme.costaC inkognitoI 2 Replies Last reply Reply Quote 0
                              • cosme.costaC Offline
                                cosme.costa @wmichi
                                @wmichi This is very strange, I’m using my Polar OH1 wilth my S9B without any problem for nearly two years. It has never failed me, not once, and I use it at least 4 times per week. The same before with my Polar H10.
                                Could be an issue with the watch Bluetooth module? Yes, but if you had the same problem with the S9P I guess we are looking for an external issue here, would be very strange that both watches have the same issue.
                                What I would do is Check if I’m in the latest firmware with the sensors and softreset the watch, if the issue persists I would do a watch hard reset, and if it still continues failing I would contact support.
                                  @wmichi I am terribly sorry for this stupid trivial question, but someone had to ask: What is your real workflow? Because, according to my experience, Verity Sense takes like 10-20 seconds to initialize. Aren’t you just too fast? 😄 I put my verity sense on, I turn it on, then I wait like 20 seconds and only after that I go to “Excercise” in my watch. If you select “Excercise” before the sensor is fully on, watch won’t find it… The same is valid for H10. First you put it on and make sure electrodes are wet, then you wait couple of seconds and then you enter the excercise menu. Perhaps other watches search for sensors continuously, but Suunto 9 seems to check for HR sensor only once (when you enter “Excercise”).
                                  And for that workflow you described originally: does it also happen when you start second exercise immediately after you finish the first one? Or does it happen only when you do the second exercise another day or such?
                                  wmichiW 1 Reply Last reply Reply Quote 3
                                  • wmichiW Offline
                                    wmichi @inkognito
                                    @inkognito That’s no stupid question 🙂 And maybe this could be the reason, good point. I don’t think I am too fast with going into exercise mode, but I will try to slow down 😉
                                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                                      Dimitrios Kanellopoulos Community Manager @wmichi
                                      From what I know it takes time to lock to a device that does not provide accurate readings or has a good signal.
                                      I know you can reset the h10 via using the battery vice versa (check polar website ) , try that and try using a new battery. Make sure the battery is not expired.
                                      If that is still happening , let’s check the logs.
                                      I asked about the h10 because there I am sure there is no problem.
                                      Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                                      wmichiW 1 Reply Last reply Reply Quote 0
                                      • wmichiW Offline
                                        wmichi @Dimitrios Kanellopoulos
                                        @dimitrios-kanellopoulos I tried today what @inkognito suggested. I put the Verity Sense on my arm, turned it on, waited a minimum of 20s and then went to “Excercise” and selected my sport profile -> Verity Sense connected. I did this a couple of times, and it worked every single time.
                                        It’s like @inkognito said: the S9 doesn’t seem to check for paired Sensors continuously, and if the Sensor is not ready, the S9 never finds it. I guess it’s the same with the H10 (haven’t tried it yet).
                                        Thanks @inkognito 🙂
                                        @Agustin-Gonzalez-Perez-Corral Maybe this works for you too?
                                        freeheelerF MdzOttM 2 Replies Last reply Reply Quote 3
                                          freeheeler @wmichi
                                          @wmichi
                                          I observed that it must be the other way around, that the sensors take some time before they are ready. S9B shows the HR belt signs right away when there’s a sensor available… but anyway, it’s a detail and I might be wrong 😉
                                          happy to see that you could finally sort it out 😀 👍
                                          living sideways
                                          • MdzOttM Offline
                                            MdzOtt @wmichi
                                            @wmichi it might depend on the sensor. I used to use the Suunto HR belt and now I use the Wahoo HR and cadence sensors, and I find that if I start the exercise, even with the sensors not ready, eventually (after 20-30 s), they show up. This might be because some sensors stay “visible” for BT connection only for a limited time (30 - 60 s), and if they are not connected they stop being visible.
                                            R2
                                            S9 Baro
                                            SA on Android
                                            Ambit 3 Peak
                                            Ambit 2 Sapphire
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
