    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Extension strap for S9/S9Baro
    4 Posts 3 Posters 496 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • MdzOttM Offline
      MdzOtt
      A simple question: anyone has a solution for extending the S9B strap to make it easier to wear the watch on the outside of clothing (e.g. on the outside of the sleeve of a ski jacket)? My preferred choice would be an extension strap. Any source for that?
      R2
      S9 Baro
      SA on Android
      Ambit 3 Peak
      Ambit 2 Sapphire
      DMytroD N 2 Replies Last reply Reply Quote 0
      • DMytroD Offline
        DMytro @MdzOtt
        @mdzott which strap do you have right now?
        There’s this strap available in two sizes:
        https://www.suunto.com/de-de/Produkte/Armbander/suunto-24-mm-athletic-1-silikonarmband/suunto-24-mm-athletic-1-silikonarmband-white-steel-grobe-m/
        And there are also diving straps compatible with S9 that have even bigger length.
        MdzOttM 1 Reply Last reply Reply Quote 0
        • N Offline
          nseslija Bronze Member @MdzOtt
          @mdzott I’m using this Suunto strap when I need to wear the watch over my fleece jacket.
          https://www.suunto.com/Products/Straps/suunto-24mm-explore-2-textile-strap/suunto-24mm-explore-2-textile-strap-black-black-size-ml/
          Ambit 2S
          Ambit 3 Peak
          Suunto 9 baro
          Suunto Vertical Ti Solar
          • MdzOttM Offline
            MdzOtt @DMytro
            @dmytro, @nseslija thanks for the replies. I have the standard strap that came with the watch. I am thinking about the diving strap, but that would be too long for normal use. This is why I thought about an extension. I need a really long strap to put the watch over the sleeve of the ski jacket (you need some bulk when you ski at -25 C - -30 C). For XC I can squeeze the sleeve enough, even if with some difficulty (the 3rd hand would be handy).
            R2
            S9 Baro
            SA on Android
            Ambit 3 Peak
            Ambit 2 Sapphire
            Register Login
            • First post
              Last post
            Suunto Terms | Privacy Policy
