    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    SSWHRB Run Interval setting not working!
    Scheduled Pinned Locked Moved Spartan
    35 Posts 7 Posters 6.4k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • D Offline
      Darren_M Bronze Member
      The Running interval setting on my SSWHRB doesn’t work. When it reaches the rest period it doesn’t vibrate or sound a tone to warn me that the interval has switched to the rest period, therefore it’s useless. Is this a known problem or am I missing something? Other than the settings for vibration, I can’t find anything else that could cause it not to work properly.
      Dimitrios KanellopoulosD Brad_OlwinB 2 Replies Last reply Reply Quote 0
        Dimitrios Kanellopoulos Community Manager @Darren_M
        @darren_m very strange. I suppose you have on settings tones -> On (or buttons off) and vibration on (as you mentioned)
        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
        D 1 Reply Last reply Reply Quote 0
        • sartoricS Offline
          sartoric Moderator
          I use intervals and the watch vibrates as expected (I disabled tones and vibration is off for buttons).
          Please forgive me for the question but it’s just to better understand.
          Did you start the interval or just the activity ?
          • Brad_OlwinB Offline
            Brad_Olwin Moderator @Darren_M
            @darren_m I assume you have the intervals turned on, you must start them, which it sounds like you have done. Mine works perfectly but there are settings for both vibration and tones. I usually have both on for intervals.
            Vector/T6c/Vertical 2 Ti
            • D Offline
              Darren_M Bronze Member @Dimitrios Kanellopoulos
              @dimitrios-kanellopoulos Yes that’s correct, Buttons off for tones and vibration, but originally I had vibration ON. I altered it in case there was a glitch for that sub setting. Still no good though.
              • D Offline
                Darren_M Bronze Member @Brad_Olwin
                @brad_olwin Forgive me, I need to clarify what you mean by this. Am I doing this right?
                I go to Running intervals
                Swipe down to Intervals and switch it on
                Set Repetitions.
                Set interval to duration, and alter the time.
                Set Recovery to duration, and alter the time
                Swipe up and start the activity.
                Is this correct?
                Thanks!
                sartoricS 1 Reply Last reply Reply Quote 0
                • sartoricS Offline
                  sartoric Moderator
                  This post is deleted!
                  • sartoricS Offline
                    sartoric Moderator @Darren_M
                    @darren_m
                    you miss the last step, after you start the activity.
                    Start the interval training, swiping all to the left (going to the right 🙂 )
                    http://www.suunto.com/en-GB/Support/Product-support/spartan_sport_whr_baro/spartan_sport_whr_baro/features/interval-training/
                    • Gabriel.SG Offline
                      Gabriel.S
                      when you start your activity you need to go to the interval screen and launch it by the upper button.
                      Phone: Blackview 9500 android 8.1
                      Watches: S9 baro & ambit run
                      S9 on SA… a lot of features are still missing
                        Gabriel.S
                        Damn, not enough fast lol.
                        • D Offline
                          • D Offline
                            Phew!
                            Thanks everyone. Thankfully it was just my incompetence that was the problem. It’s working fine!
                            Once the timing complete screen appears? Do I just go back to the activity screen and save there?
                            Much appreciated!
                            Dimitrios KanellopoulosD sartoricS 2 Replies Last reply Reply Quote 2
                              @darren_m yes. Because when it’s complete the upper button will restart it.
                              • sartoricS Offline
                                @darren_m
                                You’re welcome … I must confess that I faced a similar issue at the beginning, waiting for intervals to start automatically 😉
                                In fact it’s a bit tricky.
                                then I went back to the old rule … RTFM 😄
                                • D Offline
                                  @dimitrios-kanellopoulos Thanks for your help!
                                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                    @darren_m you are most welcome man. Enjoy.
                                    • J Offline
                                      John Lawson 0
                                      I actually prefer Suntos way of doing intervals. Instead of just starting automatically, one can do a free form warm up before the interval training starts. Most of my workouts are interval based and I really like that you can do several different interval drills in one workout. Just dive into settings and change the times or distances.
                                      Luís PintoL Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                                      • Luís PintoL Offline
                                        Luís Pinto Platinum Member @John Lawson 0
                                        @john-lawson-0 Strongly disagree if you allow me.
                                        SR
                                        Site (gr7vel spin): https://youtube.com/channel/UCfHM0mXWS8S61h70Rzj9mfA
                                          Dimitrios Kanellopoulos Community Manager @John Lawson 0
                                          @john-lawson-0 I strongly agree. I love this. I don’t understand why some people need a dfined warmup.
                                          Also teasing @Luís-Pinto
                                          Luís PintoL Gabriel.SG 2 Replies Last reply Reply Quote 2
                                            Luís Pinto Platinum Member @Dimitrios Kanellopoulos
                                            @dimitrios-kanellopoulos Just to anwser.
                                            FACT - 24th MARCH 2015 Suunto launch workout planner for Ambit 3/Run with a integrate solution for people that want to use warm-up or no.
                                            SR
                                            Dimitrios KanellopoulosD Brad_OlwinB 3 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
