    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Update SA 4.51.3 Issue or not?
    5 Posts 3 Posters 641 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • A Offline
      AndreasKauth Bronze Member
      Servus mitanand,
      at my run on friday my battery was very low, so during the run, the recording stopped. After the run i charged the battery and thought, everything was ok.
      After the SA update, i checked my customized running mode, but it won´t work. I couldn´t select the settings. Another customized mode worked properly.
      This morning at my run i could not choose my custom mode, so i used the standard running mode. In this mode, no distance was shown, but the track has been recorded (Seen in breadcrumbs map). The sync with SA however was with no GPS track and no distance.
      Had anyone similar problems?
      Soft reset had no effect - to do a hard reset, i first want to ask for help from the community.
      Thanks a lot
      Andreas
      freeheelerF surfboomerangS 2 Replies Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @AndreasKauth
        @andreaskauth
        maybe your running mode went corrupt? I would start with only deleting and newly creating your running mode and check if it helps.
        We’ve seen a similar behavior with snowboarding activity already.
        living sideways
        A 1 Reply Last reply Reply Quote 0
        • A Offline
          AndreasKauth Bronze Member @freeheeler
          @freeheeler
          Thank you, i’ve already tried deleting the sport mode. The circle circles an finally the message is shown: " oh, something went wrong"
          I think i will try a hard reset…
          freeheelerF 1 Reply Last reply Reply Quote 0
            @andreaskauth
            hmm… hard reset is like the last resort, because you have to setup everything again (no backup available yet…).
            I might be wrong, but I think I succeeded with deleting only the wrong activity… you can select one by one or multiple. maybe the issue you’re facing is different.
            living sideways
            • surfboomerangS Offline
              surfboomerang @AndreasKauth
              @andreaskauth your description looks a lot like the issue I have had with the snowboarding profile. (Mostly after a firmware update)
              Selecting the corrupted profile result in the “Oops…” error in SA and a watch reboot if you try to select it in the watch.
              I could always fix it by deleting and recreating the profile as @freeheeler suggested before. No hard reset was necessary.
              Suunto Vertical Titanium Solar
              OnePlus Nord 4
              Register Login
              • First post
                Last post
              Suunto Terms | Privacy Policy
