    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Issue with Spartan Sport Wrist HR
    Scheduled Pinned Locked Moved Spartan
    12 Posts 8 Posters 4.1k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Jibay KingJ Offline
      Jibay King
      Hi everybody,
      I have a problem regarding my Suunto Spartan Sport Wrist HR : I can’t boot the watch. Indeed there is always an arrow inside the screen like this :
      So I tried to reset my watch using SuuntoLink because it said "Your watch need to be reset " but the update failed ! I tried several times but there is always the same issue :
      So it is even impossible to make a hard reset of the watch and I can’t use it anymore !
      The current version of the firmware is the 2.8.32. Is it possible to manually reset the firmware or is there an other solution ?
      Thank you very much for your response !
      Have a nice day
      suzzloS 1 Reply Last reply Reply Quote 0
      • suzzloS Offline
        suzzlo Moderator @Jibay King
        @jibay-king is you cable ok? I have similar issues, and finally the problem was in the cable… The communication is always is cuted every some second, and FW updated fails mostly everytime… This issue (with the cable) also ruined the battery
        Let’s hope your issue is not related, but check cable, just to be sure, please
        BR
        Suunto: Race, S9Peak, Spartan Sport Wrist
        Garmin: FR745, Edge 530
        SA topics:
        • Guides - https://forum.suunto.com/tags/guides
        Jibay KingJ 1 Reply Last reply Reply Quote 1
          Jibay King @suzzlo
          @suzzlo
          Hello,
          Thanks for your answer.
          Ok I’ll check the cable but it’s a bit strange because the update doesn’t fail immediately, because the progress bar is not empty …
          EgikaE 1 Reply Last reply Reply Quote 1
          • EgikaE Offline
            Egika Platinum Member @Jibay King
            @jibay-king Please also try a different computer. I keep having issues with my desktop. On my notebook it is always smooth.
              Jibay King
              Hello,
              I tried a different cable and a different computer, but it didn’t work …
              It’s strange because, when click on the “reset button” in the SuuntoLink app, the screen is showing “updating watch”.
              Is there a way to manually downgrade the firmware of the watch in order to perform a factory reset ?
              Or have you got a zip file of the first firmware version of the watch ? (Suunto Spartan Sport Wrist HR)
              Mff73M 1 Reply Last reply Reply Quote 0
              • Mff73M Offline
                Mff73 @Jibay King
                @jibay-king
                https://forum.suunto.com/topic/6836/firmware-collection/20
                SSU (retired), SV1, SV2
                Wife : S9PP
                SA: Always the latest beta :)
                Android + Galaxy S205G
                Nicolás VargasN 1 Reply Last reply Reply Quote 0
                • Nicolás VargasN Offline
                  Nicolás Vargas @Mff73
                  @Mff73 @jibay-king Hi there, I have the exact same problem… how can you install an update using the zip file? And which Update works for the Suunto Spartan Sport Wrist HR
                  sartoricS 1 Reply Last reply Reply Quote 0
                  • sartoricS Offline
                    sartoric Moderator @Nicolás Vargas
                    @Nicolás-Vargas said in Issue with Spartan Sport Wrist HR:
                    Drag and drop it on suuntolink (if you search the forum there should be a sort of “instruction” post)
                    Just check the linked thread 😉
                    SVTS - 2.50.28
                    SSSWHR BARO Amber - 2.8.32
                    Samsung A5 2016 - Android 7.0
                    Suunto App Android 6.11.8 beta
                    D 1 Reply Last reply Reply Quote 1
                    • D Offline
                      Dwartus @sartoric
                      Hello,
                      I have the same situation with Spartan Trainer Wrist HR.
                      I tried with an other cable (even if the cable work correctly with my Ambit 2), same result.
                      I also tried to update manually the firmware by drag and drop the zip file into Suuntolink. The update started then abort, as before.
                      I tried with the following firmware:
                      Forssa-fw_2.8.32.3079-B
                      Forssa-fw_2.8.24.2899-B
                      Do you have other idea ?
                      Thank you
                      • Mff73M Offline
                        Mff73 @Dwartus
                        @Dwartus said in Issue with Spartan Sport Wrist HR:
                        there is a way to put the watch in shipping mode in SuuntoLink (if i remember well), it may “unblock” something.
                        https://forum.suunto.com/post/44426 or
                        https://forum.suunto.com/post/46365
                        Wife : S9PP
                        D 1 Reply Last reply Reply Quote 0
                        • D Offline
                          Dwartus @Mff73
                          @Mff73 Thanks, I already did this action in the past, nothing change.
                          I created a ticket to send back the watch to suunto support, I will see the next step (If the watch is out or just a reset by service).
                          Thank you
                          P 1 Reply Last reply Reply Quote 0
                          • P Offline
                            priem @Dwartus
                            @Dwartus
                            And may i ask what the feedback was from suunto?
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
