    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Backlight Standby function Suunto 9 Baro
    10 Posts 3 Posters 815 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • F Offline
      festigrat
      Hello everyone,
      I don’t understand the standby function of the backlight. How does it work? If I use On or Off I can’t see a difference.
      Has anyone an idea?
      Thanks,
      Alexander
      surfboomerangS inkognitoI 2 Replies Last reply Reply Quote 0
      • surfboomerangS Offline
        surfboomerang @festigrat
        @festigrat Did you try it in a dark environment? The standby backlight is very faint in daylight, but more than suffice for darker environments.
        Normal backlight is more powerful
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        • inkognitoI Offline
          inkognito Platinum Member @festigrat
          @festigrat Also, do you have “Do not disturb” mode on by any chance? Because if you do, standby backlight is deactivated regardless on the settings.
          SV: fingers crossed :D
          S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
          Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
          Despite some pretty bad luck, I still love Suunto!
          • F Offline
            festigrat
            Hello, thanks for the fast answers. Do not disturb is not on. I don’t recognice any difference if I use Standby On or Off. I used it in dark enviroment. Can you please discribe, what should happen if I use On or Off?
            surfboomerangS 1 Reply Last reply Reply Quote 0
              @festigrat
              Also check this post: https://forum.suunto.com/topic/6580/suunto-9-raise-to-wake-feature/7?_=1641289857250
              Standby Fixed (it looks brighter on this picture than in real life)
              Standby off
              OnePlus Nord 4
              • F Offline
                festigrat
                Ok, I think the Suunto 9 Peak has additional features. I can only chose On or Off. Can someone please tell me what happen if I chose ON or OFF? What is the result? I can’t see a difference.
                  @festigrat The Suunto 9 Peak does have more options because it has a light sensor. The Suunto 9 Baro however has a subset of those options and should behave the same.
                  What firmware version has your watch?
                  OnePlus Nord 4
                  • F Offline
                    festigrat
                    It has the newest firmware. The problem ist, that I don’t understand the manual and I don’t understand how it should behave.
                      @festigrat With standby to ON the watch should always (except in Do-Not-Disturb mode) enable a very faint backlight to improve readability of the watch. Especially when it gets dark.
                      With Standby to OFF the watch doesn’t enable a backlight and thus conserving a little power. Only button presses and incoming notifications enable the backlight for about 10 sec.
                      OnePlus Nord 4
                      • F Offline
                        festigrat
                        @surfboomerang
                        Thank you very much! Now I understand it. Best wishes. Alexander
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
