    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    peak 9 not able to pair anymore - tried most everything
    Scheduled Pinned Locked Moved Suunto 9 Peak
    bluetooth peak9 failure
    6 Posts 3 Posters 2.4k Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • steve mileyS Offline
      steve miley
      My Peak 9 stopped pairing today. I tried all the steps in the troubleshooting, removed pair from watch, remove pair from phone, restarted both, In using just bluetooth, i was able to get it to pair
      and give a code, but the suunto app wasn’t happy with that. Now I get a constant “pairing failed for some reason”, restarting just brings me back here. i’ve removed the cache on the app (pixel 4a 5g running android 12)
      I’ve even done a reset on my watch, so its in the setup mode.
      no luck, same problem.
      One big question I have, is where is my data stored in case I delete the app from my phone. Is the data only stored on my watch? I don’t sync with strava or any other service? Can I view the data on a SUUNTO website?
      I don’t have the movescount app on my phone.
      Thanks for any help.
      steve mileyS isaziI 2 Replies Last reply Reply Quote 0
        steve miley @steve miley
        @steve-miley
        a little more info - when it does pair, it says “found a device”
        “Suunto 9 peak”
        212010001592
        with a pair button, which yields same error.
        • isaziI Offline
          isazi Moderator @steve miley
          @steve-miley if data is in the app, you can uninstall and reinstall it.
          Blog: isazi's home
          B steve mileyS 2 Replies Last reply Reply Quote 0
          • B Offline
            BlueDschinn @isazi
            I had also difficulties. The solution for me was the pairing not from the Bluetooth “app” of the mobile phone but from the Suunto app (Bluetooth off until I opened the Suunto app) itself. After unpairing before on the mobile phone and the Peak as well.
            isaziI 1 Reply Last reply Reply Quote 0
            • isaziI Offline
              isazi Moderator @BlueDschinn
              @bluedschinn said in peak 9 not able to pair anymore - tried most everything:
              Well, it should also be in the documentation, but you should NEVER use the phone pairing, just let SA do its thing. It is not going to work otherwise.
              Blog: isazi's home
                steve miley @isazi
                @isazi
                Thanks all - uninstalling the app / re installing and logging in brought the data back and enabled me to sync again. Others: hanks for the tip of just having the APP pair and not the phone.
                Steve M.
                • First post
                  Last post
                Suunto Terms | Privacy Policy
