Amazed bymy new S9P , some issues with delayed start
Hi everyone,
Amazed by my new 24/7 companion and its extraordinary beauty!
However I do seem to face some sort of an issue when trying to start an activity where it shows the Start oval button and the watch is not responding to clicking the button or tapping on the screen for some 3-5 seconds every time. It seems as it tries to calculate something or waiting for some input. This occurs on running and on Hiking that I tried (both custom made ones)
Is there something that I need to check on the customization maybe ?thank you in advance
@thanasis 3-5 seconds seems a bit too long. Does it happen with all sports or just these two custom ones?
on the custom ones.
The basic Running is much faster. -
I noticed it as well, i think it’s… Normal?
Yup, same for me. Also custom profiles.
And if you want to lock the watch right after the start, there is another 2-3 sec delay. -
@surfboomerang said in Amazed bymy new S9P , some issues with delayed start:
And if you want to lock the watch right after the start, there is another 2-3 sec delay.But for me it’s not only for custom sports, I use walking it’s slow as well
@zhang965 6 seconds if you look at the workout timer
I have the same problem on the S9 in all sport modes, but I got used to it. It is very inconvenient at athletic competitions, when you need an instant start and the watch is still in an unclear state.
https://photos.app.goo.gl/Dfbc8ZP5ctnmJmaW8
sometimes i can be fast, but not everytime
I realized that the activity counter is indeed counting despite the fact that the screen is “unresponsive”
so the issue is more on the UX side and not an actual one
@stas-varazhbit The timer is not affected. So when you press Start, the watch starts counting right away but just doesn’t show you.
Looooong time ago, when Spartans gets FW updates, this situation was the opposite : screen was updated quite fast, but time duration didn’t start at button press = miss a couple of seconds.
If perfection doesn’t exist, I would prefer not to miss some seconds, rather than screen updating instantly
@surfboomerang But the start on the gps starts 5-6 seconds after pressing the button.
@mff73 I think it is related to where was the GPS fix and not related to the actual start of the activity
So what’s the conclusion? It’s normal?
@zhang965 i think the issue is that “searching for GPS” causes the delay.
When i open the suunto App and then start the activity things are much faster
I also have a slow start. It was like this a long time ago on the S9 but it got fixed in a FW update and now it surfaced in the new FW update on the S9P.
The slow start is due to loading the activity screens. There was always this issue especially when switching activity types.
The timer should though count correct.
Regarding the GPS logging typically around second 1-10 it logs the first sample and that depends on the quality and speed.
I hope it helps.
Register Login
