    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 media controll
    15 Posts 5 Posters 1.1k Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • mklbhmM Offline
      mklbhm
      My S9 can’t find media…
      I’m wondering how I should set up my S9? Phone (Android)?
      Which apps, on my phone, are compatible with this feature?
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @mklbhm
        @mklbhm you should not be doing anything in particular on your phone, just use a media app (e.g. YouTube) and open the media control on your watch.
        Blog: isazi's home
        mklbhmM 1 Reply Last reply Reply Quote 0
        • mklbhmM Offline
          mklbhm @isazi
          @isazi Thanks for answering so fast! 🙂
          Sorry but I still get the response : “Media can’t be found”…
          (I’ve restarted the watch)
          • isaziI Offline
            @mklbhm watch is paired with the phone and you have the latest SA version, right?
            Blog: isazi's home
            • mklbhmM Offline
              mklbhm @isazi
              @isazi My exercises are synced to SA - That must mean that watch and phone are paired, right?
              I’m running SA version 4.45.5. According to Google Play there is no newer version.
              isaziI 1 Reply Last reply Reply Quote 1
              • isaziI Offline
                @mklbhm okay, strange. I don’t know many more tricks, the function always worked for me. Maybe someone else can chime in.
                Blog: isazi's home
                S 1 Reply Last reply Reply Quote 0
                • S Offline
                  Shrek3k @isazi
                  Have you activated notifications on your watch and in the app? For me media control only works if this is activated.
                  using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
                  OS - Android 16/Pixel Pro 7
                  mklbhmM 1 Reply Last reply Reply Quote 1
                  • mklbhmM Offline
                    mklbhm @Shrek3k
                    @shrek3k Thank you, shrek3k!! I thought all setting would be done in the watch. Now I have changed the setting in SA aswell. Now it works! #MeHappy again! 🙂
                    • 7 Offline
                      77alex77 Bronze Member
                      Hello,
                      If SA is not running, then the feature does not work. Maybe it is by design, I’m not sure.
                      • isaziI Offline
                        isazi Moderator @77alex77
                        @77alex77 check that SA is allowed to run in the background, and it is not battery optimized.
                        Blog: isazi's home
                        7 1 Reply Last reply Reply Quote 0
                        • 7 Offline
                          77alex77 Bronze Member @isazi
                          @isazi :
                          hello. I have checked and that is the case. The only way to get the media control working with my setup is :
                          1. start SA
                          2. wait for SA synchro with my S9B
                          3. start a media player
                          If I do only 3) then I get “Media can’t be found” on the S9B. Is it normal ?
                          isaziI DMytroD 2 Replies Last reply Reply Quote 0
                          • isaziI Offline
                            @77alex77 not really normal, SA should be running in background all the time.
                            Blog: isazi's home
                            • DMytroD Offline
                              DMytro @77alex77
                              @77alex77 maybe due to battery optimization? Check that, also try uninstall/reinstall.
                              • 7 Offline
                                Thanks all, I will recheck the SA parameters and I will tell you.
                                • 7 Offline
                                  Hello all.
                                  The issue was with my mobile. The ‘auto start’ feature for SA was not activated. Below is the tutorial I have followed for my redmi note (by discarding the step ‘App pinning / App locking’):
                                  https://dontkillmyapp.com/xiaomi
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
