    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Peak heart rate plateau
    Scheduled Pinned Locked Moved Suunto 9 Peak
    19 Posts 11 Posters 1.9k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • I Offline
      iocast
      Hi,
      today i tried to reach my hr limit. i noticed that there is a plateau at 210 bpm. is this normal?
      The watch, the suunto app and the fit-file, all shows me a heart rate plateau of 210 bpm over more than 2 minutes. I can’t believe that this is correct.
      Screenshot_20210915_101530.jpg quantified-io.png IMG_20210915_101706_edit_208375494399974.jpg
      does anyone have the same experience?
      Best regards
      isaziI Brad_OlwinB Dimitrios KanellopoulosD 3 Replies Last reply Reply Quote 0
      • inkognitoI Offline
        inkognito Platinum Member
        Go to watch Settings - General - Personal and check your Max HR you set there. Isn’t it 210 by any chance? 😄
        SV: fingers crossed :D
        S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
        Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
        Despite some pretty bad luck, I still love Suunto!
        I 1 Reply Last reply Reply Quote 0
        • TheGuyFromTheSummitT Offline
          TheGuyFromTheSummit Silver Members
          Do you use a HR belt or the OHR ?
          • I Offline
            iocast @inkognito
            @inkognito thank you for your reply.
            I tried this a few days ago. then I always run in zone 1 on over 90% of my runs.
            the maximum measured and recorded heart rate should be independent of the settings and the zones.
            the funny thing is that i never get above 210 on many runs no matter what I set and how i put the watch on (instructions on suunto.com already followed)
            • I Offline
              iocast @TheGuyFromTheSummit
              @theguyfromthesummit ohr, the one built into the watch. I don’t use any additional equipment.
              • isaziI Offline
                isazi Moderator @iocast
                @iocast I will ask Suunto if this is within specs or not. I have no chance of getting such a heart rate until I am having a heart attack so never noticed 🙂
                Blog: isazi's home
                • I Offline
                  iocast @isazi
                  @isazi many thanks. If you need the .fit or the samples.json file let me know.
                  Mff73M isaziI 2 Replies Last reply Reply Quote 1
                  • Mff73M Offline
                    Mff73 @iocast
                    @iocast
                    Also a good question, do you think 210bpm is something normal for you? It is possible but quite unusual. Is the problem this “plateau” or “bad measurement” stucked at 210bpm?
                    Suunto Spartan Ultra (since 2016) FW: 2.8.24 (retired)
                    Suunto Vertical all black
                    Wife : S9PP
                    SA: Always the latest beta :)
                    Android 13, Galaxy S205G
                    • I Offline
                      iocast @Mff73
                      @mff73 i knew these questions would come. whether it is healthy or not is another question. i just wonder if the sensor or watch is measuring correctly. over 2 minutes no variations in the measurement can not be correct.
                      Mff73M 1 Reply Last reply Reply Quote 0
                      • Mff73M Offline
                        Mff73 @iocast
                        @iocast
                        If your heart really goes to 210, you should know 😊, and healthy or not depends on other factors. If you have no HR belt to check, there is still the old manual pulse “measurment” 😁 finger on your inner wrist or carotide, count over 10s and multiply by 6.
                        But plateau is not really normal, whatever the value.
                        Wife : S9PP
                        • isaziI Offline
                          @iocast so the question if there is a hard limit of 210 in the watch or app has been forwarded to Suunto and reached the developers, will hopefully get an answer for you.
                          Blog: isazi's home
                          Stas VarazhbitS 1 Reply Last reply Reply Quote 0
                          • Stas VarazhbitS Offline
                            Stas Varazhbit @isazi
                            My maximum heart rate after a running test is 208, so 210 is no surprise to me.
                            Suunto 9P
                            Suunto 9 no baro
                            Suunto Ambit3S
                            MiniForkliftM ? 2 Replies Last reply Reply Quote 0
                            • Brad_OlwinB Online
                              Brad_Olwin Moderator @iocast
                              @iocast If you look at your training over 6 months or more, especially with a HR belt what is your highest HR reading for a 30 sec time period. My only concern is that this is aberrant HR readings. It is possible but your zone 4/5 is set at 162 so over 200 seems very high for max HR.
                              Vector/T6c/Ambit 3 Peak/S5 Copper/S3/S7 Ti/S9 baro Ti/S9P Ti/S9PP Ti/Vertical Ti/Race Ti/RaceS/Ocean/Wing/Race2Ti
                                Dimitrios Kanellopoulos Community Manager @iocast
                                @iocast app wise we have a hard limit on the zone 5 (view only) and I think export wise as well. If you have a Suunto app link for me I can get the raw data and see if they were clipped.
                                Creator of Quantified-Self.io
                                youtube.com/c/dimitrioskanellopoulos
                                https://instagram.com/dimitrioskanellopoulos
                                https://www.strava.com/athletes/7586105
                                • I Offline
                                  iocast @Dimitrios Kanellopoulos
                                  @dimitrios-kanellopoulos I sent you a pm. what do you mean with suunto app link. (sorry. I am not yet familiar with the jargon. this is my first suunto watch.)
                                  • MiniForkliftM Offline
                                    MiniForklift Platinum Member @Stas Varazhbit
                                    @stas-varazhbit said in Suunto 9 Peak heart rate plateau:
                                    That’s a massive ceiling you have there! I only know one person that has a max above me and mine is only 194bpm… however I am 44 so not exactly a spring chicken
                                    SV Titanium Solar Forest
                                      Brad_Olwin Moderator @MiniForklift
                                      @miniforklift said in Suunto 9 Peak heart rate plateau:
                                      When I was in my early to mid 40s my max was in the low 190s. Twenty years later my max now is ~180. However, max HR has more to do with genetics than anything else and it is used to set training zones along with an anaerobic threshold and a aerobic threshold.
                                      • suzzloS Offline
                                        suzzlo Moderator
                                        I don’t think plateau HR is something normal so there should be a limit or an error:
                                        • getting the measurements
                                        • threshold in the sensor
                                        • threshold in SA
                                        Said that, 210??? really? 😆
                                        Suunto: Race, S9Peak, Spartan Sport Wrist
                                        Garmin: FR745, Edge 530
                                        SA topics:
                                        • Guides - https://forum.suunto.com/tags/guides
                                        • ? Offline
                                          A Former User @Stas Varazhbit
                                          205 for me on FTP test, but some years ago I got 200 + (check here, with ambit 2 and suunto hr belt new at the time)
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
