    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 change to Ultra mode during run - low battery - No GPS data from then on
    28 Posts 8 Posters 3.3k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • B Offline
      BradWeber @isazi
      @isazi Thanks a lot. I’ll get in touch with them. Thanks for the help!
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator
        I have been trying to replicate the bug with no luck, always get the track. Can you tell me which sport mode where you using, which if any S+ fields, configuration, etc.
        I will keep trying.
        Blog: isazi's home
        • EgikaE Offline
          Egika Platinum Member
          Tried to reproduce this as well today.
          Got a track for the whole activity. Had to calibrate the compass after switching to Ultra.
          Don’t know what happens if you don’t do this.
          isaziI 1 Reply Last reply Reply Quote 1
          • isaziI Offline
            isazi Moderator @Egika
            @egika I did run without calibration, and got a very good track anyway 😕
            Blog: isazi's home
            • Brad_OlwinB Offline
              Brad_Olwin Moderator @BradWeber
              @bradweber I attempted to reproduce this over the last weekend, switching modes and I have a GPS track for the entire hike. Is it possible that you lost GPS because you selected where satellites were not visible? This has been a suggestion.
              Vector/T6c/Vertical 2 Ti
              zadowZ 1 Reply Last reply Reply Quote 0
              • zadowZ Offline
                zadow @Brad_Olwin
                @brad_olwin Well, I do not think so. GPS signal was fine. It also could be that watch got confused as I was switching between modes back and forth. Mostly, when we stopped somewhere and stayed there for longer time, I switched to Endurance and when we start moving again, switched it back to Performance. I agree that it is very hard to reproduce as most of the time it is working properly. I can guess only, but the problem occured probably twice.
                Another thing could be that I am using custom sport mode for every activity. In the past, when any problem occured (mostly with multisport), it always helped to delete and recreate that custom activity again. So, I can guess only, it also could be connected with malfunctioning customized sport mode. I cannot prove that because I re-created it already… 😞
                Suunto Race
                Suunto S9 Baro Titanium, Ironman l.e. (607/1406)
                Suunto Smart Sensor
                Wahoo Tickr FIT
                Hammerhead Karoo 2
                Swim Ride Run Rest Repeat
                • isaziI Offline
                  isazi Moderator @zadow
                  @zadow I will keep trying to reproduce it, so far no tester has been able to. If it happens to you, can you send logs with the app and send me a private message?
                  Blog: isazi's home
                  • isaziI Offline
                    isazi Moderator @BradWeber
                    @bradweber did this happen in a aid station? I mean, did you switch to ultra inside the station?
                    Blog: isazi's home
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
