    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS normal?
    107 Posts 16 Posters 29.1k Views 15 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • TheGuyFromTheSummitT Offline
      TheGuyFromTheSummit Silver Members @Guest
      @_marcus_ said in GPS normal?:
      Bin dann zur Fenix 6x Pro damals gewechselt
      Maybe I switch back to English, so nobody feels left out haha.
      All in all I am satisfied with my S9B, but the problems are increasing…
      Have you tested the Fenix 6x Pro and S9B regarding tracking reliability? (better GPS track, ascent etc.?)
        So now I checked some old data and it looks like, that Suunto did something with the software… in a bad way
        2020 everything was fine
        2021 GPS track is wobbly and looses the signal
        The comparison clearly shows, that something went wrong in 2021. A friend of mine also recognized a drop in performance since July.
        DMytroD MdzOttM 2 Replies Last reply Reply Quote 1
        • ? Offline
          A Former User @TheGuyFromTheSummit
          @theguyfromthesummit no, I only did a direct comparison with the Apex Pro and S9P wearing both on my arms.
          • DMytroD Offline
            DMytro @TheGuyFromTheSummit
            @theguyfromthesummit by the way, why don’t you try snap to route if a “good” track is of importance to you? Or you don’t use predefined routes?
            TheGuyFromTheSummitT 1 Reply Last reply Reply Quote 0
              TheGuyFromTheSummit Silver Members @DMytro
              @dmytro
              Sometimes I change the route during the run and so snap to route won’t work.
              Even during a race the actual paths was different to the gpx track and messed up the data using snap to route.
              I just want the old performance back 😆
              DMytroD 1 Reply Last reply Reply Quote 0
              • DMytroD Offline
                @theguyfromthesummit ok, I see. Well, If you think it’s firmware related, you might want to try flashing an old one, they are linked somewhere in the forum. Beware, flashing an older FW deletes all your watch data.
                TheGuyFromTheSummitT 1 Reply Last reply Reply Quote 1
                  @dmytro thanks I will have a look.
                  But does anyone else experience such drop in accuracy?
                  S 1 Reply Last reply Reply Quote 0
                  • S Offline
                    Shrek3k @TheGuyFromTheSummit
                    @theguyfromthesummit (Un)Fortunately not at all. I have a non-baro 9, and although I see some bad sections when the area is really hard on GNSS, I usually have a good track. Just yesterday I ran 8 km on a track, and it worked quite well (area is not covered or bad for GNSS, but nevertheless…), and on a “regular” route the track is at least not ‘nervous’.
                    I usually only use GPS, currently I activated Beidou and before that Galileo to check if there is any real improvement … which I do not notice in my areas.
                    using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
                    OS - Android 16/Pixel Pro 7
                    TheGuyFromTheSummitT 1 Reply Last reply Reply Quote 2
                      TheGuyFromTheSummit Silver Members @Shrek3k
                      @shrek3k hmmm your track look really nice.
                      But I guess there is not much I can do about it …
                      Łukasz SzmigielŁ DMytroD 2 Replies Last reply Reply Quote 1
                      • Łukasz SzmigielŁ Online
                        Łukasz Szmigiel @TheGuyFromTheSummit
                        @theguyfromthesummit just a thought - have you tried wearing your watch differently? Ie. higher or lower or maybe tighter? This is just me doing a wild guess but maybe Suunto is using motion data along GPS for its smoothing / denoising algorithm?
                        S9PP 2.50.28
                        • DMytroD Offline
                          @theguyfromthesummit also if you don’t care about your looking at your watch during an activity, I’ve read fastening your watch to a backpack facing screen up dramatically increases its accuracy. The reason being an improved position of watches antenna and less wobble.
                            TheGuyFromTheSummit Silver Members @Łukasz Szmigiel
                            @łukasz-szmigiel I always wear the watch the same way. But it is really interesting, that the track gets much better when speeding up (<5:00 pace).
                            So maybe they changed something connected with the speed.
                            Today I will try the “hiking” sports mode and see if the track gets better (Idea behind: hiking is usually much slower than trail running, so Suunto flattens the track more in hiking mode, because each GPS measurement will be closer in terms of distance, so they expect more jumping than at a faster pace.)
                              @dmytro Thanks, but I need my heart rate and time during my runs 🙂
                              • ? Offline
                                @theguyfromthesummit enjoy running uphill trails with a <5min pace 😂
                                  @_marcus_ jep, this is the problem 😆
                                  But as long as I can be sure, that the distance and ascent is precise, I do not mind the GPS track.
                                  So further testing has to be done 🙂
                                  • ? Offline
                                    @theguyfromthesummit but that‘s the question. Elevation most of the time is the same than with my Apex Pro during trailrunning. But distance is not. S9P always records more km. Today Apex Pro 11,39km/504m+ vs S9P 12,14km/496m+. Of course I don‘t know which is correct. But seeing the track makes me think that S9P overestimates the distance a bit. Ok, in the end you get a better pace with S9P 🤣
                                    TheGuyFromTheSummitT MiniForkliftM 2 Replies Last reply Reply Quote 1
                                      @_marcus_ I also saw this comparing my S9B and a Forerunner 945
                                      Usually S9B has +0.5-1.5km …
                                      • jokeen2020J Offline
                                        jokeen2020
                                        I’ve a similar discrepancy in distance between an Ambit 3 Peak/ Polar M450 and S9B. The distance is always a little longer on the S9B for both Cycling and Runs.
                                        Also the GPS tracks on the S9B never look quite as smooth as the other devices. Similar to the ‘jagged’ tracks on the screenshots in this thread.
                                        Maybe the ‘jagged’ tracks are where it’s picking up the little bit of extra distance?
                                        I’ve tried different GPS settings and soft resets, but nothing helps.
                                        I actually tend to use the Ambit 3 Peak as my default device because I know it’s more accurate. Especially if I’m pacing a run.
                                        MdzOttM 1 Reply Last reply Reply Quote 0
                                        • MdzOttM Offline
                                          MdzOtt @jokeen2020
                                          @jokeen2020 If you use auto-pause, the distances differ, because different devices are more or less aggressive about what constitutes “moving” and what is a pause.
                                          R2
                                          S9 Baro
                                          SA on Android
                                          Ambit 3 Peak
                                          Ambit 2 Sapphire
                                          jokeen2020J 1 Reply Last reply Reply Quote 0
                                          • MdzOttM Offline
                                            MdzOtt @TheGuyFromTheSummit
                                            @theguyfromthesummit occasionally, there are issues with the GPS (the system itself). I am not saying that this is the case, but it happened to me that a track was completely off one day and the next it was back to normal.
                                            R2
                                            S9 Baro
                                            SA on Android
                                            Ambit 3 Peak
                                            Ambit 2 Sapphire
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
