    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS normal?
    107 Posts 16 Posters 28.0k Views 15 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • TheGuyFromTheSummitT Offline
      TheGuyFromTheSummit Silver Members
      Currently I am running the same route multiple times a week.
      Always at the same time with the same setting in terms of GPS. Even the weather is almost the same.
      Nevertheless the GPS track looks weird.
      Is this in the “normal” range or is something wrong with my watch?
      Screenshot_20210815-071255_Suunto.jpg Screenshot_20210815-070258_Suunto.jpg Screenshot_20210815-071318_Suunto.jpg
      Łukasz SzmigielŁ ? 2 Replies Last reply Reply Quote 0
      • Łukasz SzmigielŁ Offline
        Łukasz Szmigiel @TheGuyFromTheSummit
        @theguyfromthesummit which GNSS are you using, GPS only or two systems?
        S9PP 2.50.28
        TheGuyFromTheSummitT 1 Reply Last reply Reply Quote 0
          TheGuyFromTheSummit Silver Members @Łukasz Szmigiel
          @łukasz-szmigiel I am using GPS + QZSS + GLONASS and I live in Austria.
          But don’t ask me, why I decided to go with those settings. I just selected them 2 years ago and back then it worked fine.
          • S Offline
            Shrek3k
            The track looks rather ‘nervous’ (and not good) which IMO explains the differences in distances.
            I would try 1. a softreset and 2. different GNSS-combinations (pure GPS - with Beidou - with Galileo), and give the watch some time to recover from Sync / import of AGPS-data.
            using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
            OS - Android 16/Pixel Pro 7
            TheGuyFromTheSummitT 1 Reply Last reply Reply Quote 1
              TheGuyFromTheSummit Silver Members @Shrek3k
              @shrek3k
              thanks, I will try both and this route is planned for Tuesday again. So let’s see if anything changed.
              Only GPS or GPS + something else for the start?
              DMytroD Łukasz SzmigielŁ 2 Replies Last reply Reply Quote 1
              • DMytroD Offline
                DMytro @TheGuyFromTheSummit
                @theguyfromthesummit I’m in Munich and use GPS+Galileo - works just fine. But when out in the mountains I’m not really picky.
                  @theguyfromthesummit in challenging terrain usually the more the merrier as satellites are often obscured by terrain features but I wouldn’t expect wonders. Also, you might want to wait a little longer pre-start for better initial GPS reception.
                  S9PP 2.50.28
                  TheGuyFromTheSummitT 1 Reply Last reply Reply Quote 2
                    @łukasz-szmigiel said in GPS normal?:
                    so I test GPS+Glonass first
                    Usually I wait till the GPS symbol stops blinking, shouldn’t that be enough?
                    Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
                      @theguyfromthesummit in my opinion - it should. But somehow if you wait for like 30s to a minute, it usually makes track better in the first 15 minutes of workout or so.
                      Personally I’d like the UI changed in regards of how GPX fix is being displayed from no fix / fix to no fix / fix / good fix.
                      When I have time, ie when driving by car to location, I often go to location / my location and leave the coordinates open for 15 minutes which should be enough for the watch to get current almanac. I never experienced tracking problems on trails after such preparation.
                      S9PP 2.50.28
                      TheGuyFromTheSummitT Jamie BGJ 2 Replies Last reply Reply Quote 1
                        @łukasz-szmigiel
                        thanks!
                        I just checked the GPS track of my hike 3h later and it is really nervous. The route my girlfriend tracked with her forerunner 945 was completely clean.Screenshot_20210815-204854_Suunto.jpg
                          I did a softreset und used the Galileo combination.
                          It got even worse…
                            Waiting longer + using GPS Beidou combination is even worse…
                            I am rather clueless right now.
                            • ? Offline
                              A Former User @TheGuyFromTheSummit
                              @theguyfromthesummit I have the same wobbling track, seems as if I am drunk. Posted it some weeks ago in the S9P real world data forum here. No matter what GPS settings I use.
                                TheGuyFromTheSummit Silver Members @Guest
                                @_marcus_
                                I thought or was hoping, that the peak has a better gps track…
                                Sorry to hear that.
                                So you just live with this?
                                • ? Offline
                                  @theguyfromthesummit I use my Apex Pro or Vertix…more reliable/pausible track recordings. Sometimes I wear the S9P too when I want ETA/ETE for a predefined track which Coros does not offer up to now. Maybe this will change soon…
                                  BTW I live near Garmisch.
                                  TheGuyFromTheSummitT DMytroD 2 Replies Last reply Reply Quote 2
                                    @_marcus_ Ah dann kann ich auch Deutsch schreiben 🙂 Also schon fast ganz weg von Suunto.
                                    Liebäugl selbst immer mit einer Garmin, aber bleib dann doch wieder bei Suunto.
                                    • ? Offline
                                      @theguyfromthesummit von Suunto weg als tägliche Uhr bin ich seit 2019, als ich dann schlussendlich doch enttäuscht war von der S9B. Es waren Hoffnungen da, die man natürlich nicht hätte haben dürfen. Bin dann zur Fenix 6x Pro damals gewechselt. Seit Sommer letzten Jahres dann zu Coros gekommen wegen der genialen Unterstützung des Stryd Footpod. An die S9P bin ich sehr günstig gekommen und hab sie zum Spielen geholt und um zu schauen, wie Suunto sich so entwickelt…aber meine Favoriten sind Apex Pro und Vertix
                                      • DMytroD Offline
                                        DMytro @Guest
                                        @_marcus_ oh cool! Nice places you have there, I’m going up the Alpspitze in a couple of weeks.
                                        • ? Offline
                                          A Former User @DMytro
                                          @dmytro nice, hope you find a day with less people 😅 which way do you go up? Via Ferrata?
                                          DMytroD 1 Reply Last reply Reply Quote 0
                                          • DMytroD Offline
                                            DMytro @Guest
                                            @_marcus_ yup. Yeah, I’m going up from the valley, so I’ll start the ferrata itself relatively late when people aren’t that abundant anymore.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
