    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    STRYD Footpod
    14 Posts 8 Posters 1.7k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • T Offline
      TyreseJ4
      Good evening! I’ve been using the STRYD wind with my Suunto 9 for about a year and for some reason I never get AirPower, form power ratio, and ground contact time information. It’s been like that for some time and I’ve never made a big fuss about it. Just curious if there’s a way to fix it. Anyone else have that issue?
      isaziI 1 Reply Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @TyreseJ4
        @tyresej4 need to sync your Stryd with the Stryd app, and it’ll download these data too.
        Blog: isazi's home
        T 2 Replies Last reply Reply Quote 2
        • T Offline
          TyreseJ4 @isazi
          @isazi I’ll try that when I get home.
          • T Offline
            TyreseJ4 @isazi
            @isazi That worked! Thanks
            • v.sacreV Offline
              v.sacre Silver Members
              Hi all,
              Do you have any advice for pairing Stryd footpod to a S9P watch ?
              Do we have to pair it both as a footpod and as a power device ?
              Thanks for your help
              A3S | S9B | S9P | S9PP | SV1 Ti | SV2 Ti
              Suunto Wing
              Suunto App: Android Beta
              isaziI BulkanB suzzloS 3 Replies Last reply Reply Quote 1
              • isaziI Offline
                isazi Moderator @v.sacre
                @v-sacre if you pair it as a foot pod you get pace, distance, power, cadence. If you pair it as power pod you only get power. So pair it the way you prefer.
                Blog: isazi's home
                • BulkanB Offline
                  Bulkan Moderator @v.sacre
                  @v-sacre this video of Joaquin has all the info. Is in Spanish but you can get subtitles in YouTube.
                  Tips: the first time you pair go to paired devices in the watch and in the Stryd turn off auto calibration.
                  Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                  • v.sacreV Offline
                    Thank you both for your answers @isazi @Bulkan . It is clear for me.
                    Do you have any information on accuracy of stryd in trail running.
                    For classic track or road running, it seems stryd are very accurate so it makes sense to upload pace distance and cadence to the watch, but is it alos the case for trail running ??
                    Suunto Wing
                    • isaziI Offline
                      @v-sacre I don’t use Stryd trail running so cannot really help in this case.
                      Blog: isazi's home
                      • Brad_OlwinB Offline
                        Brad_Olwin Moderator
                        @v-sacre I have used the Stryd a lot in the past for trail running. If your trails are fairly smooth and without large hills it will work well. My trails are technical and have big climbs. I have not found the Stryd useful at all for trail running. Mine sits on my desk most of the time.
                        Vector/T6c/Vertical 2 Ti
                        herlasH 1 Reply Last reply Reply Quote 1
                        • PENNACNPP Offline
                          PENNACNP Bronze Member
                          I used a Stryd foot pod for trail running on the East Coast of the US. The power metric serves as one more indicator of effort that I am able to use in pacing myself.
                          SUUNTO VERTICAL TITANIUM SAND
                          SUUNTO 9 PEAK PRO TITANIUM SLATE
                          SUUNTO 9 PEAK GRANITE BLUE TITANIUM
                          SUUNTO 9 BARO CUSTOM
                          • herlasH Offline
                            herlas Silver Members @Brad_Olwin
                            @brad_olwin read on their forums their current firmware has a delay from 15 to 20 secs when you start going up on a hill to display an accurate power for that effort, they’ve been saying about improving it, so far nothing has been fixed , might be hardware limitation in current model too
                            SRS Ti
                            SRun (primarily road runner so testing SRun is a must ;))
                            • suzzloS Offline
                              suzzlo Moderator @v.sacre
                              @v-sacre I always pair both.
                              For road running it’s the best option if you want a high accuracy, and valuable metrics like cadence, power…
                              For trail run, I found useful just when I check after the run, but not when I’m up/down the hills (because I cannot always check the watch).
                              Anyway, I found initially a medium/high investment (200€), but then the time goes on, but the device continue working perfectly after 3 years so I’m quite happy
                              I hope this help
                              Suunto: Race, S9Peak, Spartan Sport Wrist
                              Garmin: FR745, Edge 530
                              SA topics:
                              • Guides - https://forum.suunto.com/tags/guides
                                Brad_Olwin Moderator @herlas
                                @herlas It is not just uphill issues but more to do with effort on technical terrain and downhill effort, which the Stryd simply cannot measure or cope with.
                                Register Login
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
