    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Ascent/descent completly wrong
    46 Posts 16 Posters 8.1k Views 15 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Oliver_ZO Offline
      Oliver_Z
      Re: Suunto 9 baro very low elevation gain vs other brands
      Actually I have a Problem with the ascent/descent measurements. Look:
      About 1000 m too much!
      How could that Happen?
      freeheelerF surfboomerangS sartoricS Brad_OlwinB 4 Replies Last reply Reply Quote 0
      • freeheelerF Away
        freeheeler @Oliver_Z
        @oliver-zamberger
        you can search for it in this forum… long story short: sensor holes were most likely covered with a sleeve or too tight strap and it sealed off on sweaty skin.
        if you check the details of the alti graph you’ll notice several dips (down spikes) that accumulate to 1’000m more.
        Could you share a screenshot of the graph?
        living sideways
        Oliver_ZO 1 Reply Last reply Reply Quote 1
        • surfboomerangS Offline
          surfboomerang @Oliver_Z
          @oliver-zamberger I don’t know if it’s correct for this case, but ascent and descent are the sum of meters you climbed and descended during your activity. Highest and lowest point are the min and max altitude,
          For example if you start at 100m and climb to 150m, then descend to 130m and then climb to 200m your values will be like this:
          Min altitude: 100m
          Max altitude 200m
          Ascend: 120m
          Descend: 20m
          @all Correct me if I’m mistaken
          Suunto Vertical Titanium Solar
          OnePlus Nord 4
          sartoricS Oliver_ZO 2 Replies Last reply Reply Quote 1
          • sartoricS Offline
            sartoric Moderator @surfboomerang
            @surfboomerang
            You’re correct
            SVTS - 2.50.28
            SSSWHR BARO Amber - 2.8.32
            Samsung A5 2016 - Android 7.0
            Suunto App Android 6.10.7 beta
            • sartoricS Offline
              sartoric Moderator @Oliver_Z
              @oliver-zamberger
              Just a note
              You don’t need to create a new discussion, you can reply to the original one even if it’s old.
              SVTS - 2.50.28
              Oliver_ZO 1 Reply Last reply Reply Quote 0
              • Oliver_ZO Offline
                Oliver_Z @freeheeler
                @freeheeler thanks for your reply. So here is a Screenshot
                I know what you. The only Thing is, it never happened to me before. IT always worked fine. Also if th watch was partly covered too. I guess this is since last Firmware Update.
                • Oliver_ZO Offline
                  Oliver_Z @sartoric
                  @sartoric sorry about that. I’m New in this forum and thought I replied to an existing discussion… Didn’t want to create a New one
                  • Oliver_ZO Offline
                    Oliver_Z @surfboomerang
                    @surfboomerang Sure, I know what you mean… Every ascent and descent will be summed up. But like in my case it’s really too much 🤔
                    Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                      Dimitrios Kanellopoulos Community Manager @Oliver_Z
                      @oliver-zamberger looks like the barometer had water in
                      Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                      • Oliver_ZO Offline
                        Oliver_Z @Dimitrios Kanellopoulos
                        @dimitrios-kanellopoulos that wasn’t a Problem since the läßt Update. This is an expensive multisport watch and some sweat shouldn’t influence the Barometer. 🤔
                        sartoricS 1 Reply Last reply Reply Quote 0
                        • sartoricS Offline
                          @oliver-zamberger
                          Well … that’s hard due to physical limitation 😁
                          It’s not easy to fill it with water, but it can happen
                          SVTS - 2.50.28
                          • Oliver_ZO Offline
                            Oliver_Z @sartoric
                            @sartoric and today it happened again. The Barometer Was always free from sweat and not covered with anything. Descending but then suddenly the watch added about 20 m to ascend. So after the hike more than 100 m altitude (ascent/descent) are wrong. And Not any answer from the Support. That’s really annoying!
                            isaziI freeheelerF surfboomerangS 3 Replies Last reply Reply Quote 0
                            • isaziI Offline
                              isazi Moderator @Oliver_Z
                              @oliver-zamberger did you try cleaning the baro hole? Warm water, a soft brush.
                              Blog: isazi's home
                              • freeheelerF Away
                                @oliver-zamberger
                                and a link to the activity to check the graph, please… otherwise it’s just wild guessing for us 😉
                                living sideways
                                • Oliver_ZO Offline
                                  @freeheeler I’m thankful for any solutions/help
                                  So here is the link
                                  https://www.suunto.com/move/oliverzamberger/60cdf605891a7f7d02f03c1d
                                    @oliver-zamberger Was the wach protected by a sleeve? In other words, could wind be a factor in this situation?
                                    OnePlus Nord 4
                                    • Brad_OlwinB Offline
                                      Brad_Olwin Moderator @Oliver_Z
                                      @oliver-zamberger Here is an example from this weekend. I was wearing an S9P on my left wrist and an S9baroTi model on my right wrist. I was carrying a handheld water bottle. On my right wrist by carrying the bottle my skin was blocking the baro hole on the S9bTi. Not the jagged altitude profile AND note the altitude is 2-fold off. There are two readings for the baro as I stopped the watch a few minutes into the run as it did not connect to the smartsensor.
                                      Vector/T6c/Vertical 2 Ti
                                      Oliver_ZO freeheelerF Mister PYCM 3 Replies Last reply Reply Quote 2
                                      • Oliver_ZO Offline
                                        @surfboomerang the watch wasn’t covered by anything. So the baro sensor was always free. Also there wasn’t really any Wind… But if Wind influences the Barometer this much to deliver wrong data, why it ever integrated into the watch🤔
                                        Is there any possibility to deactivate the Barometer?
                                        surfboomerangS 1 Reply Last reply Reply Quote 0
                                        • Oliver_ZO Offline
                                          Oliver_Z @Brad_Olwin
                                          @brad_olwin i can See. It’s totally clear, that the the altitude can’t be 100% correct. But it isn’t ok, when it’s several 100 m incorrect.
                                          And this appears to Happen most when ascending 🤔
                                            @oliver-zamberger Wind does have an effect on pressure and altitude, but I don’t know to what extent.
                                            This is data from a random windsurf session on flat water:
                                            In the old Movescount days there was an option to select how pressure changes should be interpreted by the watch, but that option has been removed in SA unfortunately.
                                            OnePlus Nord 4
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
